Probleme avec java
jai un problemme avec java quean je joue a mon jeux minecraft come vous le saver sa marche avec java mai apres 5 minute le jeux se ferme et un dossier tex se creer den mon bureu de mon pc le mesage de ce dosier tex est
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6906a7f0, pid=3040, tid=2988
# JRE version: 6.0_24-b07
# Java VM: Java HotSpot(TM) Client VM (19.1-b02 mixed mode windows-x86 )
# Problematic frame:
# C [atioglxx.dll+0x6a7f0]
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x03b10800): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=2988, stack(0x03f10000,0x03f60000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000008
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x00000009, EDX=0x0f073214
ESP=0x03f5eacc, EBP=0x0f011014, ESI=0x0c014958, EDI=0x0c00c000
EIP=0x6906a7f0, EFLAGS=0x00010206
Register to memory mapping:
EAX=0x00000000
0x00000000 is pointing to unknown location
EBX=0x00000000
ECX=0x00000009
0x00000009 is pointing to unknown location
EDX=0x0f073214
0x0f073214 is pointing to unknown location
ESP=0x03f5eacc
0x03f5eacc is pointing into the stack for thread: 0x03b10800
"Minecraft main thread" daemon prio=6 tid=0x03b10800 nid=0xbac runnable [0x03f5f000]
java.lang.Thread.State: RUNNABLE
EBP=0x0f011014
0x0f011014 is pointing to unknown location
ESI=0x0c014958
0x0c014958 is pointing to unknown location
EDI=0x0c00c000
0x0c00c000 is pointing to unknown location
Top of Stack: (sp=0x03f5eacc)
0x03f5eacc: 0c00c000 0c014958 692b8744 0f073214
0x03f5eadc: 000046b0 00003110 03f5f468 00000000
0x03f5eaec: 00010011 00000002 0c00ca40 692b8e36
0x03f5eafc: 00003110 03b10800 03f5f4a4 00000000
0x03f5eb0c: 7c925199 03f5eb4c 000900e4 00000004
0x03f5eb1c: 000900d4 00090000 03f5eb64 7c92538b
0x03f5eb2c: 03f5eb4c 000900d4 00000000 0c00c140
0x03f5eb3c: 000046b0 3f800000 3f800000 3f800000
Instructions: (pc=0x6906a7f0)
0x6906a7e0: 56 57 64 a1 f0 0b 00 00 8b f8 8b 87 bc 81 00 00
0x6906a7f0: 8b 40 08 8b 50 04 8b b7 c0 81 00 00 83 c2 14 89
Stack: [0x03f10000,0x03f60000], sp=0x03f5eacc, free space=314k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J org.lwjgl.opengl.GL11.nglDrawArrays(IIIJ)V
J kv.a()V
J ck.a()V
J h.a(Liz;Z)Z
j mh.c(F)V+358
J mh.b(F)V
j net.minecraft.client.Minecraft.run()V+357
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x02e78c00 JavaThread "Client write thread" daemon [_thread_blocked, id=4352, stack(0x039c0000,0x03a10000)]
0x031fc800 JavaThread "Client read thread" daemon [_thread_in_native, id=4356, stack(0x03970000,0x039c0000)]
0x03324400 JavaThread "Thread-7" daemon [_thread_in_native, id=5904, stack(0x56850000,0x568a0000)]
=>0x03b10800 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=2988, stack(0x03f10000,0x03f60000)]
0x03b10400 JavaThread "Timer hack thread" daemon [_thread_blocked, id=3156, stack(0x03920000,0x03970000)]
0x002b6800 JavaThread "DestroyJavaVM" [_thread_blocked, id=5588, stack(0x00350000,0x003a0000)]
0x0322ac00 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=5720, stack(0x035a0000,0x035f0000)]
0x031c2000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=5672, stack(0x03480000,0x034d0000)]
0x031c0c00 JavaThread "AWT-Shutdown" [_thread_blocked, id=5668, stack(0x03430000,0x03480000)]
0x02edf400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=5656, stack(0x033e0000,0x03430000)]
0x02e74400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=5616, stack(0x030c0000,0x03110000)]
0x02e69000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=5612, stack(0x03070000,0x030c0000)]
0x02e67800 JavaThread "Attach Listener" daemon [_thread_blocked, id=5608, stack(0x03020000,0x03070000)]
0x02e66000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5604, stack(0x02fd0000,0x03020000)]
0x02e59400 JavaThread "Finalizer" daemon [_thread_blocked, id=5600, stack(0x02f80000,0x02fd0000)]
0x02e54c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=5596, stack(0x02f30000,0x02f80000)]
Other Threads:
0x02e50c00 VMThread [stack: 0x02ee0000,0x02f30000] [id=5592]
0x02e76400 WatcherThread [stack: 0x03110000,0x03160000] [id=5636]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157376K, used 118345K [0x10020000, 0x1aae0000, 0x25570000)
eden space 139904K, 74% used [0x10020000, 0x16606448, 0x188c0000)
from space 17472K, 80% used [0x188c0000, 0x1966c080, 0x199d0000)
to space 17472K, 0% used [0x199d0000, 0x199d0000, 0x1aae0000)
tenured generation total 349568K, used 45989K [0x25570000, 0x3aad0000, 0x50020000)
the space 349568K, 13% used [0x25570000, 0x28259708, 0x28259800, 0x3aad0000)
compacting perm gen total 12288K, used 11734K [0x50020000, 0x50c20000, 0x54020000)
the space 12288K, 95% used [0x50020000, 0x50b95a50, 0x50b95c00, 0x50c20000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x00424000 C:\WINDOWS\system32\javaw.exe
0x7c910000 - 0x7c9c9000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c906000 C:\WINDOWS\system32\kernel32.dll
0x64d00000 - 0x64d31000 C:\Program Files\Alwil Software\Avast5\snxhk.dll
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee3000 C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
0x76320000 - 0x7633d000 C:\WINDOWS\system32\IMM32.DLL
0x10000000 - 0x10016000 C:\Program Files\Fichiers communs\Logitech\LVMVFM\LVPrcInj.dll
0x774a0000 - 0x775de000 C:\WINDOWS\system32\ole32.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x73e30000 - 0x73e34000 C:\WINDOWS\system32\KsUser.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d7f0000 - 0x6da96000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x76ae0000 - 0x76b0f000 C:\WINDOWS\system32\WINMM.dll
0x6d7a0000 - 0x6d7ac000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d320000 - 0x6d33f000 C:\Program Files\Java\jre6\bin\java.dll
0x6d280000 - 0x6d288000 C:\Program Files\Java\jre6\bin\hpi.dll
0x76ba0000 - 0x76bab000 C:\WINDOWS\system32\PSAPI.DLL
0x6d7e0000 - 0x6d7ef000 C:\Program Files\Java\jre6\bin\zip.dll
0x6d000000 - 0x6d14a000 C:\Program Files\Java\jre6\bin\awt.dll
0x72f50000 - 0x72f76000 C:\WINDOWS\system32\WINSPOOL.DRV
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x5b090000 - 0x5b0c8000 C:\WINDOWS\system32\uxtheme.dll
0x6d230000 - 0x6d27f000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x74690000 - 0x746dc000 C:\WINDOWS\system32\MSCTF.dll
0x75140000 - 0x7516e000 C:\WINDOWS\system32\msctfime.ime
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x76960000 - 0x76a16000 C:\WINDOWS\system32\USERENV.dll
0x6fee0000 - 0x6ff35000 C:\WINDOWS\system32\netapi32.dll
0x6d600000 - 0x6d613000 C:\Program Files\Java\jre6\bin\net.dll
0x719f0000 - 0x71a07000 C:\WINDOWS\system32\WS2_32.dll
0x719e0000 - 0x719e8000 C:\WINDOWS\system32\WS2HELP.dll
0x71990000 - 0x719d0000 C:\WINDOWS\System32\mswsock.dll
0x76ed0000 - 0x76ef7000 C:\WINDOWS\system32\DNSAPI.dll
0x76f60000 - 0x76f68000 C:\WINDOWS\System32\winrnr.dll
0x76f10000 - 0x76f3d000 C:\WINDOWS\system32\WLDAP32.dll
0x76f70000 - 0x76f76000 C:\WINDOWS\system32\rasadhlp.dll
0x6d620000 - 0x6d629000 C:\Program Files\Java\jre6\bin\nio.dll
0x03f60000 - 0x03fcb000 C:\Documents and Settings\Utilisateur\Application Data\.minecraft\bin\natives\lwjgl.dll
0x5f070000 - 0x5f13c000 C:\WINDOWS\system32\OPENGL32.dll
0x6cef0000 - 0x6cf11000 C:\WINDOWS\system32\GLU32.dll
0x736b0000 - 0x736fb000 C:\WINDOWS\system32\DDRAW.dll
0x73b10000 - 0x73b16000 C:\WINDOWS\system32\DCIMAN32.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x6d350000 - 0x6d356000 C:\Program Files\Java\jre6\bin\jawt.dll
0x69000000 - 0x694d7000 C:\WINDOWS\system32\atioglxx.dll
0x56690000 - 0x566a3000 C:\Documents and Settings\Utilisateur\Application Data\.minecraft\bin\natives\jinput-dx8.dll
0x6d2d0000 - 0x6d30a000 C:\WINDOWS\system32\DINPUT8.dll
0x68d50000 - 0x68d59000 C:\WINDOWS\system32\HID.DLL
0x778e0000 - 0x779d8000 C:\WINDOWS\system32\SETUPAPI.DLL
0x76be0000 - 0x76c0e000 C:\WINDOWS\system32\WINTRUST.dll
0x779e0000 - 0x77a77000 C:\WINDOWS\system32\CRYPT32.dll
0x77a80000 - 0x77a92000 C:\WINDOWS\system32\MSASN1.dll
0x76c40000 - 0x76c68000 C:\WINDOWS\system32\IMAGEHLP.dll
0x56820000 - 0x56832000 C:\Documents and Settings\Utilisateur\Application Data\.minecraft\bin\natives\jinput-raw.dll
0x62e40000 - 0x62e99000 C:\WINDOWS\system32\hnetcfg.dll
0x719d0000 - 0x719d8000 C:\WINDOWS\System32\wshtcpip.dll
0x6e7c0000 - 0x6e7cf000 C:\Program Files\WIDCOMM\Bluetooth Software\btkeyind.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m -Dsun.java2d.noddraw=true -Dsun.java2d.d3d=false -Dsun.java2d.opengl=false -Dsun.java2d.pmoffscreen=false
java_command: net.minecraft.LauncherFrame
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\program files\java\jre6\bin
USERNAME=Utilisateur
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 14 Stepping 8, GenuineIntel
    Va dans démarrer, panneau de configuration, ajout et suppression, désinstalle tous les --> Java.
    Redémarre le pc, va dans: C\program files , supprime Java
    Ensuite il faut voir les fichiers cachés, donc il faut apporter une modification:
    --> Panneau de configuration, options des dossiers, onglet affichage, coche: afficher les fichiers et dossiers cachés, appliquer et OK.
    Par la suite va supprimer le dossier --> Sun dans ces 2 répertoires:
    --> C\documents and settings\ton nom d'utilisateur\application data
    --> C\documents and settings\all users\application data
    Lance --> CCleaner pour un nettoyage dans windows, applications et régistre.
    Finalement installe la dernière version de --> Java offline
