Probleme proftpd
salut ,
voial j expose mon probléme ,je n arrive aps a me connecter a mon serveur ftp a partir d une machine windows sp1,j utilse mandrake 10(ou est installé proftpd),un routeur qui sert de passerelle.
lorsque je fait ftp://mon adresse.ip pour tester ca me met :
Connected to localhost.
421 Service not available, remote server has closed connection
ftp>
est ce que c est bon?je suis stagiaire donc soyez indulgent je suis novice.
merci de votre aide
ftp>
merci de votre aide
oui j arrive a me connecter depuis tout a l heure je galere pour restreindre l accés ftp ,mais de nouveaux problemes se posent a moi:
-dans ftpusers j ajoute anonymous afin de ne pas permettre l accés ftp ?
-comment mettre un mot de passe +utilisateur?
-je modifie bien le fichier proftpd.conf comme ceci
ServerName "ProFTPD server"
ServerType standalone
DefaultServer on
UseFtpUsers on
# Allow FTP resuming.
# Remember to set to off if you have an incoming ftp for upload.
AllowStoreRestart on
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd).
MaxInstances 30
# Set the user and group under which the server will run.
User nobody
Group nogroup
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
# Normally, we want files to be overwriteable.
<Directory />
AllowOverwrite on
</Directory>
# Needed for NIS.
Persisentpasswd off
<Global>
DefaultRoot ~
AllowOverwrite yes
MaxClients 3
MaxClientsPerHost 1
UseFtpUsers on
AllowForeignAddress on
ServerIdent on "ProFTP Server Ready"
AccessGrantMsg "Bienvenue %u sur le serveur du "
</Global>
# Default root can be used to put users in a chroot environment.
# As an example if you have a user foo and you want to put foo in /home/foo
# chroot environment you would do this:
# DefaultRoot /home/foo foo
#Include /etc/proftpd-anonymous.conf -
J'ai réalisé un post sur la configuration de PROFTPD :
http://www.artduweb.com/unix-linux/proftpd
En espèrant que ça puisse vous aider ! -
c est bon j ai reussi chris mais encore 1 probleme lol ,je cherche a passer le routeur afin de me connecter de l exterieur et non plus en local ,CA MARCHE PAS,j ai bien ouvert les ports du routeur linksis.
une autre question quand je fais ftp localhost il me demande un utilisateur et un mot de passe mais lequel??celui de mon utilisateur? -
comme promis voici ton aide:
Configuration du serveur FTP
Dans le centre de contrôle Mandrake:
-> Assistant serveurs
-> Configurer FTP
suivant
cocher: « activer pour intranet » et « activer pour internet »
cocher: « chroot des utilisateur... » et « autoriser la reprise... »
- Installer: gproftpd-8.1.7-1mdk.i586.rpm
- Dans un terminal taper: $ su
-> password (mot de passe root)
# gproftpd
-> Cliquer sur « yes »
Onglet servers
DNS name or ip... : mon_adresse_IP (fixe evidement. Sinon me redemander de l'aide plus precise sur ce point)
The admin email : jojo@...com
Useradds default root dir : /mnt/... (repertoire par défaut où les nouveaux utilisateurs auront accès en lecture)
Useradds default Upload dir : /mnt/.../Upload (repertoire par defaut où les nouveaux -
Re salut!
etant donné que je suis au taf, je n'ai pas trop le temps de cherhcer l'erreur ou de te guider dans tes demarches. Cependant, des ce soir, je t'envoie le tuto que j'ai fait avec des explications en +. dc arrete de t'arracher les cheveux lol, garde les pour un autre projet.
A ce soir
Chris -
Salut!!!
Pour te conencter à ton ftp, tu peux te connecter soit d'une machine dans le reseau local en marquant l'url: ftp://192.168. etc
soit d'une machine exterieure à ton reseau en ouvrant le port 21 sur ton routeur et en marquant ftp://adresse IP du routeur.
Voila.
PS: oublie pas de verifier que ton serveur ftp est bien en route grace à drakconf/service/demarrage.
A++
