Probleme d'installation Wordpress
Cela fait maintenant quelques jours que je me prends la tête pour essayer d'installer wordpress.
Je me suis référé à plusieurs tutos mais en vain...
Je suis inscrite chez easy hebergement pour bénéficier d'un serveur, nom de domaine, base de données... et j'utilise filezilla en client FTP.
Quand j'ouvre la page wp-admin/install.php, voici ce que j'obtiens :
"ERROR: %s'), $error); ?>
'.__('Already Installed').'
'.__('You appear to have already installed WordPress. To reinstall please clear your old database tables first.').'
');} $php_version = phpversion(); $mysql_version = $wpdb->db_version(); $php_compat = version_compare( $php_version, $required_php_version, '>=' ); $mysql_compat = version_compare( $mysql_version, $required_mysql_version, '>=' ) || file_exists( WP_CONTENT_DIR . '/db.php' ); if ( !$mysql_compat && !$php_compat ) $compat = sprintf( __('You cannot install because WordPress %1$s requires PHP version %2$s or higher and MySQL version %3$s or higher. You are running PHP version %4$s and MySQL version %5$s.'), $wp_version, $required_php_version, $required_mysql_version, $php_version, $mysql_version ); elseif ( !$php_compat ) $compat = sprintf( __('You cannot install because WordPress %1$s requires PHP version %2$s or higher. You are running version %3$s.'), $wp_version, $required_php_version, $php_version ); elseif ( !$mysql_compat ) $compat = sprintf( __('You cannot install because WordPress %1$s requires MySQL version %2$s or higher. You are running version %3$s.'), $wp_version, $required_mysql_version, $mysql_version ); if ( !$mysql_compat || !$php_compat ) { display_header(); die('
' . __('Insufficient Requirements') . '
' . $compat . '
'); } switch($step) { case 0: case 1: // in case people are directly linking to this display_header(); ?>
ReadMe documentation at your leisure. Otherwise, just fill in the information below and you'll be on your way to using the most extendable and powerful personal publishing platform in the world.'), '../readme.html'); ?>
error) ) wp_die($wpdb->error->get_error_message()); display_header(); // Fill in the data we gathered $weblog_title = isset($_POST['weblog_title']) ? stripslashes($_POST['weblog_title']) : ''; $admin_email = isset($_POST['admin_email']) ? stripslashes($_POST['admin_email']) : ''; $public = isset($_POST['blog_public']) ? (int) $_POST['blog_public'] : 0; // check e-mail address $error = false; if (empty($admin_email)) { // TODO: poka-yoke display_setup_form( __('you must provide an e-mail address.') ); $error = true; } else if (!is_email($admin_email)) { // TODO: poka-yoke display_setup_form( __('that isn't a valid e-mail address. E-mail addresses look like: username@example.com') ); $error = true; } if ( $error === false ) { $wpdb->show_errors(); $result = wp_install($weblog_title, 'admin', $admin_email, $public); extract($result, EXTR_SKIP); ?>
	admin
	'. $password .'
'; } echo '
'. $password_message .'
Comment y remédier car je désespère :-( Est-ce qu'il faut activer php dans phpmyadmin ou ca se fait automatiquement ou autre manip????)
Sur Filezilla, j'ai installé wordpress après /www , est-ce la bonne méthode car dans les différents tutos que j'ai consultés, certains disent qu'il faut installer à la racine et d'autres non, je suis perdu à ce niveau là)
Si vous avez besoin d'autres précisions pour m'aider, demandez moi.
  1. le message d'erreur entier :
    ' . $compat . '
    	admin
    	'. $password .'
    '; } echo '
