Problème avec un quizz en java
J'ai programmé un quizz en Java et le code me renvoie cette erreur quand je le lance:
Error java.util.NoSuchElementException: No line found
Est ce que quelqu'un aurait une solution à mon problème?
Voila le InputFile que j'utilise:
5
The possession of more than two sets of chromosomes is termed?
polyploidy
3
Erling Kagge skiied into here alone on January 7, 1993
south pole
2
1997 British band that produced "Tub Thumper"
Chumbawumba
2
Who is the tallest person on record (8 ft. 11 in) that has lived?
Robert Wadlow
3
I am the geometric figure most like a lost parrot
polygon
Et voici mon code:
import java.applet.*;
import java.io.*;
import java.util.Scanner;
public class Trivia extends Applet {
	private String[] questions;
	private String[] answers;
	private int[] values;
	private int score = 0; // Overall score
	private int questionNum = 0; // Track if question 0 - 4
	// Construct the applet
	public Trivia() {
		Scanner inputStream = null;
		int numQuestions = 0;
		try {
			inputStream = new Scanner(new FileInputStream("C:\\trivia.txt"));
			// If we got here, the file was opened
			// Read number of questions
			numQuestions = inputStream.nextInt();
			inputStream.nextLine(); // skip newline
			// Allocate arrays
			questions = new String[numQuestions];
			answers = new String[numQuestions];
			values = new int[numQuestions];
			for (int i = 0; i < numQuestions; i++) {
				questions[i] = inputStream.nextLine();
				answers[i] = inputStream.nextLine();
				values[i] = inputStream.nextInt();
			inputStream.close();
		} catch (Exception e) {
			System.out.println("Error " + e);
			System.exit(0);
	// Returns false if there are no more questions to ask.
	// Otherwise it asks the next question, gets an answer
	// from the user, and displays if the user was correct or not.
	public boolean askNextQuestion() {
		if (questionNum >= questions.length) {
			return false;
		// Show the current question
		System.out.println();
		System.out.println("Question " + questionNum);
		System.out.println(questions[questionNum]);
		Scanner kbd = new Scanner(System.in);
		String guess = kbd.nextLine();
		// Check if the answer is correct or not
		guess = guess.toLowerCase();
		if (guess.equals(answers[questionNum].toLowerCase())) {
			System.out.println("That is correct!");
			score += values[questionNum];
		} else {
			System.out.println("Wrong. The correct answer is "
					+ answers[questionNum]);
		// Go to next question
		questionNum++;
		return true;
	// Displays current score
	public void showScore() {
		System.out.println("Your score is " + score);
	public static void main(String[] args) {
		Trivia t = new Trivia();
		while (t.askNextQuestion()) {
			t.showScore();
		System.out.println("Game over! Thanks for playing!");
	public String getAppletInfo() {
		return "Applet Information";
	// Get parameter info
	public String[][] getParameterInfo() {
		return null;
Merci d'avance
Faquaral
Configuration: Windows Vista
Firefox 3.0.8
  1. Oui, ça je m'en doutai. Mais mon problème c'est de savoir ce que mon programme essaie de chercher dans mon fichier et ne trouve pas...
    1. java.util.NoSuchElementException est une ligne qui n'existe pas dans ton fichier
      "no line found" ligne non trouvée
