GUITAR PRO 5 PROBLEM
hi,
I have a problem with gp5, I installed and uninstall it several times thinking there might be a problem with the installation. Actually, I have no sound when I load a score. I have enabled the MIDI (RSE) and installed the RSE sound banks properly, but nothing works; if anyone knows the trick to get this damned software to work, that would be great, especially since with version 5 I can no longer reinstall version 4 (I also get error messages (address problem)).
Thanks for a little help for a desperate guitarist!!!!
  1. Hi!
    Well, it seems I’m not the only one to receive messages like "GP5.exe address violation" or "floating-point operation incorrect."
    I’ve searched everywhere to resolve this issue; I should note that I’m using version 5.2 and I also attempted to reinstall but without success.
    I contacted Guitar Pro support; they asked me to download Guitar Pro from their site. What’s the point if you already have the CD?
    I’d like to know if it’s a registry problem. Since my virus infection, I’ve had to clean some registry entries a bit too aggressively, like "help and support, machine debug" (something like that).
    It’s very frustrating; I can’t work on my compositions anymore, whether it’s the keyboard, the guitar, the bass, or the drums!
    So, is there a savior among us?
    1. Hello,
      Actually I cannot help you I have never had this problem because I hacked gp5 ^^
      But I support you and encourage you to find a solution !!
      Best regards, makeuh
      1. I hacked it too and yet I have the same problem
