Samsung TV and Home Cinema connection issue
tropique62 Posted messages 9 Status Member -
 Vraux -
Hello,
I know there are already a lot of questions on the topic, but I'm losing my mind...
I have a FULL HD LCD TV series 6 LE40A626 SAMSUNG, and I just bought a SAMSUNG digital HOME CINEMA HT-A100, but I can't get the sound from the Home Cinema when I'm watching TV; either I have the sound from the TV speakers, or there's no sound at all. (I do have sound from the Home Cinema for CDs and DVDs), and there is no PERITEL on the Home Cinema.
I assume that with this Home Cinema, the supplied HDMI cable is 1.3.
On the Home Cinema, I have connected the HDMI cable and then 2 RCA audio cables (1 white and 1 red) to the AUX IN 2 port.
The problem lies with the TV since there are 3 HDMI ports:
HDMI IN 2
HDMI IN 1 below
HDMI IN 3 on the side
And there are also 4 audio cable connection options:
DVI IN (HDMI 2) at the back
AUDIO OUT at the back
Another one in a COMPONENT IN block at the back
1 more on the side.
I have tried a lot of possible combinations and I can't get the sound from the TV channels through the Home Cinema.
Do I need to use a SCART connection?? I don't know what to do anymore... if you have a diagram, I would appreciate it.
Thank you in advance.
Configuration: Windows 2000 Internet Explorer 6.0
  1. joule974
    It's all good, it works...
    You're actually missing an audio cable with 2 inputs (red and white) that needs to be purchased separately as it's not included with the home theater.
    You'll need to connect the TV to the home theater using this cable by utilizing the AUX 2 inputs.
    To get sound on the TV, press AUX several times until AUX2 is activated.
    Don't forget to turn on the home theater sound.
    If it works, it's also recommended to mute the TV sound to only have the home theater sound. This avoids the echo effect.
    Hoping this will help you.
    24
    1. catou
      Hello, no need to buy any more cables. I tried several connections, and for a few days it wasn't working. You just need to plug the red and white cable into AUDIO OUT on the back of the TV, then on the home cinema remote press DVD RECEIVER, then AUX, go to AUX 2, and it should work properly. Plus, you have the option to adjust either the TV or the Home Cinema for the sound. Be careful, if you have ANYNET+ you need to disable it to use the audio cinema remote. Good luck!
    2. buzette > catou
      Hello, and thank you for me it finally works.......
