How does the wii battery charger work
bonemine06 Posted messages 1 Status Member -
 elexa18 -
Hello,
yesterday I bought the charger for 2 Wiimote batteries, I have a problem how to know if the batteries are charged and one controller blinks in one way and the other in another.
  1. Jay' Posted messages 9 Status Member 77
    The trick you do first to see if they are charged is you turn on your console and press the home button on your Wiimote. Then you look at the bottom of the displayed screen and check if they are charged; if yes, great, if not, the trick you do is when you place them on the charging dock, wedge them with paper so that they properly touch the back dock. Then, if it blinks, it's often because it's either done or it's not charging properly, hence the solution of the wedge.
    See you later
    52
    1. mel08
      Unplug your console a bit and go do some dictation.
      6
    2. titeuf
      He has the right to make mistakes!!! We don't break someone like that and anyway, I don't think he sees it was done in 2008...-_-'
      2
