Camera issue on liberticam web
Solved
talking67
Posted messages
17
Status
Member
stephane97440 -
stephane97440 -
Hello,
I wanted to go on a site called liberticam. I logged in, but I can't display the cams of other members. They can see my cam, I did everything after requests on the site, but I still can't. Yet I took an allopasse. I don't know if there is software to fix all this. Thank you in advance.
Comme toi, je n'arrive pas à ouvrir les cams des membres sur Liberticam. Tu as la solution ? Merci.
Good evening Talking,
You need to tell us more about your problem. Have you been able to display at least one cam on www.liberticam.com? How much RAM does your PC have? Do you see any error when you try to open the cams? What is your connection like? High speed, low speed? Do you have a firewall that might be blocking certain ports? -
Yes, just a camera and also when I click on a camera, it rotates but it doesn't display due to the firewall issue. I don't know, I have an antivirus; I don't know if the answer could help. Thank you.
Hello
I would like to say that I have an account on LibertyCam since I updated IE it tells me:
Internet Explorer has closed this webpage to protect the computer
Due to a malicious or malfunctioning add-on, Internet Explorer had to close this webpage
What should I do my configuration
OS: Windows XP Pro SP3
Memory: 2047 MB
"All my components are up to date" including my webcam!
Thank you for replying. -
Hello, I have a problem with Liberticam. I also have an MSI laptop. I've tried everything to display my camera and nothing works; however, I can see others and hear them, but no one can see me. I've changed webcams, installed Splitcam, and still nothing. My computer is XP with 2048MB of RAM and uses Internet Explorer 7. My updates are done, and it still doesn't work. My camera starts up but freezes! Please help me solve this problem. Thank you.
Good evening, I find it unfortunate that on this site the abuse of power by certain moderators. It's always the same ones who insult for free and the only solution is to punish us. Please sort out some of your moderators, thank you.
I go to the Stickam site and it works very well, I can open several cams.
So if you've already managed to display at least one webcam (and see the person), then the issue is likely hardware-related; you must have an old PC or a laptop that lacks memory (RAM). On https://www.liberticam.com/, you need at least 256MB of RAM (and that's just the minimum) because the video is very high performance, and you'll see (if you manage to) that the webcams are very smooth.
Otherwise, try disabling your antivirus. -
Who can tell me why? I've been using Liberticam for a long time, and now when I turn on my camera, my computer shuts down. Why? What should I do? Thank you.
