Grayed-out power management mode
rintintin
GodRage Posted messages 25 Status Member -
Hello,
The power management settings are grayed out, so it's impossible to configure them.
How can I restore these fields to active status?
Thank you
With reference to this discussion
Thank you
Configuration: Windows XP Firefox 2.0.0.9
1 answer
If the tab is active but its content is greyed out, then do this:
(click) Start
(click) Run
(type) cmd
(click) OK
(type) powercfg /RestoreDefaultPolicies
(press) Enter
And the problem is solved.
More details on Microsoft's page: https://support.microsoft.com/fr-fr/help/913622
I allow myself to respond to this "old" unanswered topic because while searching for "Empty power management modes" on Google, I stumbled upon it. :) It turns out the problem is still relevant xD
(click) Start
(click) Run
(type) cmd
(click) OK
(press) Enter
