I’m having a wifi connection problem on my iPad when I go to
Gllgz Posted messages 3 Registration date   Status Member Last intervention   -
Didi64_549 Posted messages 2906 Registration date   Status Member Last intervention   -
In the wi-fi settings I can connect to the network, but after a few moments the "no internet" message appears even though internet is working for all other devices; at the top the wi-fi connection does not show. What can I do?
1 answer
  1. Didi64_549 Posted messages 2906 Registration date   Status Member Last intervention
    Hello,
    This indicates a local issue with the iPad and not the network.
    A bug in the Wi‑Fi interface can occur after an update.
    Your IP address is poorly allocated by the Box.
    A network conflict such as a repeater, etc....
    You can, in a first step, forget the Wi‑Fi network and then reconnect by retyping the password.
    You should try forcing a restart of the iPad so it reinitializes the network modules without erasing data, and if nothing changes, reset the network settings as well.
    Then see if the Wi‑Fi works again.
