Laptop power supply issue, voltage drop
Squidos Posted messages 3 Status Member -
Hello, when I plug in my laptop charger, I hear a small 'tick' coming from the connector and nothing happens, the battery does not charge and the laptop does not turn on. Curious, I measured the voltage of the power supply when it is not connected to the laptop and I have the correct 19V, then when I plug the power supply into the laptop connector and check the voltage at the pins of the laptop connector, I only get about 0.3V. I then unplugged the power supply from the laptop and when I measure the voltage on it again, I still get 0.3V at the connector of the power supply. I have to unplug the power supply from the wall outlet and plug it back in to get 19V again. Do you think it is a problem with the power supply or with my laptop that might have a short circuit causing this phenomenon? Thank you for any responses.
1 answer
  1. Panth33ra Posted messages 23245 Registration date   Status Member Last intervention   Ambassador 2 363
    Hello,
    Is this a recent laptop?
    1. Squidos Posted messages 3 Status Member
      I would say he is about 6 years old.
      1. Panth33ra Posted messages 23245 Registration date   Status Member Last intervention   2 363 > Squidos Posted messages 3 Status Member
        You should check the battery and its charger.
      2. Squidos Posted messages 3 Status Member > Panth33ra Posted messages 23245 Registration date   Status Member Last intervention
        How to verify them?
