Unreal Engine 5: problema de empaquetado
Hola, estoy intentando empaquetar mi proyecto, ¡pero tengo un pequeño / gran problema durante este proceso!
Estoy recibiendo errores que he intentado resolver sin éxito hasta ahora. Aquí está el archivo de registro, ¿podrías ayudarme, por favor?
LogStats: Stats thread started at 0.287547 LogPluginManager: Display: By default, prioritizing project plugin (H:/prog/GameExample/Plugins/Marketplace/AutoFootstep/AutoFootstep.uplugin) over the corresponding engine version (../../../Engine/Plugins/Marketplace/AutoFootstep/AutoFootstep.uplugin). LogPluginManager: Display: By default, prioritizing project plugin (H:/prog/GameExample/Plugins/Marketplace/SurfaceFootstepSystem/SurfaceFootstepSystem.uplugin) over the corresponding engine version (../../../Engine/Plugins/Marketplace/SurfaceFootstepSystem/SurfaceFootstepSystem.uplugin). LogPluginManager: Display: By default, prioritizing project plugin (H:/prog/GameExample/Plugins/Marketplace/DialogueTreeBuild/DialogueTree.uplugin) over the corresponding engine version (../../../Engine/Plugins/Marketplace/DialogueTreeBuild/DialogueTree.uplugin). LogPluginManager: Display: By default, prioritizing project plugin (H:/prog/GameExample/Plugins/Marketplace/Convai/ConvAI.uplugin) over the corresponding engine version (../../../Engine/Plugins/Marketplace/Convai/ConvAI.uplugin). LogICUInternationalization: ICU TimeZone Detection - Raw Offset: +1:00, Platform Override: '' LogInit: Session CrashGUID >==================================================== Session CrashGUID > UECC-Windows-E0032862458E03137E5CF2985F6417F5 Session CrashGUID >==================================================== LogConfig: Display: Loading Mac ini files took 0.03 seconds LogConfig: Display: Loading VulkanPC ini files took 0.03 seconds LogConfig: Display: Loading IOS ini files took 0.03 seconds LogConfig: Display: Loading Android ini files took 0.04 seconds LogConfig: Display: Loading Windows ini files took 0.04 seconds LogConfig: Display: Loading Unix ini files took 0.04 seconds LogConfig: Display: Loading TVOS ini files took 0.05 seconds LogConfig: Display: Loading Linux ini files took 0.05 seconds LogConfig: Display: Loading LinuxArm64 ini files took 0.05 seconds LogPluginManager: Mounting Engine plugin Bridge LogPluginManager: Mounting Engine plugin FastBuildController LogPluginManager: Mounting Engine plugin MeshPainting LogPluginManager: Mounting Engine plugin EnhancedInput LogPluginManager: Found config from plugin[EnhancedInput] Input LogPluginManager: Mounting Engine plugin TraceUtilities LogPluginManager: Mounting Engine plugin XGEController LogPluginManager: Mounting Engine plugin GameplayCameras LogPluginManager: Mounting Engine plugin Paper2D LogPluginManager: Mounting Engine plugin CameraShakePreviewer LogPluginManager: Mounting Engine plugin AssetManagerEditor LogPluginManager: Mounting Engine plugin BlueprintMaterialTextureNodes LogPluginManager: Mounting Engine plugin CryptoKeys LogPluginManager: Mounting Engine plugin BlueprintHeaderView LogPluginManager: Mounting Engine plugin CurveEditorTools LogPluginManager: Mounting Engine plugin EditorDebugTools LogPluginManager: Mounting Engine plugin DataValidation LogPluginManager: Mounting Engine plugin EngineAssetDefinitions LogPluginManager: Mounting Engine plugin ChangelistReview LogPluginManager: Mounting Engine plugin GeometryMode LogPluginManager: Mounting Engine plugin MaterialAnalyzer LogPluginManager: Mounting Engine plugin FacialAnimation LogPluginManager: Mounting Engine plugin EditorScriptingUtilities LogPluginManager: Mounting Engine plugin ModelingToolsEditorMode LogPluginManager: Mounting Engine plugin SequencerAnimTools LogPluginManager: Mounting Engine plugin PluginBrowser LogPluginManager: Mounting Engine plugin MacGraphicsSwitching LogPluginManager: Mounting engine plugin UVEditor LogPluginManager: Mounting Project plugin AutoFootstep LogPluginManager: Mounting Engine plugin SpeedTreeImporter LogPluginManager: Mounting Project plugin DialogueTree LogPluginManager: Mounting Project plugin ConvAI LogPluginManager: Mounting Engine plugin WorldPartitionHLODUtilities LogPluginManager: Mounting Project plugin SurfaceFootstepSystem LogPluginManager: Mounting Engine plugin GameplayTagsEditor LogPluginManager: Mounting Engine plugin AISupport LogPluginManager: Mounting Engine plugin ACLPlugin LogPluginManager: Mounting Engine plugin AnimationData LogPluginManager: Mounting Engine plugin OodleNetwork LogPluginManager: Mounting Engine plugin AnimationModifierLibrary LogPluginManager: Mounting Engine plugin EnvironmentQueryEditor LogPluginManager: Mounting Engine plugin ControlRig LogPluginManager: Mounting Engine plugin ControlRigSpline LogPluginManager: Mounting Engine plugin DeformerGraph LogPluginManager: Mounting Engine plugin MobileLauncherProfileWizard LogPluginManager: Mounting Engine plugin RigLogic LogPluginManager: Mounting Engine plugin LiveLink LogPluginManager: Mounting Engine plugin IKRig LogPluginManager: Mounting Engine plugin BlendSpaceMotionAnalysis LogPluginManager: Mounting Engine plugin GitSourceControl LogPluginManager: Mounting Engine plugin DumpGPUServices LogPluginManager: Mounting Engine plugin KDevelopSourceCodeAccess LogPluginManager: Mounting Engine plugin N10XSourceCodeAccess LogPluginManager: Mounting Engine plugin PixWinPlugin LogPluginManager: Mounting Engine plugin PlasticSourceControl LogPluginManager: Mounting Engine plugin PerforceSourceControl LogPluginManager: Mounting Engine plugin NullSourceCodeAccess LogPluginManager: Mounting Engine plugin CodeLiteSourceCodeAccess LogPluginManager: Mounting Engine plugin RenderDocPlugin LogPluginManager: Mounting Engine plugin SubversionSourceControl LogPluginManager: Mounting Engine plugin RiderSourceCodeAccess LogPluginManager: Mounting Engine plugin PropertyAccessNode LogPluginManager: Mounting Engine plugin TraceDataFilters LogPluginManager: Mounting Engine plugin VisualStudioCodeSourceCodeAccess LogPluginManager: Mounting Engine plugin TextureFormatOodle LogPluginManager: Mounting Engine plugin PluginUtils LogPluginManager: Mounting Engine plugin VisualStudioSourceCodeAccess LogPluginManager: Mounting Engine plugin XCodeSourceCodeAccess LogPluginManager: Mounting Engine plugin UObjectPlugin LogPluginManager: Mounting Engine plugin AutomationUtils LogPluginManager: Mounting Engine plugin ChaosCaching LogPluginManager: Mounting Engine plugin AnimationSharing LogPluginManager: Mounting Engine plugin CLionSourceCodeAccess LogPluginManager: Mounting Engine plugin ChaosClothEditor LogPluginManager: Mounting Engine plugin ChaosCloth LogPluginManager: Mounting Engine plugin BackChannel LogPluginManager: Mounting Engine plugin ChaosUserDataPT LogPluginManager: Mounting Engine plugin ChaosNiagara LogPluginManager: Mounting Engine plugin ChaosSolverPlugin LogPluginManager: Mounting Engine plugin CharacterAI LogPluginManager: Mounting Engine plugin Takes LogPluginManager: Mounting Engine plugin ChaosEditor LogPluginManager: Mounting Engine plugin Dataflow LogPluginManager: Mounting Engine plugin Fracture LogPluginManager: Mounting Engine plugin FullBodyIK LogPluginManager: Mounting Engine plugin GeometryFlow LogPluginManager: Mounting Engine plugin Landmass LogPluginManager: Mounting Engine plugin GeometryCollectionPlugin LogPluginManager: Mounting Engine plugin LiveLinkControlRig LogPluginManager: Mounting Engine plugin ChaosVehiclesPlugin LogPluginManager: Mounting Engine plugin OpenImageDenoise LogPluginManager: Mounting Engine plugin MeshModelingToolsetExp LogPluginManager: Mounting Engine plugin MeshLODToolset LogPluginManager: Mounting Engine plugin PlatformCrypto LogPluginManager: Mounting Engine plugin PlanarCut LogPluginManager: Mounting Engine plugin LocalizableMessage LogPluginManager: Mounting Engine plugin PythonScriptPlugin LogPluginManager: Mounting Engine plugin StructUtils LogPluginManager: Mounting Engine plugin SkeletalReduction LogPluginManager: Mounting Engine plugin ToolPresets LogPluginManager: Mounting Engine plugin Water LogPluginManager: Mounting Engine plugin ProxyLODPlugin LogPluginManager: Mounting Engine plugin DatasmithContent LogPluginManager: Mounting Engine plugin VariantManager LogPluginManager: Mounting Engine plugin GLTFExporter LogPluginManager: Mounting Engine plugin InterchangeEditor LogPluginManager: Mounting Engine plugin Interchange LogPluginManager: Mounting Engine plugin UdpMessaging LogPluginManager: Mounting Engine plugin TcpMessaging LogPluginManager: Mounting Engine plugin ActorSequence LogPluginManager: Mounting Engine plugin LevelSequenceEditor LogPluginManager: Mounting Engine plugin SequencerScripting LogPluginManager: Mounting Engine plugin TemplateSequence LogPluginManager: Mounting Engine plugin AlembicImporter LogPluginManager: Mounting Engine plugin Niagara LogPluginManager: Mounting Engine plugin AndroidMedia LogPluginManager: Mounting Engine plugin AvfMedia LogPluginManager: Mounting Engine plugin MediaCompositing LogPluginManager: Mounting Engine plugin MediaPlate LogPluginManager: Mounting Engine plugin MediaPlayerEditor LogPluginManager: Mounting Engine plugin WebMMedia LogPluginManager: Mounting Engine plugin WmfMedia LogPluginManager: Mounting Engine plugin ImgMedia LogPluginManager: Mounting Engine plugin VariantManagerContent LogPluginManager: Mounting Engine plugin OnlineBase LogPluginManager: Mounting Engine plugin OnlineServices LogPluginManager: Mounting Engine plugin OnlineSubsystem LogPluginManager: Mounting Engine plugin OnlineSubsystemNull LogPluginManager: Mounting Engine plugin AndroidFileServer LogPluginManager: Mounting Engine plugin AndroidMoviePlayer LogPluginManager: Mounting Engine plugin OnlineSubsystemUtils LogPluginManager: Mounting Engine plugin AppleMoviePlayer LogPluginManager: Mounting Engine plugin AppleImageUtils LogPluginManager: Mounting Engine plugin AndroidPermission LogPluginManager: Mounting Engine plugin ArchVisCharacter LogPluginManager: Mounting Engine plugin AssetTags LogPluginManager: Mounting Engine plugin AudioWidgets LogPluginManager: Mounting Engine plugin AudioSynesthesia LogPluginManager: Mounting Engine plugin ChunkDownloader LogPluginManager: Mounting Engine plugin ComputeFramework LogPluginManager: Mounting Engine plugin CableComponent LogPluginManager: Mounting Engine plugin CustomMeshComponent LogPluginManager: Mounting Engine plugin ExampleDeviceProfileSelector LogPluginManager: Mounting Engine plugin GeometryCache LogPluginManager: Mounting Engine plugin GeometryProcessing LogPluginManager: Mounting Engine plugin GoogleCloudMessaging LogPluginManager: Mounting Engine plugin GooglePAD LogPluginManager: Mounting Engine plugin AudioCapture LogPluginManager: Mounting Engine plugin InputDebugging LogPluginManager: Found config from plugin[InputDebugging] Input LogPluginManager: Mounting Engine plugin LinuxDeviceProfileSelector LogPluginManager: Mounting Engine plugin IOSDeviceProfileSelector LogPluginManager: Mounting Engine plugin ActorLayerUtilities LogPluginManager: Mounting Engine plugin LocationServicesBPLibrary LogPluginManager: Mounting Engine plugin Metasound LogPluginManager: Mounting Engine plugin MeshModelingToolset LogPluginManager: Mounting Engine plugin MobilePatchingUtils LogPluginManager: Mounting Engine plugin MsQuic LogPluginManager: Mounting Engine plugin ProceduralMeshComponent LogPluginManager: Mounting Engine plugin PropertyAccessEditor LogPluginManager: Mounting Engine plugin RigVM LogPluginManager: Mounting Engine plugin SignificanceManager LogPluginManager: Mounting Engine plugin SoundFields LogPluginManager: Mounting Engine plugin ResonanceAudio LogPluginManager: Mounting Engine plugin HairStrands LogPluginManager: Mounting Engine plugin Synthesis LogPluginManager: Mounting Engine plugin SunPosition LogPluginManager: Mounting Engine plugin AndroidDeviceProfileSelector LogPluginManager: Mounting Engine plugin WaveTable LogPluginManager: Mounting Engine plugin WebMMoviePlayer LogPluginManager: Mounting Engine plugin WindowsDeviceProfileSelector LogPluginManager: Mounting Engine plugin InterchangeTests LogPluginManager: Mounting Engine plugin LauncherChunkInstaller LogPluginManager: Mounting Engine plugin WindowsMoviePlayer LogPluginManager: Mounting Engine plugin XRBase LogPluginManager: Mounting Engine plugin ContentBrowserAssetDataSource LogPluginManager: Mounting Engine plugin ContentBrowserFileDataSource LogPluginManager: Mounting Engine plugin ContentBrowserClassDataSource LogPluginManager: Mounting Engine plugin PortableObjectFileDataSource LogPluginManager: Mounting Engine plugin ConcertMain LogPluginManager: Mounting Engine plugin OnlineSubsystemGooglePlay LogPluginManager: Mounting Engine plugin ARUtilities LogPluginManager: Mounting Engine plugin ObjectMixer LogPluginManager: Mounting Engine plugin OnlineSubsystemIOS LogPluginManager: Mounting Engine plugin LightMixer LogPluginManager: Mounting Engine plugin SQLiteCore LogPluginManager: Mounting Engine plugin AppleARKitFaceSupport LogPluginManager: Mounting Engine plugin ConcertSyncCore LogPluginManager: Mounting Engine plugin AppleARKit LogPluginManager: Mounting Engine plugin ConcertSyncClient LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Bridge/Content/' mounted to '/Bridge/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/TraceUtilities/Content/' mounted to '/TraceUtilities/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/2D/Paper2D/Content/' mounted to '/Paper2D/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/BlueprintHeaderView/Content/' mounted to '/BlueprintHeaderView/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/GeometryMode/Content/' mounted to '/GeometryMode/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/ModelingToolsEditorMode/Content/' mounted to '/ModelingToolsEditorMode/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/UVEditor/Content/' mounted to '/UVEditor/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/SpeedTreeImporter/Content/' mounted to '/SpeedTreeImporter/' LogPackageName: Display: FPackageName: Mount point added: 'H:/prog/GameExample/Plugins/Marketplace/DialogueTreeBuild/Content/' mounted to '/DialogueTree/' LogPackageName: Display: FPackageName: Mount point added: 'H:/prog/GameExample/Plugins/Marketplace/Convai/Content/' mounted to '/ConvAI/' LogPackageName: Display: FPackageName: Mount point added: 'H:/prog/GameExample/Plugins/Marketplace/SurfaceFootstepSystem/Content/' mounted to '/SurfaceFootstepSystem/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Animation/ACLPlugin/Content/' mounted to '/ACLPlugin/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Animation/ControlRig/Content/' mounted to '/ControlRig/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Animation/ControlRigSpline/Content/' mounted to '/ControlRigSpline/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Animation/DeformerGraph/Content/' mounted to '/DeformerGraph/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Animation/RigLogic/Content/' mounted to '/RigLogic/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Animation/IKRig/Content/' mounted to '/IKRig/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosCaching/Content/' mounted to '/ChaosCaching/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Developer/AnimationSharing/Content/' mounted to '/AnimationSharing/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosClothEditor/Content/' mounted to '/ChaosClothEditor/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosNiagara/Content/' mounted to '/ChaosNiagara/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosSolverPlugin/Content/' mounted to '/ChaosSolverPlugin/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/VirtualProduction/Takes/Content/' mounted to '/Takes/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/Dataflow/Content/' mounted to '/Dataflow/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/FullBodyIK/Content/' mounted to '/FullBodyIK/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/GeometryFlow/Content/' mounted to '/GeometryFlow/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/Landmass/Content/' mounted to '/Landmass/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/GeometryCollectionPlugin/Content/' mounted to '/GeometryCollectionPlugin/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ChaosVehiclesPlugin/Content/' mounted to '/ChaosVehiclesPlugin/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/MeshModelingToolsetExp/Content/' mounted to '/MeshModelingToolsetExp/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/MeshLODToolset/Content/' mounted to '/MeshLODToolset/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/PythonScriptPlugin/Content/' mounted to '/PythonScriptPlugin/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/ToolPresets/Content/' mounted to '/ToolPresets/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Experimental/Water/Content/' mounted to '/Water/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Enterprise/DatasmithContent/Content/' mounted to '/DatasmithContent/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Enterprise/GLTFExporter/Content/' mounted to '/GLTFExporter/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Interchange/Runtime/Content/' mounted to '/Interchange/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/MovieScene/SequencerScripting/Content/' mounted to '/SequencerScripting/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/FX/Niagara/Content/' mounted to '/Niagara/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Media/MediaCompositing/Content/' mounted to '/MediaCompositing/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Media/MediaPlate/Content/' mounted to '/MediaPlate/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/AudioWidgets/Content/' mounted to '/AudioWidgets/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/AudioSynesthesia/Content/' mounted to '/AudioSynesthesia/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/GeometryProcessing/Content/' mounted to '/GeometryProcessing/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/Metasound/Content/' mounted to '/Metasound/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/MeshModelingToolset/Content/' mounted to '/MeshModelingToolset/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/RigVM/Content/' mounted to '/RigVM/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/ResonanceAudio/Content/' mounted to '/ResonanceAudio/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/HairStrands/Content/' mounted to '/HairStrands/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/Synthesis/Content/' mounted to '/Synthesis/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/SunPosition/Content/' mounted to '/SunPosition/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/WaveTable/Content/' mounted to '/WaveTable/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/AR/ARUtilities/Content/' mounted to '/ARUtilities/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/ObjectMixer/ObjectMixer/Content/' mounted to '/ObjectMixer/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Editor/ObjectMixer/LightMixer/Content/' mounted to '/LightMixer/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/AR/AppleAR/AppleARKitFaceSupport/Content/' mounted to '/AppleARKitFaceSupport/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Runtime/AR/AppleAR/AppleARKit/Content/' mounted to '/AppleARKit/' LogPackageName: Display: FPackageName: Mount point added: '../../Plugins/Developer/Concert/ConcertSync/ConcertSyncClient/Content/' mounted to '/ConcertSyncClient/' SourceControl: Revision control is disabled SourceControl: Revision control is disabled SourceControl: Revision control is disabled LogWindows: Failed to load 'WinPixGpuCapturer.dll' (GetLastError=126) LogWindows: File 'WinPixGpuCapturer.dll' does not exist PixWinPlugin: PIX capture plugin failed to initialize! Check that the process is launched from PIX. LogConfig: Applying CVar settings from Section [/Script/RenderDocPlugin.RenderDocPluginSettings] File [Engine] RenderDocPlugin: Display: RenderDoc plugin will not be loaded. Use '-AttachRenderDoc' on the cmd line or enable 'renderdoc.AutoAttach' in the plugin settings. LogInit: Using libcurl 8.4.0 LogInit: - built for Windows LogInit: - supports SSL with OpenSSL/1.1.1t LogInit: - supports HTTP deflate (compression) using libz 1.2.13 LogInit: - other features: LogInit: CURL_VERSION_SSL LogInit: CURL_VERSION_LIBZ LogInit: CURL_VERSION_IPV6 LogInit: CURL_VERSION_ASYNCHDNS LogInit: CURL_VERSION_LARGEFILE LogInit: CurlRequestOptions (configurable via config and command line): LogInit: - bVerifyPeer = true - Libcurl will verify peer
1 respuesta
Hola,
Este error parece problemático:
UATHelper: Packaging (Windows): Platform Win64 no es una plataforma válida para construir. Verifica que el SDK esté instalado correctamente.Quizás esta discusión te ayude.
Buena suerte
