How to find the star key on an AZERTY keyboard?
Youssoufa -
Jojolaguitare Posted messages 12012 Registration date   Status Membre Last intervention   -
Hello,
how to find the star key on the AZERTY keyboard on Windows 10?
brucine Posted messages 24378 Registration date   Status Membre Last intervention   4 093
Hello,
The key is integrated into all AZERTY keyboards, not necessarily in the same place depending on whether the AZERTY is French, Belgian....
Some laptop keyboards may have specific layouts in this regard, although I doubt it.
On a standard 105-key French AZERTY keyboard, it is located above the right Shift key and also above the numeric keypad when there is one.
If your keyboard is unusual, without seeing an image...
Jojolaguitare Posted messages 12012 Registration date   Status Membre Last intervention   2 781
Hello.
As it is a character that is rarely used, hold down the Alt key and type the numeric keys 4 and 2. This gives *
A + . . .
Hello,
Besides the fact that I do use it fairly regularly (generic search character, batches...), back to square one, what is special about this keyboard?
If it doesn't have a numeric keypad, no ALT-42 or anything like that.
Jojolaguitare Posted messages 12012 Registration date   Status Membre Last intervention   2 781 > brucine Posted messages 24378 Registration date   Status Membre Last intervention
Hello.
My bad. I had forgotten that assumption!
We just have to wait for the correct information about this keyboard.
See you later . . .
