Philips 42PFL8404H/12 TV Power Cable Issue
baladur13 Posted messages 47322 Registration date Status Moderator Last intervention -
Hello everyone, I'm reaching out because I need your help. My Philips television 42PFL8404H/12 has a problem, I can't find any information online, which is why I'm turning to this forum. In fact, the cable connecting the power board to the socket for the external power cable, which is a C7 cable, has broken, as you can see in the images; the two metal prongs that connect inside the C7 socket are broken. I'm therefore asking you if you know the name of this cable, as I cannot find any information. Thank you very much for your help.
Best regards, Paul
Hello, you just need to change the socket and re-solder the wires on it, but first, we need to know why it broke, whether the socket melted or if it was just due to physical stress.
Hello,
This type of soldering plug should work
https://www.amazon.fr/AERZETIX-connecteurs-dalimentation-bi-p%C3%B4le-polaris%C3%A9/dp/B07Z3FVFTF
Very difficult to catch a black cat in a dark room.
Especially when it's not there... -
I think she went through a shock, but the thing is I tried to solder the metal rods onto the cable, but it didn't hold????
