Philips 42PFL8404H/12 TV Power Cable Issue
Paulo_2004 Posted messages 5 Status Member -
baladur13 Posted messages 47419 Registration date   Status Moderator Last intervention   -
Hello everyone, I'm reaching out because I need your help. My Philips television 42PFL8404H/12 has a problem, I can't find any information online, which is why I'm turning to this forum. In fact, the cable connecting the power board to the socket for the external power cable, which is a C7 cable, has broken, as you can see in the images; the two metal prongs that connect inside the C7 socket are broken. I'm therefore asking you if you know the name of this cable, as I cannot find any information. Thank you very much for your help.
Best regards, Paul
Socket where the two metal prongs come out
  1. Kcaouette
    Hello, you just need to change the socket and re-solder the wires on it, but first, we need to know why it broke, whether the socket melted or if it was just due to physical stress.
  2. Paulo_2004 Posted messages 5 Status Member
    I think she went through a shock, but the thing is I tried to solder the metal rods onto the cable, but it didn't hold????
    1. baladur13 Posted messages 47419 Registration date   Status Moderator Last intervention   14 417
      If the wires have trouble soldering, then you will need to go through a "sugar" and a small piece of electrical wire, which will need to be soldered onto the new connector.
      1. Paulo_2004 Posted messages 5 Status Member > baladur13 Posted messages 47419 Registration date   Status Moderator Last intervention
        Thanks for the advice, I tried adding some sugar but that doesn't work either ;(
    2. Kcaouette
      You first need to heat the metal of the rods sufficiently and then apply the tin; it should melt instantly upon contact with the heated piece and not upon contact with the soldering iron tip.
      1. Paulo_2004 Posted messages 5 Status Member > Kcaouette
        Thank you for the advice but I tried in vain ;( I really wish I could buy this part again but it's nowhere to be found because I don't know its name ;(((
      2. baladur13 Posted messages 47419 Registration date   Status Moderator Last intervention   14 417 > Paulo_2004 Posted messages 5 Status Member
        How can it be impossible to find? The input given in message #2 seems to be exactly the same to me.
