Network connection issue with Realtek RTL8723BE Wireless LAN 802.11n PCI-E NIC
Solved/Closed
Nawii_ Posted messages 1 Status Member -
 Cam -
Good evening,
Since yesterday, I can no longer detect any Wi-Fi network. I went to check the network devices and it seems that there is a problem with the Realtek RTL8723BE Wireless LAN 802.11n PCI-E NIC. I have uninstalled/reinstalled the device, tried to make the necessary updates but nothing changes ... Could you help me? I think I need to reinstall a driver but I don’t know which one or how to do it ... Thank you for your response! I am using Windows 10 and I have an Asus.
  1. kaneagle Posted messages 86301 Registration date   Status Moderator Last intervention   14 692
    Hello,
    Download and install --> 7Zip 64 bits
    Download this driver --> Realtek
    Right-click on --> WLAN_Realtek_Win10_64_VER2023554152017.zip
    Select --> 7Zip
    Choose --> extract to "WLAN_Realtek_Win10_64_VER2023554152017\"
    Go to Device Manager
    Right-click on the Realtek RTL8723BE Wireless
    Update driver
    Browse my computer ......
    Choose from a list of drivers...
    Have Disk
    Browse
    Go to the unzipped driver folder --> WLAN_Realtek_Win10_64_VER2023554152017
    Folder --> RTWLANE_Driver
    Folder --> Win10X64
    Select the file --> netrtwlane.inf and OK.
    Restart.
    47
    1. Nawii_ Posted messages 1 Status Member 4
      Thank you very much, everything seems to be working again!
      Have a good evening!
      4
    2. marredemonordi
      Comment accéder à ce site avec son ordinateur portable si on ne peut se connecter à aucun Wi-Fi ni réseau ?
      11
    3. kaneagle Posted messages 86301 Registration date   Status Moderator Last intervention   14 692
      From another PC, download 7Zip and the driver
      Put them on a USB stick
      Transfer them to the documents of the problematic PC
      Install 7Zip
      Then, follow the procedure for a manual installation.
