No signal, check cable
Lalala -
 lalala -
Hello
On vacation, we took the precaution of unplugging the antenna and the power supply of the TV. (TV with built-in TNT, receiving via aerial antenna, no box). Upon our return, the TV shows "no signal found, check the cable," which I do: everything seems normal but I unplug and plug it back several times...same issue. I move the TV to a different room to connect it elsewhere, as I have an antenna socket in the office...same issue. I also bought a new brand new antenna cable and tried the setup in both locations: same message! In desperation, I tried to retune (air + dtv) and started an automatic channel scan, but no channels found, unsurprisingly... However, when I turn it back on now the message has changed and indicates "no channels found." Can someone help me?? I would like to add that this damn TV is only three and a half years old... Thank you.
Sylviane17 Posted messages 2885 Registration date   Status Modérateur Last intervention   386
Hello,
and by checking in "source" if it's the right input (TV, AV, HDMI...)
Tomorrow is another day, let's live in the moment.
19
lalala
Thank you Sylviane for your response. The source setting is just fine as I already mentioned: with a rooftop antenna it’s “air”, searching for “dtv” channels.
