Besoin d'aide pour conversion d'un code en Fortran77 pour Matlab
Je souhaiterai beaucoup votre aide dans la conversion du code suivant écrit en Fortran 77 pour Matlab
le code est le suivant
! Filename : realtime1d.F
! Title : Fortran program for time-dependent Gross-Pitaevskii equation in
! a fully anisotropic trap
! Authors : P. Muruganandam and S. K. Adhikari
! Gross-Pitaevskii equation in a one-dimensional parabolic trap by
! real time propagation (FORTRAN 77 version)
PROGRAM MAIN
IMPLICIT NONE
INTEGER N, N2, NX, NPAS, NRUN,NSTP
! N : Number of space mesh points
PARAMETER (N = 5000, N2 = N/2, NX = N-1)
! NSTP : Number of iterations to introduce the nonlinearity
! NPAS : Number of subsequent iterations with fixed nonlinearity, and
! NRUN : Number of final time iterations with fixed nonlinearity
PARAMETER (NSTP = 1000000, NPAS = 1000, NRUN = 40000)
! X(0:N) : Space mesh, V(0:N) : Potential, and CP(0:N) : Wave function
DOUBLE PRECISION X(0:N), X2(0:N), V(0:N)
DOUBLE COMPLEX CI, CP(0:N)
DOUBLE PRECISION G, DX, DT, MU, EN, ZNORM, RMS
DOUBLE COMPLEX CAIPM, CAL(0:NX), CGA(0:NX)
! OPTION and XOP decides which equation to be solved.
DOUBLE PRECISION G0, GSTP, XOP
INTEGER I, K, OPTION
! DX : Space step and DT : Time step
DATA DX/0.01D0/, DT/0.0001D0/
DATA G0/62.742D0/ ! Final nonlinearity
! Subroutine INTIALIZE() used to initialize the space mesh X(I),
! potential V(I) and the initial wave function. Subroutine COEF() used to
! generate the coefficients for the Crank-Nicholson Scheme. The routine
! NU() performs time progation for the non-derivative part and LU() performs
! time propagation of derivative part. NORM() calculates the norm and
! normalizes the wave function, CHEM() and RAD() are used to calculate the
! chemical potential, energy and the rms radius, respectively. The subroutine
! NONLIN() calculates the nonlinear term, and functions DIFF(), used to
! calculate the space derivatives of the wave function used in CHEM(). The
! function SIMP() does the integration by Simpson's rule.
! OPTION=1 ! Solves -psi_xx+V(x)psi+G0|psi|^2 psi=i psi_t
OPTION=2 !Solves [-psi_xx+V(x)psi]/2+G0|psi|^2 psi=i psi_t
! OPTION=3 ! Solves -psi_xx+V(x)psi/4+G0|psi|^2 psi=i psi_t
IF (OPTION.EQ.1) XOP = 1.D0
IF (OPTION.EQ.2) XOP = 2.D0
IF (OPTION.EQ.3) XOP = 1.D0
G = 0.D0
WRITE(7,900) OPTION
WRITE(7,*)
WRITE(7,901) N
WRITE(7,902) NSTP, NPAS, NRUN
WRITE(7,903) G0
WRITE(7,904) DX, DT
WRITE(7,*)
900 FORMAT(' OPTION = ', I3)
901 FORMAT('# Space Stp N = ', I8)
902 FORMAT('# Time Stp : NSTP', I9,' , NPAS = ', I9,', NRUN = ', I9)
903 FORMAT(' Nonlinearity G = ', F16.8)
904 FORMAT(' Space Step DX = ', F12.6, ', Time Step DT = ', F12.6)
905 FORMAT(F12.6, F16.8)
! INITIALIZE() initializes the starting normalized wave function 'CP' and
! harmonic oscillator potential V
CALL INITIALIZE(N, N2, OPTION, DX, X, X2, V, CI, CP)
! COEF() defines the coefficients of Crank-Nicholson Scheme.
CALL COEF(NX, DX, DT, CI, CAIPM, CAL, CGA)
! Writes initial wave function in File 1
WRITE (1,905) (X(I), ABS(CP(I)), I = 0, N)
! NORM() calculates norm and restores normalization
CALL NORM(N, CP, DX, ZNORM)
! CHEM() calculates the chemical potential MU and energy EN.
CALL CHEM(N, V, CP, DX, G, MU, EN)
! RAD() calculates the r.m.s radius RMS
CALL RAD(N, X2, CP, DX, RMS)
WRITE (7, 1001)
WRITE (7, 1002)
WRITE (7, 1001)
WRITE (7, 1003) ZNORM, MU/XOP, EN/XOP, RMS, ABS(CP(N2))
1001 FORMAT (19X,52('-'))
1002 FORMAT (20X, 'Norm', 7X, 'Chem', 8X, 'Ener', 7X, '<x>', 7X,
& 'Psi(0)')
1003 FORMAT ('Initial : ', 4X, F11.4, 2F12.3, 3F11.3)
GSTP = XOP*G0/DFLOAT(NSTP)
DO K = 1, NSTP ! Introduces nonlinearity in 'NSTP' iterations
G = G + GSTP
! NU() performs time propagation with harmonic potential and nonlinear
! term (non-derivative parts)
CALL NU(N, V, CP, CI, G, DT)
! LU() performs the time iteration with space derivative alone using
! Crank-Nicholson scheme.
CALL LU(N, NX, CAIPM, CAL, CGA, CP) !
END DO
WRITE (7, 1004) ZNORM, MU/XOP, EN/XOP, RMS, ABS(CP(N2))
1004 FORMAT('After NSTP iter.:', F8.4, 2F12.3, 3F11.3)
! Write intermediate wavefuntion in File 2
WRITE(2,905) (X(I), ABS(CP(I)), I = 0, N)
DO K = 1, NPAS ! NPAS iterations transient
END DO
WRITE (7, 1005) ZNORM, MU/XOP, EN/XOP, RMS, ABS(CP(N2))
1005 FORMAT('After NPAS iter.:', F8.4, 2F12.3, 3F11.3)
WRITE (7, 1001)
! Writes final wavefuntion in File 3
WRITE (3,905) (X(I), ABS(CP(I)), I=0,N)
! The following line defines a nonstationary problem which is studied
! below and the time evolution written on file 8 via WRITE(8,*)
G = 0.5D0*G
DO K = 1, NRUN ! NRUN iterations to study nonlinear dynamics
IF (MOD(K,100).EQ.0) THEN
WRITE(8,905) DFLOAT(K)*DT*XOP, RMS
END IF
END DO
STOP
END
SUBROUTINE INITIALIZE(N, N2, OPTION, DX, X, X2, V, CI, CP)
! Calculates the potential term V and the initial wave function CP
IMPLICIT NONE
INTEGER N, N2, OPTION
DOUBLE PRECISION DX, X(0:N), X2(0:N), V(0:N)
DOUBLE PRECISION PI, PI2, PI4, TMP
INTEGER I
CI = CMPLX(0.0D0, 1.0D0)
PI = 4.0D0*ATAN(1.0D0)
PI2 = SQRT(SQRT(2.0D0*PI))
PI4 = SQRT(SQRT(PI))
DO I = 0, N ! Setting up initial condition
X(I) = DFLOAT(I-N2)*DX
X2(I) = X(I)*X(I)
IF (OPTION.EQ.3) THEN
V(I) = X2(I)/4.0D0
TMP = V(I)
CP(I) = EXP(-TMP)/PI2
ELSE
V(I) = X2(I)
TMP = X2(I)/2.0D0
CP(I) = EXP(-TMP)/PI4
END IF
END DO
RETURN
END
SUBROUTINE COEF(NX, DX, DT, CI, CAIPM, CAL, CGA)
! Calculates the coefficients needed in subroutine LU.
IMPLICIT NONE
INTEGER NX
DOUBLE PRECISION DX, DT
DOUBLE COMPLEX CI, CAIPM, CAL(0:NX), CGA(0:NX)
INTEGER J
DOUBLE PRECISION DX2
DOUBLE COMPLEX CDT, CAI0
CDT = DT/CI ! Generating the Coefficients for the
DX2 = DX*DX ! C-N method (to solve the spatial part)
CAIPM = CDT/2.0D0/DX2
CAI0 = 1.D0-CDT/DX2
CAL(NX) = 0.0D0
CGA(NX) = -1.0D0/CAI0
DO J = NX, 1, -1
CAL(J-1) = CGA(J)*CAIPM
CGA(J-1) = -1.0D0/(CAI0+CAIPM*CAL(J-1))
END DO
RETURN
END
SUBROUTINE NU(N, V, CP, CI, G, DT)
! Solves the partial differential equation with the potential and the
! nonlinear term.
IMPLICIT NONE
INTEGER N
DOUBLE PRECISION V(0:N)
DOUBLE COMPLEX CP(0:N), CI
DOUBLE PRECISION G, DT,P3
INTEGER I
DOUBLE PRECISION TMP, TMP2
DO I = 1, N
TMP = ABS(CP(I))
TMP2 = TMP*TMP
CALL NONLIN(TMP2,P3,G)
TMP = DT*(V(I)+P3)
CP(I) = CP(I)*EXP(-CI*TMP)
END DO
RETURN
END
SUBROUTINE NONLIN(P2,P3,G)
! Calculates the nonlinear term.
IMPLICIT NONE
DOUBLE PRECISION P2,P3,G
P3=G*P2
RETURN
END
SUBROUTINE LU(N, NX, CAIPM, CAL, CGA, CP)
! Solves the partial differential equation only with the space
! derivative term using the Crank-Nicholson method
IMPLICIT NONE
INTEGER N, NX
DOUBLE COMPLEX CAIPM, CAL(0:NX), CGA(0:NX), CP(0:N)
INTEGER I
DOUBLE COMPLEX CBE(0:NX), CXX
CBE(NX) = CP(N)
DO I = NX, 1, -1
CXX = CP(I)-(CP(I+1)-2.0D0*CP(I)+CP(I-1))*CAIPM
CBE(I-1) = CGA(I)*(CAIPM*CBE(I)-CXX)
END DO
CP(0) = CMPLX(0.0D0, 0.0D0)
DO I = 0, NX
CP(I+1) = CAL(I)*CP(I)+CBE(I)
END DO
RETURN
END
SUBROUTINE NORM(N, CP, DX, ZNORM)
! Calculates the normalization of the wave function and sets it to
! unity.
IMPLICIT NONE
INTEGER N
DOUBLE PRECISION DX, ZNORM
INTEGER I
DOUBLE PRECISION CP2(0:N)
DOUBLE PRECISION SIMP
EXTERNAL SIMP
DO I = 0, N
CP2(I) = ABS(CP(I))**2
END DO
ZNORM = SQRT(SIMP(N, CP2, DX))
DO I = 0, N
CP(I) = CP(I)/ZNORM
END DO
RETURN
END
SUBROUTINE RAD(N, X2, CP, DX, RMS)
! Calculates the root mean square size RMS.
IMPLICIT NONE
INTEGER N
DOUBLE PRECISION X2(0:N)
DOUBLE PRECISION DX, RMS
INTEGER I
EXTERNAL SIMP
DO I = 0, N
CP2(I) = ABS(CP(I))**2*X2(I)
END DO
RMS = SQRT(SIMP(N, CP2, DX))
RETURN
END
SUBROUTINE CHEM(N, V, CP, DX, G, MU, EN)
! Calculates the chemical potential MU and energy EN. CP is the wave
! function defined at N+1 points at steps of DX, V is the potential and
! G is the nonlinearity.
IMPLICIT NONE
INTEGER N
DOUBLE PRECISION DX, G, MU, EN
INTEGER I
DOUBLE PRECISION P2, DP2, GP2, TMP1D(0:N), EMP1D(0:N)
DOUBLE PRECISION DCP(0:N), XCP(0:N)
EXTERNAL SIMP
DO I=0,N
XCP(I)= ABS(CP(I))
END DO
CALL DIFF(N, DX, XCP, DCP)
DO I = 0, N
P2 = XCP(I)**2
DP2 = DCP(I)**2
CALL NONLIN(P2,GP2,G)
TMP1D(I) = (V(I) + GP2)*P2 + DP2
EMP1D(I) = (V(I) + GP2/2.0D0)*P2 + DP2
END DO
MU = SIMP(N, TMP1D, DX)
EN = SIMP(N, EMP1D, DX)
RETURN
END
DOUBLE PRECISION FUNCTION SIMP(N, F, DX)
! Does the spatial integration with Simpson's rule.
! N refer to the number of integration points, DX space step, and
! F is the function to be integrated.
IMPLICIT NONE
INTEGER N
DOUBLE PRECISION F(0:N), DX
DOUBLE PRECISION F1, F2
INTEGER I
F1 = F(1) + F(N-1) ! N even
F2 = F(2)
DO I = 3, N-3, 2
F1 = F1 + F(I)
F2 = F2 + F(I+1)
END DO
SIMP = DX*(F(0) + 4.0D0*F1 + 2.0D0*F2 + F(N))/3.0D0
RETURN
END
SUBROUTINE DIFF(N, DX, P, DP)
! Computes the first derivative DP of P using
! Richardson extrapolation formula. The derivative at the
! boundaries are assumed to be zero
IMPLICIT NONE
INTEGER N
DOUBLE PRECISION P(0:N), DP(0:N)
DOUBLE PRECISION DX
INTEGER I
DP(0) = 0.0D0
DP(1) = (P(2) - P(0))/(2.0D0*DX)
DO I = 2, N-2
DP(I) = (P(I-2)-8.0D0*P(I-1)+8.0D0*P(I+1)
c -P(I+2))/(12.0D0*DX)
END DO
DP(N-1) = (P(N) - P(N-2))/(2.0D0*DX)
DP(N) = 0.0D0
RETURN
END
  1. Contributeur Ambassadeur
    bonjour, dans quel contexte fais-tu ce travail?
    Veux-tu réellement convertir le programme fortran, ou veux-tu programmer le même algorithme en matlab?
    Matlab et fortran étant très différents, je pense que convertir n'a pas de sens.
    Es-tu prêt à utiliser la boite à outils GPELab, ou bien dois-tu programmer exclusivement en matlab?
    1. Bonjour, en effet j'aimerais programmer en Matlab cette equation: [-psi_xx+V(x)psi]/2+G0|psi|^2 psi=i psi_t, ainsi que les autres fonction qui vont avec ds le code en Fortran. pour ce faire bien que Matlab et Fortran soit tres différent je souhaiterai bcp avoir une conversion du Code en Matlab ensuite je m'en servirai pour écrire un code adequat en Matlab. c'est en fait comme cela que je voudrais procéder.
