Guitar pedal and microphone setup with phantom power requirement
julien
Julien -
Julien -
Hello,
I use a DPA 4099 microphone that I connect to a SR Technology amplifier, with phantom power supplied by the amplifier. So far so good.
I just bought a Line 6 DL4 pedal and want to connect it between the DPA 4099 mic and the amp. Since then, nothing comes out. Is my pedal defective or is it simply a phantom power issue that no longer passes through the pedal?
How can I use the pedal with my microphone?
If you have any idea, I’m listening.
Julien
Julien
Hi Julien,
You have a condenser microphone that isn’t being powered when you connect it to your pedal...
You just need to insert a phantom power supply between the microphone and the pedal: https://www.thomann.de/fr/millenium_pocket_phantom.htm
Happy playing!
Hello Julien,
Unfortunately, the phantom power doesn’t go through the Jack. Likewise, I doubt that the pedal can process a "micro" signal (unamplified). You would therefore need to put a preamp between the microphone and the pedal.
Useful answer or not, feel free to add your small + or - ...
Rédacteur sur ItrassProd.fr - Tests, Prises en main, Actus Son, Vidéo, Lumière-
Thank you for your answers.
In fact, what I would like is to plug my microphones into the mixer of the amplifier in such a way that it provides phantom power, and to plug my delay/loop pedal into the input or output so that it works on the overall sound of the amp. But it seems like it won’t work.
So I’m going to buy a mixer (MG10XU) that has the fx send, and from what I was told in the shop, I’ll be able to plug the pedal into it and the microphones that need phantom power into the mixer.
It’s more expensive than a phantom power supply from Thomann but it will also serve as a medium for recording on the computer
I
