New JBL Xtreme Battery Charging Issue
Solved
Stewo Posted messages 8 Status Membre -
 Matheo -
Hello,
I recently purchased a JBL Xtreme speaker (yesterday) and I’ve already noticed an issue with it. I tried to charge the battery before using it, but the LED lights indicating the battery level are stuck: 3 are on and the fourth is continuously flashing. The speaker has been charging all night. Normally, when the battery is fully charged, all 5 LEDs should light up, right?
I’m not sure if this is a manufacturing defect or not; I didn’t take the warranty. Is it possible to exchange it in that case? (I bought it at FNAC)
Thank you in advance and have a great day.
RomanBG
Hello everyone,
One solution worked for me:
  • First, reset the device (hold the volume + and play/pause buttons for 5 seconds) --> Then charge the battery for 6 hours.
  • If solution 1 doesn't work, download the JBL Connect app (Android/iOS) and update the drivers via Bluetooth.
One of these two solutions worked for me, I hope it works for you too!
Have a nice day!
103
Nono
Thank you very much, best regards.
SB
Thank you
Matheo
I had the same problem, but I bought it at Boulanger and they exchanged it for a new one.
