NIKON Coolpix S3100 "Battery/Power exhausted"
Angélica
cecim Posted messages 3582 Registration date Status Membre Last intervention -
Hello,
I have a Nikon Coolpix S3100 camera and there's a problem: it keeps displaying "The battery is empty." However, I have charged it several times, so it's strange.
I cleared the memory card, it turned on for me, I had to update the time zone, but right after that, the same message appeared again.
What should I do? I can't just leave it charging for a whole day?
Thank you in advance. :)
Hello,
rechargeable batteries have a limited lifespan, which means that after a certain period (most often between 2 and 4 years) they no longer hold a charge. You need to buy new ones.
If the batteries are new, you should check that the charger is working properly. You can never be too careful about a malfunction or a loose connection.
