IF function with multiple conditions using less than and greater than
Solved
Hello,
I'm having some issues with an Excel formula.
I would like:
- If AA2 is less than 1, then 1
- If AA2 is between 1 and 5 inclusive, then 2
- If AA2 is between 6 and 10 inclusive, then 3
- If AA2 is greater than 10, then 4
What is wrong with my formula?
=IF(AA2<1,1,IF(AND(AA2>=1,AA2<=5),2,IF(AND(AA2<=6,AA2<=10),3,IF(AA2>10,4))))
Excel seems to work fine for giving me 1 and 4, but it's the 2 and 3 that aren't working...
Thank you for your help!!
1 answer
  1. Hello
    You can simplify your formula already:
    =IF(AA2<1,1,IF(AA2<=5,2,IF(AA2<=10,3,4)))
    Best regards
    Via
    "Imagination is more important than knowledge." A. Einstein
    3
    1. Why make things complicated when they can be simple?
      Thank you, it's perfect!
