Divide a sheet into 4 equal parts.
Solved
Ppouille Posted messages 306 Registration date   Status Member Last intervention   -
 Elodie -
Hello, I would like to split my page into 4 strictly equal parts, so that after printing, I can cut my sheet into 4 completely equal parts. How can I do that?
Thank you for your help.
  1. Raymond PENTIER Posted messages 58229 Registration date   Status Contributor Last intervention   17 493
    Hello Ppouille.
    1) If the rules are not displayed, select View/Rule
    2) Select Insert/Shapes/Lines/Line
    3) Draw a vertical line in the middle of the page (at 8 cm on the ruler) from one edge to the other
    4) Draw a horizontal line in the middle of the page (at 12.4 cm) from one edge to the other
    It's nice, retirement! Especially in the Caribbean ... :-)
    ☻ Raymond ♂
    11
    1. Elodie
      Thank you
