Difference between CineCrystal and LED backlighting
Akunotenshi -
 Akunotenshi -
Hello,
What is (are) the difference(s) between an LED backlit screen and a Cine Crystal screen?
Thank you
Configuration: Windows 8 / Chrome 24.0.1312.57
1 answer
  1. Bruce Willix Posted messages 12376 Registration date   Status Contributor Last intervention   2 640
    CineCrystal doesn't mean much: it's just the way Acer calls its LCD screens (a bit like "Retina"). Acer's LED screen is called "CrystalBrite."
    Personally, I prefer LED (and its variations: OLED and AMOLED): lower persistence (there are fewer "traces" behind fast-moving objects on the screen), higher contrast and brightness. Price too, by the way.
    The best thing is still to go see them functioning in the store. You'll immediately see which one you prefer...
    Remember remember the fifth of November
    Gunpowder, treason and plot.
    I see no reason why gunpowder, treason
    Should ever be forgot...
    1. Akunotenshi
      Thank you Bruce Willix, that was very informative^^
