Low battery warning not showing
Solved
Theluxland
Posted messages
6
Status
Member
Charlie -
Charlie -
Hello,
I have a problem that has been going on for some time
The battery of my Gateway laptop is perfectly fine, and I disconnect it as soon as it's fully charged and only plug it back in when it's almost empty
But for some time now, it no longer warns me when my battery is almost empty, nor even when the battery level is critical, so it becomes a bit frustrating when the PC shuts down unexpectedly in the middle of work (At least I don't lose what I'm doing because it goes into hibernation, but I still wait a good 5 minutes plus 2-3 minutes for it to boot up.)
Where are the warning settings? At first, I thought it was because I was watching things in full screen, but it just did it to me while I was at school, on Word... Please help me!
Theluxland
Configuration: Windows 7 / Chrome 23.0.1271.97
Theluxland
Hello,
I had the same problem as you and I've just found the solution: right-click on the battery icon, power options, change plan settings (normal use), change advanced power settings, click on battery, low battery level "on battery" (by default 10% for me), I raised it to 15% and now I get the message and sound when I'm at 15% and I have time to plug it in. There you go, I hope it works for you too.
Great and thank you for sharing your know-how. One less frustration in life...hallelujah!
