Cutting your Samsung LED TV 7 remote control
Solved
Théo -
 Toshyjoe -
How to mute the sound on the remote control of a Samsung LED TV series 7
Thank you in advance
pacalvideo Posted messages 3358 Status Membre 396
on the "mute" button
2
Théo
Thank you, but my request was not clear enough; it's not the sound of the television that I want to mute, but the beeps that the remote makes when used in the menus. Mute the cut as well, but it also mutes the sound of the television.
menu then "config" then "general" and submenu "remote control" and in "remove" "beep"
in principle it's there
Indeed, the "mute" cuts everything off, it's good when you're on the phone.
Steph
For Samsung UHD series 7000 televisions, go to the menu under the tabs: System - General - Audio feedback select Disable.
Toshyjoe > Steph
Top!
