Problem with a Starcom TNT tuner decoder
Solved
Hello,
I have a Starcom TNT tuner that stubbornly sends a window to the TV screen saying "tuner power" at intervals of a few seconds. The image is otherwise good. What should I do? Does anyone have an idea to eliminate this nuisance??
Thanks.
Configuration: iPad / Safari 6533.18.5
1 answer
  • Descending date
  1. hello
    go to the settings menu
    disable or enable the 'antenna power + 5 V' option depending on the case
    1. Thank you for the advice, I had the same problem and I solved it thanks to your response.
      Gilbert
    2. I don’t have that option when I’m in the settings menu
    3. problem of the Starcom 8817 decoder: it shows "alimentación tuner" on the TV, what to do.
    4. Moderator
      See above for cricri's answer.....
