Problem with TV cabinet nesx ne778i
Yuya
coco -
coco -
Hello everyone.
Here's my problem, I just bought a home cinema TV cabinet from the brand nesx model NE778i-.
After making the connections, only the iPhone station and the USB/SD port work.
When I turn on the TV (connected to the SFR box decoder) no sound comes out of the TV cabinet.
The SFR decoder is connected to the TV via the SCART cable, if that helps.
Please help me, I'm going crazy -_-.
Thank you.
Thank you.
Related links:
- Playing MKV files with subtitles on Philips TV
- Connecting Kenwood amplifier with Samsung LED TV
- Problem with HD reception with Techwood RS685 CHB decoder
- How to connect the Soundvision SV 200W home theater cabinet?
- Connecting amplifier - TV with sound PS4
- Connecter une télévision Thomson avec un home cinéma Samsung via Orange.
Hello,
First of all:
Output = "out"
Input = "in"
If you have inverted them or if your TV does not have an "out" RCA output, it cannot work on the "in" RCA input of the Nesx. However, if your TV has a headphone output, you can use it as a connection with a male stereo jack to stereo RCA cable (shielded is better). -
Hello everyone.
After much searching and thorough research, I found the problem.
As sawsix said, my TV did not have an "Out" output, so I had to buy an RCA SCART with an "In" "Out" switch, and now everything works.
Thank you for your help. -
Hi
how did you connect your SFR box decoder to your home theater furniture?
