Problem with HD reception with Techwood RS685 CHB decoder
Hello,
I have a problem with HD reception with the Techwood RS685 CHB decoder
so, every time I go to an HD channel the TV displays "the video format is not supported"
Are there any settings to configure? if so, which ones? thank you
1 answer
Connect your TV to your set-top box via HDMI; without this, it won’t work.
perhaps a clue regarding the antenna pointing to consider: http://forum.telesatellite.com/showthread.php/727-d%C3%A9codeur-TNTSAT-Techwood-RS-685-CHB
