TASSIMO BOCH leak problem in the tank
Closed
boublou34 -
 Xileh -
Good evening
I have a Bosch Tassimo and I performed a descaling since the red indicator light was on. Everything was fine until I filled the water tank at the back!! Water was leaking everywhere and the T-disc capsule only dispensed a little water, leaving the cup half full!! I should mention that everything was working perfectly before the descaling.
How can I fix this water flow issue?
Who can help me?
Thank you for your responses... if there are any!
1 answer
  1. enorvege Posted messages 2 Status Member
    Hello,
    I think the problem is that your tank is messed up because I had the same issue as you
    I think the best thing is to change it, there are quite a few Tassimo models and a lot of tank models
    I bought it online at this address https://www.ma-cafetiere.com/multi-boissons-tas-430-tassimo/360-reservoir-cafetiere-bosch-multi-boissons-t43-tassimo-00741162.html otherwise there’s another site if you want https://www.pieces-online.com/reservoir-cafetiere-tassimo-bosch/5186-reservoir-cafetiere-tassimo-bosch-multi-boissons-tas4304-00741162.html
    Keep me updated if your problem persists
    Michel
    1. piquesous Posted messages 15734 Registration date   Status Contributor Last intervention   6 124
      Hello,
      I think the person has found the answer since, and especially changed machines.
      The topic is over 3 years old.
      Just like the other topic where you responded.
      I don't think it’s useful to bring up all the old topics like this one.
      See you later!
      1. Xileh > piquesous Posted messages 15734 Registration date   Status Contributor Last intervention
        Hi
        Absolutely!
        Especially since this topic should have been closed (even back then)... as it is off-topic!
        The "right forum" for these questions is:
        https://bricolage.linternaute.com/forum/electromenager-14
        So.... I’m closing it!.....
        See you!
