Logitech X210 subwoofer problem
Jas-86 Posted messages 18 Status Member -
 tarascon -
Hello,
I have a problem with the subwoofer of the Logitech X210 speaker kit. It doesn’t work. Only the two speakers work. The subwoofer only vibrates a little. I tried it on another device, my iPod, and I still have the same problem! I need help!
Thanks in advance! :D
Configuration: Windows Vista / Firefox 3.6.16
  1. tarascon
    hello
    if there is a volume button behind the casing and it is turned up to the max, is it malfunctioning
  2. Jas-86 Posted messages 18 Status Member 1
    There is no volume button behind the subwoofer but apart from it this one isn’t turned up to the max...
  3. tarascon
    I found the user manual, no problem to plug it in. Open the volume box and check if it’s turned up all the way; if yes, that means it’s malfunctioning.
