Help for 4-wire fan
poops21 Posted messages 130 Status Member -
Hello,
I have a 4-pin CPU fan but I would like to use it as a case fan
but when I connect it to a 3-pin fan socket, the fan doesn't go above 1500 RPM at full speed.
I can't connect it any other way because of the notch on the connector.
Is there a way to make it work like a normal 3-pin fan?
Fan specifications:
Fan(s) 1 x 92 mm
RPM min: 1200 max: 2800
Airflow min. 36 CFM
Airflow max. 54.6 CFM
Noise min. 22 dB
Noise max. 34 dB
Motherboard:
http://img91.imageshack.us/img91/9901/asusm2nslideluxetopbhv5.jpg
Thank you for your attention
Configuration: Windows XP Firefox 3.0.8
  1. fabalex Posted messages 1504 Status Member 110
    Personally, I have a fan controller for the case fans, a fan controller that can also completely shut off the fans,
    what brand is your motherboard?
    Vista ultimate 64bit
    4
    1. poops21 Posted messages 130 Status Member 13
      asus m2n-sli deluxe
