I cannot write in System32.
Speed
seb -
seb -
Hello,
I am the admin of the computer (the only one) but I cannot write in the folder "C:\Windows\System32\drivers\etc"
I want to save changes to hosts but I can't save it!!
Please help me
Thank you in advance for your responses,
Cordilus,
Postium
Please help me
Cordilus,
Postium
Configuration: Windows Vista Firefox 3.0.5
As I pointed out earlier, the operations that will follow will have no effect
without administrator status (the Login name)
Start\tall programs\accessories\ right-click on Windows Explorer
properties\advanced\ check the box run as administrator, OK then Apply
then right-click on Windows Explorer again add to the quick launch bar
return to the desktop and launch Windows Explorer, go to the HOST folder and
right-click on it, \properties\security\advanced\owner\edit
check replace owner of sub-cont........, then click on your Login name
Apply then OK
then give yourself all rights in the first window. -
Hello
What is the message displayed for this refusal? -
Have you checked with the explorer if the host file exists?
And if it's there, check its properties (security, administrator rights, read-write mode). -
That's why you can't write on it; apparently, only the system has access. You may need to take ownership, but if you're not an administrator, there's no point in insisting.
Until now I am
right click on it, \properties\security\advanced\owner\edit
But there is no "replace owner of sub-contents"
look: http://img2.hostingpics.net/pics/792522prob.jpg -
