Max tv ne s'ouvre plus
Bonjour,MAX TV ne veut plus s ouvrir vola se qu' il me dit:
Failed to Connect
The connection was refused when attempting to contact localhost:2000.
Though the site seems valid, the browser was unable to establish a connection.
* Could the site be temporarily unavailable? Try again later.
* Are you unable to browse other sites? Check the computer's network connection.
* Is your computer or network protected by a firewall or proxy? Incorrect settings can interfere with Web browsing.
s'il vous plait redonder vite c urgent merci
cordialement quentin
désolé pour les fautes
Failed to Connect
Configuration: Windows XP Firefox 3.0.1
Si Max -tv ne s'ouvre plus , essaie de vérifier ce paramètre.
try to check if your setting is correct.
Wordpad = bloc note
Click on the right on your mouse , not the left
http://www.microsoft.com/security/portal/Entry.aspx?name=SettingsModifier%3aWin32%2fPossibleHostsFileHijack&threatid=1758608427027806866
