Problème Apache
Bonjour, je viens d’installer wamp sur mon pc, et moment ou je le lance, apache plante ! J'ai essayer de la réinstaller, ou de désactive mes par-feus, mais rien. Auriez-vous une solution ? Merci.
Configuration: Windows XP Firefox 3.0
15 réponses
c'est quoi l'erreur?
Contributeuressaie de désinstaller apache car je pense que on ne peut pas avoir deux serveurs locals sur le meme ordi
darkchristophetd, je n'est pas apache en plus de wamp, c'est le apache de wamp qui plante.
Sinon pour l'erreur, dans l"apache_error.log" il y a :
[Sun Jun 22 19:16:22 2008] [notice] Apache/2.2.8 (Win32) PHP/5.2.6 configured -- resuming normal operations
[Sun Jun 22 19:16:22 2008] [notice] Server built: Jan 18 2008 00:37:19
[Sun Jun 22 19:16:22 2008] [notice] Parent: Created child process 3236
[Sun Jun 22 19:16:22 2008] [notice] Child 3236: Child process is running
[Sun Jun 22 19:16:22 2008] [notice] Child 3236: Acquired the start mutex.
[Sun Jun 22 19:16:22 2008] [notice] Child 3236: Starting 64 worker threads.
[Sun Jun 22 19:16:22 2008] [notice] Child 3236: Starting thread to listen on port 80.
[Sun Jun 22 19:16:28 2008] [notice] Parent: child process exited with status 3221225477 -- Restarting.
[Sun Jun 22 19:16:28 2008] [notice] Apache/2.2.8 (Win32) PHP/5.2.6 configured -- resuming normal operations
[Sun Jun 22 19:16:28 2008] [notice] Server built: Jan 18 2008 00:37:19
[Sun Jun 22 19:16:28 2008] [notice] Parent: Created child process 480
[Sun Jun 22 19:16:29 2008] [notice] Child 480: Child process is running
[Sun Jun 22 19:16:29 2008] [notice] Child 480: Acquired the start mutex.
[Sun Jun 22 19:16:29 2008] [notice] Child 480: Starting 64 worker threads.
[Sun Jun 22 19:16:29 2008] [notice] Child 480: Starting thread to listen on port 80.
[Sun Jun 22 19:16:29 2008] [notice] Parent: Received shutdown signal -- Shutting down the server.
[Sun Jun 22 19:16:33 2008] [notice] Child 480: Exit event signaled. Child process is ending.
[Sun Jun 22 19:16:34 2008] [notice] Child 480: Released the start mutex
[Sun Jun 22 19:16:34 2008] [notice] Parent: Child process exited successfully. -
Pour lui, aucune erreur... Il a reçu le signal shutdown alors il s'arrete. Je ne connais pas wamp mais apache si... Comment lances tu ton serveur Apache?
Ne devrais tu pas essayer l'installation et la configuration d'Apache, PHP et MySQL indépendamment?
Pour darkchristophetd, il est possible d'avoir 2 serveurs sur le meme ordi et meme 2 serveur lancé en meme temps sur le meme ordi (pour peu qu'il n'utilise pas les memes ports)! -
Apache se lance au démarrage de wamp. Je vais essayer d’installer Apache, PHP et mysql independamment et on verra bien.
independamment c'est quand meme un peu plus compliqué mais en cherchant sur internet, ça ne devrait pas trop te poser de probleme.
Contributeurdésolé pour l'erreur
no soucy ;)
Je viens d'installer apache et sa me fait la même chose :(
ça serait pas un pare feu qui bloque ça???
Non j'ai essayer en désactivant mes pare feu, sans succès.
logs?
Voila voila:
[Sun Jun 22 19:51:28 2008] [notice] Apache/2.2.4 (Win32) configured -- resuming normal operations
[Sun Jun 22 19:51:28 2008] [notice] Server built: Jan 9 2007 23:17:20
[Sun Jun 22 19:51:28 2008] [notice] Parent: Created child process 2532
[Sun Jun 22 19:51:28 2008] [notice] Child 2532: Child process is running
[Sun Jun 22 19:51:28 2008] [notice] Child 2532: Acquired the start mutex.
[Sun Jun 22 19:51:28 2008] [notice] Child 2532: Starting 250 worker threads.
[Sun Jun 22 19:51:28 2008] [notice] Child 2532: Starting thread to listen on port 80. -
Il s'arrete sur "Starting thread to listen on port 80." disant qu'il était bien démarré!
Dans ton navigateur, ça marche pas : http://127.0.0.1:80
La page charge mais sans s'arrêter. Mais c'est louche, parce que apache ne plante plus.
