Rapport sd fix pour le virus ta tof
j ai essayé de suivre les instructions , msn fix ca marche pas ??? j ai essayé avec sd fix , je trouve ce rapport quelqu un pourrait l interpreter et me dire qu est ce que je dois faire ?? merci d avance
[b]SDFix: Version 1.154 [/b]
Run by dauphin pierre-yves on 09/03/2008 at 22:15
Microsoft Windows XP [version 5.1.2600]
Running From: C:\SDFix
[b]Checking Services [/b]:
Restoring Windows Registry Values
Restoring Windows Default Hosts File
Rebooting
[b]Checking Files [/b]:
Trojan Files Found:
C:\Documents and Settings\dauphin pierre-yves\Application Data\WinTouch\WTUninstaller.exe - Deleted
C:\Documents and Settings\dauphin pierre-yves\Application Data\WinTouch\wintouch.cfg - Deleted
C:\Program Files\JavaCore\JavaCore.exe - Deleted
C:\Program Files\JavaCore\UnInstall.exe - Deleted
C:\Program Files\NoDNS\UnInstall.exe - Deleted
C:\Program Files\nvcoi\nvcoi.exe - Deleted
C:\Program Files\nvcoi\mst.stt - Deleted
C:\Program Files\Temporary\InsiDERInst.exe - Deleted
C:\WINDOWS\b152.exe - Deleted
C:\WINDOWS\b153.exe - Deleted
C:\DOCUME~1\DAUPHI~1\LOCALS~1\Temp\services.exe - Deleted
C:\WINDOWS\system32\real.txt - Deleted
Folder C:\Documents and Settings\dauphin pierre-yves\Application Data\WinTouch - Removed
Folder C:\Program Files\InetGet2 - Removed
Folder C:\Program Files\JavaCore - Removed
Folder C:\Program Files\NoDNS - Removed
Folder C:\Program Files\nvcoi - Removed
Folder C:\Program Files\Temporary - Removed
Removing Temp Files
[b]ADS Check [/b]:
[b]Final Check [/b]:
catchme 0.3.1344.2 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-03-09 22:19:59
Windows 5.1.2600 Service Pack 2 FAT NTAPI
scanning hidden processes ...
scanning hidden services ...
scanning hidden autostart entries ...
HKLM\Software\Microsoft\Windows\CurrentVersion\Run
LXCFCATS = rundll32 C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\LXCFtime.dll,_RunDLLEntry@16???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
scanning hidden files ...
scan completed successfully
hidden processes: 0
hidden services: 0
hidden files: 0
[b]Remaining Services [/b]:
Authorized Application Key Export:
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\standardprofile\authorizedapplications\list]
"%windir%\\system32\\sessmgr.exe"="%windir%\\system32\\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019"
"C:\\Program Files\\Messenger\\msmsgs.exe"="C:\\Program Files\\Messenger\\msmsgs.exe:*:Enabled:Windows Messenger"
"C:\\Program Files\\Windows Live\\Messenger\\msnmsgr.exe"="C:\\Program Files\\Windows Live\\Messenger\\msnmsgr.exe:*:Enabled:Windows Live Messenger"
"C:\\Program Files\\Windows Live\\Messenger\\livecall.exe"="C:\\Program Files\\Windows Live\\Messenger\\livecall.exe:*:Enabled:Windows Live Messenger (Phone)"
"%windir%\\Network Diagnostic\\xpnetdiag.exe"="%windir%\\Network Diagnostic\\xpnetdiag.exe:*:Enabled:@xpsp3res.dll,-20000"
"C:\\Program Files\\Bonjour\\mDNSResponder.exe"="C:\\Program Files\\Bonjour\\mDNSResponder.exe:*:Enabled:Bonjour"
"C:\\WINDOWS\\System32\\lxcfcoms.exe"="C:\\WINDOWS\\System32\\lxcfcoms.exe:*:Enabled:730 Series"
"C:\\Program Files\\Norcontrol\\Neptune\\Bin\\Picasso-3\\bin\\winArch\\rtm.exe"="C:\\Program Files\\Norcontrol\\Neptune\\Bin\\Picasso-3\\bin\\winArch\\rtm.exe:*:Enabled:Picasso-3 RTM Application"
"C:\\Program Files\\Norcontrol\\Neptune\\Bin\\Ess.exe"="C:\\Program Files\\Norcontrol\\Neptune\\Bin\\Ess.exe:*:Enabled:Ess"
"C:\\Program Files\\Norcontrol\\Neptune\\Bin\\Simulator.exe"="C:\\Program Files\\Norcontrol\\Neptune\\Bin\\Simulator.exe:*:Enabled:Neptune Simulator"
"C:\\Program Files\\Norcontrol\\Neptune\\Bin\\Picasso-3\\bin\\winArch\\control.exe"="C:\\Program Files\\Norcontrol\\Neptune\\Bin\\Picasso-3\\bin\\winArch\\control.exe:*:Enabled:control"
"C:\\Program Files\\iTunes\\iTunes.exe"="C:\\Program Files\\iTunes\\iTunes.exe:*:Enabled:iTunes"
"C:\\DOCUME~1\\DAUPHI~1\\LOCALS~1\\Temp\\services.exe"="C:\\DOCUME~1\\DAUPHI~1\\LOCALS~1\\Temp\\services.exe:*:Enabled:Flash Media"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\domainprofile\authorizedapplications\list]
[b]Remaining Files [/b]:
File Backups: - C:\SDFix\backups\backups.zip
[b]Files with Hidden Attributes [/b]:
Fri 3 Oct 2003 1,024 ...HR --- "C:\WINDOWS\system32\NTICDMK32.dll"
Sun 9 Mar 2008 0 A..H. --- "C:\WINDOWS\SoftwareDistribution\Download\4633c51c90c17af214c8eeab40b9fcf4\BIT14.tmp"
Sat 26 Jan 2008 0 A.SH. --- "C:\Documents and Settings\All Users\DRM\Cache\Indiv01.tmp"
Mon 28 Jan 2008 230,400 ..SHR --- "C:\Documents and Settings\dauphin pierre-yves\Application Data\?asks\m?iexec.exe"
[b]Finished![/b]
Rebooting
Trojan Files Found:
Removing Temp Files
[b]ADS Check [/b]:
hidden processes: 0
hidden services: 0
hidden files: 0
[b]Finished![/b]
telecharge hijackthis installe le. ouvre le fait le premier choix et poste le texte qui va apparaitre ici
bonsoir
pourquoi il marche pas msnfix?
lance ceci quand meme en attendant:
Ouvre ce lien (merci a S!RI pour ce programme). http://siri.urz.free.fr/Fix/SmitfraudFix.php
et télécharge SmitfraudFix.exe.
Exécute le en choisissant l’option 1, il va générer un rapport
Copie/colle le sur le poste stp.
bises -
merci je vous donne le rapport hijackthisLogfile of Trend Micro HijackThis v2.0.2
Scan saved at 22:37:35, on 09/03/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16608)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\System32\Ati2evxx.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
C:\Program Files\Fichiers communs\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
C:\Program Files\Bonjour\mDNSResponder.exe
C:\Program Files\Fichiers communs\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\WINDOWS\system32\notepad.exe
C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\WINDOWS\AGRSMMSG.exe
C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe
C:\Program Files\Aspire Arcade\PCMService.exe
C:\Program Files\CRW\shwicon.exe
C:\PROGRA~1\LAUNCH~1\CPLCL32.EXE
C:\Program Files\Neuf\Kit\WiFi\9wifi.exe
C:\PROGRA~1\Nokia\NOKIAP~1\LAUNCH~1.EXE
C:\Program Files\Adobe\Photoshop Album Edition Découverte\3.0\Apps\apdproxy.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe
C:\Program Files\Fichiers communs\PCSuite\Services\ServiceLayer.exe
C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe
C:\Program Files\OLYMPUS\OLYMPUS Master 2\MMonitor.exe
C:\Program Files\Google\GoogleToolbarNotifier\1.2.1128.5462\GoogleToolbarNotifier.exe
C:\PROGRA~1\FICHIE~1\Nokia\MPAPI\MPAPI3s.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WLLoginProxy.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.msn.com/fr-fr/?ocid=iehp
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = https://www.msn.com/fr-fr/?ocid=iehp
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = https://www.bing.com/?toHttps=1&redig=5FC791212101479BAFBE1A679848B1AF
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.bing.com/?toHttps=1&redig=5FC791212101479BAFBE1A679848B1AF
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.msn.com/fr-fr/?ocid=iehp
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = https://actus.sfr.fr
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = https://www.acer.com/worldwide/selection.html
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
O2 - BHO: (no name) - {3636CDC1-5704-03FC-0211-2B00BBC8889C} - C:\WINDOWS\system32\ljaf.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
O4 - HKLM\..\Run: [LaunchApp] Alaunch
O4 - HKLM\..\Run: [ATIModeChange] Ati2mdxx.exe
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [SynTPLpr] C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe"
O4 - HKLM\..\Run: [PCMService] "C:\Program Files\Aspire Arcade\PCMService.exe"
O4 - HKLM\..\Run: [ShowIcon_Chander_CRW Series Driver v1.17r019] "C:\Program Files\CRW\shwicon.exe" -t"Chander\CRW Series Driver v1.17r019"
O4 - HKLM\..\Run: [LManager] C:\PROGRA~1\LAUNCH~1\CPLCL32.EXE
O4 - HKLM\..\Run: [Autoconfigurateur WiFi Neuf] "C:\Program Files\Neuf\Kit\WiFi\9wifi.exe"
O4 - HKLM\..\Run: [PCSuiteTrayApplication] C:\PROGRA~1\Nokia\NOKIAP~1\LAUNCH~1.EXE -startup
O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Album Edition Découverte\3.0\Apps\apdproxy.exe"
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [LXCFCATS] rundll32 C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\LXCFtime.dll,_RunDLLEntry@16
O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe" /min
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [PcSync] C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe /NoDialog
O4 - HKCU\..\Run: [OM2_Monitor] "C:\Program Files\OLYMPUS\OLYMPUS Master 2\MMonitor.exe"
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\1.2.1128.5462\GoogleToolbarNotifier.exe
O4 - HKCU\..\Run: [Sabn] "C:\DOCUME~1\DAUPHI~1\APPLIC~1\ECURIT~1\scanregw.exe" -vt yazb
O4 - HKCU\..\Run: [Izagn] "C:\Documents and Settings\dauphin pierre-yves\Application Data\?asks\m?iexec.exe"
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Default user')
O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Console Java (Sun) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra button: Recherche - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O15 - Trusted Zone: http://www.secuser.com
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/...
O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - https://www.trendmicro.com/en_us/forHome/products/housecall.html
O23 - Service: AntiVir PersonalEdition Classic Scheduler (AntiVirScheduler) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
O23 - Service: AntiVir PersonalEdition Classic Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Fichiers communs\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Ati HotKey Poller - Unknown owner - C:\WINDOWS\System32\Ati2evxx.exe
O23 - Service: Service Bonjour (Bonjour Service) - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: Service de l'iPod (iPod Service) - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: lxcf_device - Unknown owner - C:\WINDOWS\system32\lxcfcoms.exe
O23 - Service: ServiceLayer - Nokia. - C:\Program Files\Fichiers communs\PCSuite\Services\ServiceLayer.exe
il est très bon ce rapport plus de virus!!!!
et en plus avec bon antivirus puissant.
tu as je pense suivit les conseil du site de malekal.
Cordialement-
@Utilisateur anonymeah ouais merde ^^ dsl j'en fait plein !!
mais par contre le virus n'est plus là!!
quel virus et d'où lol!!!!!!!!
bon , pour la personne de ce topic ^^ :
remoi
bon déjà tu n'a pas de parefeu , installe celui ci :
https://www.01net.com/telecharger/windows/Securite/firewall/fiches/22418.html
tuto & explications ici :
http://kerio.probb.fr/logiciels-et-tutoriels-gratuits-tries-par-categorie-f6/tutoriel-sunbelt-personal-firewall-45916-ex-kerio-t248.htm
ensuite relance hijack et va sur do a scan only et coche ceci :
-O4 - HKCU\..\Run: [Sabn] "C:\DOCUME~1\DAUPHI~1\APPLIC~1\ECURIT~1\scanregw.exe" -vt yazb
-O4 - HKCU\..\Run: [Izagn] "C:\Documents and Settings\dauphin pierre-yves\Application Data\?asks\m?iexec.exe"
clic sur fix ensuite
bises
Contributeur sécuritéSalut les gens......
quand on a un doute, faut voir de plus près .....
Il va falloir analyser des fichiers suspects !
Il se peut qu'ils se trouvent dans les " dossiers cachés " du systeme. Il faut donc les rendre visibles pour le scan.
Pour afficher les dossiers et fichiers cachés:
Panneau de configuration > Options des dossiers > onglet Affichage.
coche Afficher les fichiers et dossiers cachés,
décoche Masquer les extensions de fichiers connus
décoche Masquer les fichiers protégés du Système.
Un message de mise en garde va apparaitre. Clique sur OK pour confirmer ton choix.
Les fichiers et dossiers cachés du système apparaitront alors dans l'explorateur Windows en transparence.
Lorsque tu aura fini d'intervenir dans les répertoires système, fait la manip inverse pour recacher les fichiers système.
Rend toi chez Virus Total pour analyser ce fichier.
Clik sur parcourir
Recherche ceci :
C:\Documents and Settings\dauphin pierre-yves\Application Data\?asks\m?iexec.exe" Fais le un dossier à la fois !
Clik send et poste le rapport ici stp
Comment faire <<< Aide toi de ce tuto. -
re bonjour ,
j ai supprimé les fichiers avec hitjackthis , et je vous poste un rapport pour voir si il est bon ???
merci d avance
Scan saved at 17:24:04, on 10/03/2008
Boot mode: Normal
Running processes:
C:\Program Files\Sunbelt Software\Personal Firewall\kpf4ss.exe
C:\Program Files\Sunbelt Software\Personal Firewall\kpf4gui.exe
O23 - Service: Sunbelt Personal Firewall 4 (SPF4) - Sunbelt Software - C:\Program Files\Sunbelt Software\Personal Firewall\kpf4ss.exe
