Probleme XML
Bonjour, Bonjour a tous, petit probleme XML si vous pouviez m'aider :
Voila mon code d'erreur :
Code: Tout sélectionner
SystemID: E:\autounattend.xml
Endroit: 4:2
Description: The markup in the document following the root element must be well-formed.
Et voila mon code en XML :
<?xml version="1.0" encoding="utf-8"?> <unattend xmlns="urn:schemas-microsoft-com:unattend"> <settings pass="windowsPE"> <component name="Microsoft-Windows-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DiskConfiguration> <Disk>
<CreatePartitions> <CreatePartition wcm:action="add"> <Order>1</Order> <Size>10000</Size> <Type>Primary</Type> </CreatePartition> </CreatePartitions> <ModifyPartitions> <ModifyPartition wcm:action="add"> <Active>true</Active> <Extend>true</Extend> <Format>NTFS</Format> <Label>OS_Install</Label> <Letter>C</Letter> <Order>1</Order> <PartitionID>1</PartitionID> </ModifyPartition> </ModifyPartitions> <DiskID>0</DiskID> <WillWipeDisk>true</WillWipeDisk> </Disk> <WillShowUI>OnError</WillShowUI> </DiskConfiguration> <UserData> <AcceptEula>true</AcceptEula> </UserData> <ImageInstall> <OSImage> <InstallTo> <DiskID>0</DiskID> <PartitionID>1</PartitionID> </InstallTo> <WillShowUI>OnError</WillShowUI> </OSImage> </ImageInstall> </component> <component name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SetupUILanguage> <UILanguage>fr-FR</UILanguage> </SetupUILanguage> <InputLocale>040C</InputLocale> <SystemLocale>fr-FR</SystemLocale>
<UILanguage>fr-FR</UILanguage> <UserLocale>fr-FR</UserLocale> </component> </settings> <settings pass="oobeSystem"> <component name="Microsoft-Windows-Deployment" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <Reseal> <Mode>Audit</Mode> </Reseal> </component> </settings> <cpi:offlineImage cpi:source="catalog:c:/opktools/install_windows vista ultimate.clg" xmlns:cpi="urn:schemas-microsoft-com:cpi" /> </unattend>
<settings pass="auditUser">
<component name="Microsoft-Windows-Shell-Setup"
<OEMInformation> <Manufacturer>FABRIKAM</Manufacturer>
<Model>FABRIKAM Gamer 510</Model>
<SupportHours>9h-19h</SupportHours>
<SupportPhone>12 34 56 78 90</SupportPhone>
<SupportURL>www.fabrikam.fr</SupportURL>
<Logo>C:\Windows\OEM\FABRIKAM.BMP</Logo>
</OEMInformation>
</component>
</settings>
Si vous avez trouvé je voudrais bien votre aide. Merci plein
10 réponses
    Bonjour, tu peux reposter le contenu du fichier entre des balises "code" s'il te plaît? (au dessus de l'endroit pour rentrer le texte, tu as un icône avec un rectangle blanc et un < > en bleu dessus)
    Merci :)
    1. <?xml version="1.0" encoding="utf-8"?> <unattend xmlns="urn:schemas-microsoft-com:unattend"> <settings pass="windowsPE"> <component name="Microsoft-Windows-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DiskConfiguration> <Disk>
                                  </OEMInformation>
          </component>
      </settings>
      1. sa a coupé un morceau :s moi le logiciel me dit que l'erreur se trouve ici :
                                    </OEMInformation>
            </component>
        </settings>
          Bon, déjà quand tu as un problème de ce genre, il vaut mieux mettre ton fichier sous la forme suivante:
              <DiskConfiguration>
                  <Disk>
                      <CreatePartitions>
                              <Order>1</Order>
                              <Size>10000</Size>
                              </CreatePartition>
                      </CreatePartitions>
                      <ModifyPartitions>
                              <Letter>C</Letter>
                              <Order>1</Order>
                          </ModifyPartition>
                      </ModifyPartitions>
                      <DiskID>0</DiskID>
                  </Disk>
              <UserData>
              </UserData>
              <ImageInstall>
                  <OSImage>
                      <InstallTo>
                          <DiskID>0</DiskID>
                      </InstallTo>
                  </OSImage>
              </ImageInstall>
          </component>
                                      </OEMInformation>
              </component>
          </settings>
          Ca m'a permis de voir directement que tu as au moins deux tags "component" , hors tu n'as le droit qu'à un tag qui lui peut avoir plusieurs enfants, il te faut donc introduire un "components" qui contient tous les "component"
          1. Mince alors, je ne m'y connais pas plus que sa :s, comment faire pour reparer sa alors ? tu peux m'aider ?
              En fait je pense que dans ton cas, tu as mis plusieurs fichiers xml dans un seul, il vaut mieux les garder de manière séparée. Si tu ne veux pas, regarde ce que j'ai mis :)
              genre :
              <components>
                     <component...
                     </component>
                     <component ....
                     <component>
              </components>
              J'ai pas regardé ton fichier en détail mais c'est le principe...
              1. Ok j'ai compris, je l'ai mis sous cette forme tu peux me dire si sa convient ? dsl de te prendre du temps :s
                        <DiskConfiguration>
                            <Disk>
                                <CreatePartitions>
                                        <Order>1</Order>
                                        <Size>10000</Size>
                                    </CreatePartition>
                                </CreatePartitions>
                                <ModifyPartitions>
                                        <Letter>C</Letter>
                                        <Order>1</Order>
                                    </ModifyPartition>
                                </ModifyPartitions>
                                <DiskID>0</DiskID>
                            </Disk>
                        <UserData>
                        </UserData>
                        <ImageInstall>
                            <OSImage>
                                <InstallTo>
                                    <DiskID>0</DiskID>
                                </InstallTo>
                            </OSImage>
                        </ImageInstall>
                    </component>
                                </OEMInformation>
                            </component>
                </unattend>
                1. Dans tous les cas Oxygen ne me met pas d'erreur de mise en forme c'est un bon début :). J'espere ne pas avoir fait de betise(s).
                  Quelqu'un peux me corriger dans le cas inverse ?
                    Ben demande à ton logiciel de tout à l'heure, quant à la lisibilité, il faudrait faire pour tous les component ce que j'ai fait au premier :)
                    Mais certains logiciels spécialisés (et gratuits) font ça très bien :)
                    cherche "xml editor freeware" dans google
                    1. C'est vrai que ton logiciel est bien eficace on a une très bonne lisibilité. Cependant je ne sais pas du tout dans quel settings mettre ma balise components :s. Difficile tout sa. Merc pour ton aide c'est super sympa
