Probleme de creation de vm
Bonjour, svp quand je veux cree la machine virtuelle ca maffiche ca
his host supports Intel VT-x, but Intel VT-x is disabled.
Intel VT-x might be disabled if it has been disabled in the BIOS/firmware settings or the host has not been power-cycled since changing this setting.
(1) Verify that the BIOS/firmware settings enable Intel VT-x and disable 'trusted execution.'
(2) Power-cycle the host if either of these BIOS/firmware settings have been changed.
(3) Power-cycle the host if you have not done so since installing VMware Workstation.
(4) Update the host's BIOS/firmware to the latest version.
This host does not support "Intel EPT" hardware assisted MMU virtualization.
VMware Workstation does not support the user level monitor on this host.
Module 'MonitorMode' power on failed.
Failed to start the virtual machine.
