[Debien lenny] problème driver Nvidia
bonsoir,
j'ai un probleme de driver avec ma carte graphique NVIDIA Ge7300.
je précise que j'installe le driver propriétaire, avec les kernel source et headers meme version que le noyau.
voici le gedit /var/log/Xorg.0.log
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian
Current Operating System: Linux debian 2.6.21-2-486 #1 Mon Jun 25 20:09:51 UTC 2007 i686
Build Date: 01 June 2007
Before reporting problems, check https://www.x.org/wiki/
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 11 19:33:02 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Videocard0"
(**) |-->Input Device "Keyboard1"
(**) |-->Input Device "Mouse0"
(**) Option "Xinerama" "0"
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(**) Extension "Composite" is enabled
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81e5f60
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 10b9,1695 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 10b9,524b card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:02:0: chip 10b9,524c card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:04:0: chip 10b9,1689 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:05:0: chip 10b9,5246 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:06:0: chip 10b9,5249 card 0000,0000 rev 00 class 06,04,01 hdr 01
(II) PCI: 00:07:0: chip 10b9,1563 card 1849,1563 rev 70 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 10b9,7101 card 1849,7101 rev 00 class 06,80,00 hdr 80
(II) PCI: 00:11:0: chip 10b9,5263 card 1849,5263 rev 40 class 02,00,00 hdr 00
(II) PCI: 00:12:0: chip 10b9,5229 card 1849,5229 rev c7 class 01,01,8a hdr 00
(II) PCI: 00:13:0: chip 10b9,5237 card 1849,5237 rev 03 class 0c,03,10 hdr 80
(II) PCI: 00:13:1: chip 10b9,5237 card 1849,5237 rev 03 class 0c,03,10 hdr 80
(II) PCI: 00:13:3: chip 10b9,5239 card 1849,5239 rev 01 class 0c,03,20 hdr 80
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 10de,01df card 10de,0366 rev a1 class 03,00,00 hdr 00
(II) PCI: 04:05:0: chip 109e,0350 card 0000,0000 rev 12 class 04,00,00 hdr 00
(II) PCI: 04:06:0: chip 1102,0002 card 1102,8061 rev 07 class 04,01,00 hdr 80
(II) PCI: 04:06:1: chip 1102,7002 card 1102,0020 rev 07 class 09,80,00 hdr 80
(II) PCI: 04:07:0: chip 1106,3044 card 1106,3044 rev 46 class 0c,00,10 hdr 00
(II) PCI: End of PCI scan
et voici le xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder3) Fri Dec 15 10:12:14 PST 2006
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 1.0 (buildmeister@builder3) Wed Nov 1 19:48:08 PST 2006
Section "ServerLayout"
Identifier "Default Layout"
Screen "Screen0" 0 0
InputDevice "Keyboard1" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "ServerFlags"
EndSection
Section "InputDevice"
Identifier "Keyboard1"
Driver "kbd"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
Option "XkbOptions" "compose:rwin"
EndSection
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "HP w19"
HorizSync 30.0 - 83.0
VertRefresh 48.0 - 75.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nv"
VendorName "NVIDIA Corporation"
BoardName "GeForce 7300 GS"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Option "RenderAccel" "true"
Option "metamodes" "1440x900 +0+0; 832x624 +0+0; 800x600 +0+0; 640x480 +0+0"
Option "AddARGBGLXVisuals" "On"
Option "XAANoOffscreenPixmaps"
SubSection "Display"
Depth 24
Modes "1440x900" "1280x1024" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
voila si quelqu'un pourrait m'aider apparement le probleme viendrait de glx mais meme en le commentant j'ai le probléme.
merci de votre aide
Configuration: Linux
Firefox 2.0.0.4
32 réponses
Un problème de driver NVIDIA survient avec une GeForce 7300 GS lors de l'installation du driver propriétaire, après vérification des kernel headers et sources sous Debian. Le fichier Xorg.0.log et la configuration xorg.conf indiquent que le pilote libre nv peut encore être actif et que l'erreur semble liée à glx, malgré l'installation du pilote Nvidia. Des étapes recommandées incluent l'installation des paquets gcc, make et linux-headers, la création d'un lien /usr/src/linux, puis l'arrêt du serveur X et l'exécution de l'installateur NVIDIA. En cas d'échec, transmettre le message d'erreur exact et vérifier la compatibilité du kernel et des paquets installés avec la version du driver NVIDIA.
    Le truc c'est que le log que nous a donné ne nous aide pas car ce sont les lignes (WW) (warnings) et (EE) (errors) qui peuvent nous aider. En fait c'est normal car tu utilises encore le driver libre (nv) et non le driver propriétaire dans /etc/X11/xorg.conf.
    Voici ma conf (sachant que ça marche chez moi)
    - debian lenny,
    - carte nvidia 6600GT,
    - noyau 2.6.18-4-686,
    - driver nvidia NVIDIA-Linux-x86-100.14.11-pkg1.run,
    - gcc 4.1.3,
    - xserver-xorg 1:7.2-5
    Vérifie au préalable que tu as installé les paquets requis pour installer le driver, ie gcc, g++, make les linux headers de ton noyau. En root :
    aptitude install linux-headers-`uname -r` make gcc g++
    Ensuite crée un lien /usr/src/linux qui va pointer sur les bons headers
    rm /usr/src/linux
    ln -s /usr/src/linux-headers-`uname -r` /usr/src/linux
    Installe le driver après avoir éteint ton serveur X (au besoin remplacer kdm par xdm ou gdm selon ce que tu utilises). Pour celà quitte ta session graphique, passe en mode texte (ctrl alt f1), et loggue toi en root :
    /etc/init.d/kdm stop
    cd /le/repertoire/du/script/nvidia
    chmod +x NVIDIA-Linux-x86-100.14.11-pkg1.run
    ./NVIDIA-Linux-x86-100.14.11-pkg1.run
    Si tout va bien c'est presque dans la poche, sinon remonte nous l'erreur. En particulier vérifie aussi dans les logs nvidia que tout s'est bien passé. Normalement le script nvidia met à jour tout seul /etc/X11/xorg.conf, vérifie qu'il a bien mis le driver nvidia et pas nv :
    Section "Device"
            Identifier      "nVidia Corporation NV43 [GeForce 6600 GT]"
            Driver          "nvidia"
            BusID           "PCI:3:0:0"
    EndSection
    Il suffit de relancer le serveur X :
    /etc/init.d/kdm restart
    Au besoin, pour passer en mode graphique appuies sur ctrl alt f7.
    Bonne chance
    1. bonjour,
      Merci mamimendo pour ta réponse.
      voila je viens d'essayer de compiler le driver et voila ce que j'obtiens dans : /var/log/nvidia-installer.log
      ***coupé***
      FATAL: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol 'para
      virt_ops'
      make[3]: *** [__modpost] Erreur 1
      make[2]: *** [modules] Erreur 2
      NVIDIA: left KBUILD.
      nvidia.ko failed to build!
      make[1]: *** [module] Erreur 1
      make: *** [module] Erreur 2
      -> Error.
      ERROR: Unable to build the NVIDIA kernel module.
      ERROR: Installation has failed. Please see the file
      '/var/log/nvidia-installer.log' for details. You may find suggestions
      on fixing installation problems in the README available on the Linux
      driver download page at www.nvidia.com.
      voila je recherche aussi de mon coté
      bonne soirée
      fabrice
        salut
        il va falloir recompiler son noyau et desactiver la paravirtualisation !!!
        pour le savoir =>
        tufs@debian:~$ grep -i paravirt /boot/config-`uname -r`
        # CONFIG_PARAVIRT is not set
        depuis les versions 2.6.20 et 2.6.21 peut-etre pas ou plus pour le 2.6.22
        1. SAlut tufs,
          tux@debian:~$ grep -i paravirt /boot/config-`uname -r`
          CONFIG_PARAVIRT=y
          bah voilà c'est yes.
          bon plus qu'a recompiler un noyau 2.6.22
          je vous tiens au courant
          bonne soirée
          fabrice
            Pourquoi tu n'utilises pas tout simplement une linux-image qui marche directement ?
            Moi je n'ai pas recompilé de noyau j'ai juste installé les paquets standards :
            aptitude install linux-image-2.6.18-4-i686 linux-headers-2.6.18-4-i686
            Reboote sur ce noyau et tente de recompiler ton driver nvidia sur ce noyau et ca devrait rouler.
            Si le driver nvidia marche un coup mais pas les fois suivantes voilà la bidouille que j'ai faite.
            Commente dans le script /etc/init.d/nvidia-glx (en root) ce passage :
            case "$1" in
              start|restart|reload|force-reload)
            #    if [ "$USE_TLS" = "1" ]
            #    then
            #      setup_links
            #    elif [ "$USE_TLS" = "0" ]
            #    then
            #      remove_links
            #    fi
            #    rm -f  /usr/lib/libGL.so || true
            #    if [ -L /usr/lib/nvidia/libGL.so.xlibmesa ] && [ -d /usr/share/doc/libgl1-mesa-dev ] ; then
            #       ln -s /usr/lib/nvidia/libGL.so.1.2.xlibmesa /usr/lib/libGL.so
            #    fi
            #    if [ -d /usr/share/doc/nvidia-glx-dev ] ; then
            #        ln -s /usr/lib/libGL.so.1.0.8776 /usr/lib/libGL.so
            #    fi
              stop)
                echo "Usage: /etc/init.d/nvidia-glx {start|stop|restart|reload|force-reload}"
                exit 1
            esac
            exit 0
            Je n'ai pas trop cherché à creuser ce qui était foireux je peux juste te dire que maintenant je suis tranquille ;)
            Bonne chance
              hi ,
              Si tu utilises les paquets standarts du genre un 2.6.18 tu ne rencontreras pas de problem de paravirt_ops
              Alors dans se cas precis la recompilation n est pas necessaire du moins pour nVidia la regression est apparue à partir du 2.6.20 seulement .....
              Mais bon il est claire que si tu veux passer à une version superieur pour raison x.y.z la recompilation est inevitable dans se cas "processor type and features" et tu desactives
              "la paravirtualization support" tu enregistres ...et ça devrait etre bon ...
              voilà bonne chance ....
              1. SAlut,
                Aprés recompile d'un noyau 2.6.22.1,
                j'ai enlevé le "processor type and features" et tu desactives "la paravirtualization support"
                mais ça ne marche pas : ci dessous
                tux@debian:~$ cat /var/log/Xorg.0.log | grep EE
                (II) Loading extension MIT-SCREEN-SAVER
                (EE) Failed to load module "glx" (module does not exist, 0)
                bon je vais essayer de bidouiller le script nvidia comme me préconisait mamiemando.
                bonne soirée
                1. salut,
                  bon je galére j'ai rien trouvé
                  donc en desactivant la paravirtualisation dans le noyau du kernel, j'obtiens cette erreur :
                  (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
                  tux@debian:~$ cat /var/log/Xorg.0.log | grep WW
                  (WW) NV(0): Option "RenderAccel" is not used
                  (WW) NV(0): Option "metamodes" is not used
                  (WW) NV(0): Option "AddARGBGLXVisuals" is not used
                  tux@debian:~$
                  bon ya toujours gls ki deconne, mais meme en le desactivant j'ai cette erreur.
                  sinon dans les Warnings, je ne sais pas trop quoi faire, apparement il me manque des polices
                  merci de votre aide
                  bonne soirée
                  fabss
                    A mon avis tu te prendrais moins la tête si tu faisais ce que je t'ai dit. Maintenant tu es libre ;)
                    1. Salut mamiemendo,
                      J'ai essayé comme tu m'as dit :
                      il ne trouve pas le noyau.
                      Aprés recompile du noyau 2.6.22.1 sans la paravirtualisation, le driver nvidia s'installe bien mais j'ai le probleme de glx. (meme en commentant load "glx" dans le xorg)
                      aprés je commente le script nvidia-glx aux lignes que tu m'as dit.
                      rien y fait j'ai toujours le problème de glx.
                      Aprés je fais un aptitute install cyrillic, c'est une police russe, j'arrive l'installer, mais c'est bizarre, il me demande qu'elle langue mais seulement russe mon clavier est !!!
                      Pour le problème de truetype j'avoue que je ne comprends pas.
                      voilà je tourne en rond.
                      Je suis dispo pour vos solutions
                      je vous remercie et je continuerais les recherches ce soir.
                        re
                        Il faut peut-tre commenté [ # ] les lignes suivantes => [ xorg.conf]
                        # Load "GLcore"
                        # Load "dri"
                        tu peux modifier le fichier /etc/modules comme suit =>{ en root]
                        grep -q ^nvidia /etc/modules || echo nvidia >> /etc/modules
                        Sinon pourquoi ne pas utiliser la methode debian pour installer tes drivers nVidia =>
                        pour desinstaller le .run
                        * Stop X
                        * login as root
                        * # nvidia-installer --uninstall
                        La methode Debian preconisé sur le site Debian-Wiki que voicie =>https://wiki.debian.org/NvidiaGraphicsDrivers
                        apt-get update && apt-get dist-upgrade
                        apt-get install module-assistant gcc nvidia-kernel-common build-essential
                        # m-a prepare
                        # m-a auto-install nvidia
                        # apt-get install nvidia-glx
                        # depmod -a
                        # modprobe nvidia
                        # dpkg-reconfigure xserver-xorg ( tu choisie nVidia )
                        Et voir si ça marche pas mieux );-
                        Bonne chance .....
                        1. tu a l'application envy qui va se charger d'installer tous ce qu'il te faut
                            Au temps pour moi j'ai fait une erreur c'est 686 pas i686.
                            En fait il faut installer une linux-image et un linux-header correspondant, présent quand tu fais un apt-cache search.
                            Exemple :
                            (mando@aldur) (~) $ apt-cache search linux-image | grep 686
                            linux-headers-2.6.18-4-686 - Header files for Linux 2.6.18 on PPro/Celeron/PII/PIII/P4
                            linux-image-2.6.18-4-686 - Linux 2.6.18 image on PPro/Celeron/PII/PIII/P4
                            Il suffit ensuite de les installer. Il faudra en plus gcc et make de mémoire donc va les installer en même temps : en root :
                            aptitude install linux-headers-2.6.18-4-686 linux-image-2.6.18-4-686 gcc make
                            Reboote sur ce noyau.
                            Ensuite récupère le script d'installation fourni sur le site de nvidia. Moi par exemple j'ai récupéré à l'époque NVIDIA-Linux-x86-100.14.11-pkg1.run. Passe en mode texte (ctrl alt f1) et loggue toi en root Place toi dans le répertoire dans lequel tu as enregistré le script. Tape ensuite :
                            chmod +x  NVIDIA-Linux-*
                            ./NVIDIA-Linux-*
                            (i ce n'est pas kdm mais gdm ou xdm je te laisse adapter, le but étant d'éteindre le serveur X le temps de l'installation). A la fin de l'installation il devrait adapter ton fichier /etc/X11/xorg.conf. Ensuite patch le fichier /etc/init.d/nvidia-glx comme je t'ai indiqué :
                            nano /etc/init.d/nvidia-glx
                            Sauve et quitte (ctrl x) et relance ton serveur X :
                            Normalement ça devrait marcher
                            1. salut tufs,
                              donc j'ai essayé par le méthode debian et pareil je ne demarre pas.
                              voici le log du : tux@debian:~$ cat /var/log/Xorg.0.log | grep EE
                              (EE) AIGLX: Screen 0 is not DRI capable
                              j'ai meme pas de module "dri" dans mon nouveau xorg, enfin j'en ai peu marre donc je réfléchis au gros travaux !!!
                              voici le nouveau xorg.conf :
                              tux@debian:~$ cat /etc/X11/xorg.conf
                              # xorg.conf (xorg X Window System server configuration file)
                              # This file was generated by dexconf, the Debian X Configuration tool, using
                              # values from the debconf database.
                              # Edit this file with caution, and see the xorg.conf manual page.
                              # (Type "man xorg.conf" at the shell prompt.)
                              # This file is automatically updated on xserver-xorg package upgrades *only*
                              # if it has not been modified since the last upgrade of the xserver-xorg
                              # package.
                              # If you have edited this file but would like it to be automatically updated
                              # again, run the following command:
                              # sudo dpkg-reconfigure -phigh xserver-xorg
                              Section "Files"
                              EndSection
                              Identifier "Generic Keyboard"
                              Driver "kbd"
                              Option "CoreKeyboard"
                              Option "XkbRules" "xorg"
                              Option "XkbModel" "pc101"
                              Option "XkbVariant" "latin9"
                              EndSection
                              Identifier "Configured Mouse"
                              Driver "mouse"
                              Option "CorePointer"
                              Option "Protocol" "ExplorerPS/2"
                              Option "Emulate3Buttons" "true"
                              EndSection
                              Section "Device"
                              Identifier "nVidia Corporation G71 [GeForce 7300 GS]"
                              Driver "nv"
                              BusID "PCI:1:0:0"
                              VideoRam 256
                              EndSection
                              Section "Monitor"
                              Identifier "Écran générique"
                              Option "DPMS"
                              HorizSync 30-100
                              VertRefresh 50-160
                              EndSection
                              Section "Screen"
                              Identifier "Default Screen"
                              Device "nVidia Corporation G71 [GeForce 7300 GS]"
                              Monitor "Écran générique"
                              DefaultDepth 24
                              Modes "1440x900"
                              EndSubSection
                              EndSection
                              Screen "Default Screen"
                              InputDevice "Generic Keyboard"
                              InputDevice "Configured Mouse"
                              EndSection
                              j'ai un peu cherché sur le google, effectivement j'ai beryl d'installé, mais je l'ai désactivé.
                              voila bonne soirée
                              fab
                                re
                                edite ton xorg.conf et remplace la linge suivante =>
                                Section "Device"
                                Driver "nvidia"
                                BusID "PCI:1:0:0"
                                VideoRam 256
                                EndSection
                                ok tu enregistres et un ctrl+alt+backspace
                                1. hello,
                                  1 : tufs
                                  j'ai deja essayé avec le driver nvidia et j'obtiens l'erreur de "dri", lorsque j'ai édité le xorg.conf je l'ai édité sous x afin de pouvoir demarrer d'ou le "nv".
                                  2 : mamiemendo
                                  en fait j'ai oublié de te dire cet aprem que j'avais le noyau vmlinuz-2.6.18-4-486 deja en stock.
                                  et que j'ai rebooté dessus, et lorsque que j'ai voulu installer le nvidia propriétaire apres avoir commentait le nvidia-glx, j'avais un message du style : unable to install nvidia driver ou un truc du genre..j'avoue que j'ai pas regardé le log du nvidia-installer à cette époque.
                                  bon je cherche et merci pour votre aide.
                                  bonne soirée
                                    ok
                                    daccord comment-tu fais pour avoir le message suivant :
                                    l erreur suivante est due au fait que le serveur X essaie de charger le module DRI
                                    mais si tu l as commenté il ne devrait pas le charger << OK
                                    dans se cas refait un dpkg-reconfigure xserver-xorg pour remettre ton xorg.conf au propre
                                    puis tu recommences l installation des drivers en suivant le principe si-dessus ( post 12 )
                                    tu ne commentes rien du tout tu remplaces juste nv par nvidia << ok
                                    lors de la configuration de xorg.conf
                                    relance la machine et si X plante colle moi le message d erreur ); Mercie
                                      fabss essaye déjà la méthode de tufs et si ça marche pas on repart sur la mienne. Installe le noyau que je t'ai donné, au moins lui c'est sûr que ça marche.
                                      1. salut,
                                        1 - tufs
                                        oki voici les logs :
                                        (EE) Failed to load module "nvidia" (module does not exist, 0)
                                        (EE) No drivers available.
                                        debian:~# cat xorg.log.1 | grep WW
                                        2 - Mamiemendo
                                        Juste pour te dire que je n'ai pas un pentium mais un AMD64. Je ne sais pas si ce noyau peut poser problemes ?
                                        fab
                                        • 1
                                        • 2
