Problème Java
J'utilise regulièrement Java pour Un jeu nommé Runescape (3D) et parfois j'obtien des fichiers textes només :
hs_err_pid3916
hs_err_pid5004
Quesque c'est ?
Merci de vos Répnses
hs_err_pid3916
hs_err_pid5004
Quesque c'est ?
voici le fichier hs_err_pid5004 :
# A fatal error has been detected by the Java Runtime Environment:
# Internal Error (safepoint.cpp:562), pid=5004, tid=2744
# Error: Deadlock in safepoint code. Should have called back to the VM before blocking.
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) Client VM (16.3-b01 mixed mode, sharing windows-x86 )
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x01e9f800): JavaThread "Finalizer" daemon [_thread_in_native_trans, id=2744, stack(0x04780000,0x047d0000)]
Stack: [0x04780000,0x047d0000], sp=0x047ce918, free space=13a047ce928k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V [jvm.dll+0x1f4180]
V [jvm.dll+0xa1d78]
V [jvm.dll+0x1a02e2]
V [jvm.dll+0x1dc33e]
V [jvm.dll+0x115b]
V [jvm.dll+0xf7ed6]
C [sw3d.dll+0x6cc0f]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J fa.pa()V
J fn.a(Lv;I)V
J fa.finalize()V
v ~StubRoutines::call_stub
J java.lang.ref.Finalizer.invokeFinalizeMethod(Ljava/lang/Object;)V
J java.lang.ref.Finalizer.runFinalizer()V
J java.lang.ref.Finalizer$FinalizerThread.run()V
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x04e99400 JavaThread "Thread-22" daemon [_thread_blocked, id=5064, stack(0x0cc30000,0x0cc80000)]
0x04e99c00 JavaThread "Thread-21" daemon [_thread_in_native, id=1412, stack(0x0cba0000,0x0cbf0000)]
0x04e99000 JavaThread "Thread-18" daemon [_thread_blocked, id=3832, stack(0x09110000,0x09160000)]
0x04e97c00 JavaThread "Thread-17" daemon [_thread_blocked, id=1556, stack(0x08d40000,0x08d90000)]
0x04e97000 JavaThread "Java Sound Event Dispatcher" daemon [_thread_blocked, id=1972, stack(0x07d80000,0x07dd0000)]
0x04e95400 JavaThread "Thread-14" daemon [_thread_blocked, id=4316, stack(0x06aa0000,0x06af0000)]
0x04e98800 JavaThread "Thread-13" daemon [_thread_blocked, id=4408, stack(0x06130000,0x06180000)]
0x04e97800 JavaThread "Thread-12" daemon [_thread_blocked, id=4032, stack(0x05030000,0x05080000)]
0x04e96000 JavaThread "thread applet-loader.class-1" [_thread_blocked, id=4744, stack(0x05c10000,0x05c60000)]
0x04e96c00 JavaThread "AWT-EventQueue-2" [_thread_blocked, id=4036, stack(0x05520000,0x05570000)]
0x04e96400 JavaThread "Applet 1 LiveConnect Worker Thread" [_thread_blocked, id=3708, stack(0x05b80000,0x05bd0000)]
0x04e95800 JavaThread "Browser Side Object Cleanup Thread" [_thread_blocked, id=4684, stack(0x05af0000,0x05b40000)]
0x04e94c00 JavaThread "Windows Tray Icon Thread" [_thread_in_native, id=4060, stack(0x058f0000,0x05940000)]
0x04e94800 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=4300, stack(0x05860000,0x058b0000)]
0x04e92000 JavaThread "CacheMemoryCleanUpThread" daemon [_thread_blocked, id=4592, stack(0x057d0000,0x05820000)]
0x04e6b800 JavaThread "Java Plug-In Heartbeat Thread" [_thread_blocked, id=1036, stack(0x05640000,0x05690000)]
0x04e6b400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=2404, stack(0x055b0000,0x05600000)]
0x04e67800 JavaThread "AWT-Windows" daemon [_thread_blocked, id=5084, stack(0x05490000,0x054e0000)]
0x04e65000 JavaThread "AWT-Shutdown" [_thread_blocked, id=4240, stack(0x05400000,0x05450000)]
0x01f5f800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2884, stack(0x05370000,0x053c0000)]
0x01ef8800 JavaThread "Java Plug-In Pipe Worker Thread (Client-Side)" daemon [_thread_in_native, id=3840, stack(0x050c0000,0x05110000)]
0x01f5a800 JavaThread "Timer-0" [_thread_blocked, id=3564, stack(0x04d50000,0x04da0000)]
0x01f07400 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=4480, stack(0x04ae0000,0x04b30000)]
0x01eb1800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=5008, stack(0x049c0000,0x04a10000)]
0x01eacc00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2748, stack(0x04930000,0x04980000)]
0x01ea9800 JavaThread "Attach Listener" daemon [_thread_blocked, id=2796, stack(0x048a0000,0x048f0000)]
0x01ea8800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4264, stack(0x04810000,0x04860000)]
=>0x01e9f800 JavaThread "Finalizer" daemon [_thread_in_native_trans, id=2744, stack(0x04780000,0x047d0000)]
0x01e9e000 JavaThread "Reference Handler" daemon [_thread_blocked, id=2740, stack(0x046f0000,0x04740000)]
0x002d9800 JavaThread "main" [_thread_blocked, id=2736, stack(0x00310000,0x00360000)]
Other Threads:
0x01e9d000 VMThread [stack: 0x04660000,0x046b0000] [id=2948]
0x01ec5c00 WatcherThread [stack: 0x04a50000,0x04aa0000] [id=1444]
VM state:synchronizing (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x002d78f0] Threads_lock - owner thread: 0x01e9d000
[0x002d7d00] Heap_lock - owner thread: 0x04e98800
Heap
def new generation total 22016K, used 19584K [0x2df80000, 0x2f760000, 0x30180000)
eden space 19584K, 100% used [0x2df80000, 0x2f2a0000, 0x2f2a0000)
from space 2432K, 0% used [0x2f2a0000, 0x2f2a0000, 0x2f500000)
to space 2432K, 0% used [0x2f500000, 0x2f500000, 0x2f760000)
tenured generation total 48724K, used 26717K [0x30180000, 0x33115000, 0x34580000)
the space 48724K, 54% used [0x30180000, 0x31b975b8, 0x31b97600, 0x33115000)
compacting perm gen total 12288K, used 8586K [0x34580000, 0x35180000, 0x38580000)
the space 12288K, 69% used [0x34580000, 0x34de2be0, 0x34de2c00, 0x35180000)
ro space 10240K, 51% used [0x38580000, 0x38aaae00, 0x38aaae00, 0x38f80000)
rw space 12288K, 54% used [0x38f80000, 0x396172d8, 0x39617400, 0x39b80000)
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files (x86)\Java\jre6\bin\java.exe
0x77590000 - 0x77710000 C:\Windows\SysWOW64\ntdll.dll
0x75460000 - 0x75560000 C:\Windows\syswow64\kernel32.dll
0x75df0000 - 0x75e36000 C:\Windows\syswow64\KERNELBASE.dll
0x75b60000 - 0x75c00000 C:\Windows\syswow64\ADVAPI32.dll
0x770e0000 - 0x7718c000 C:\Windows\syswow64\msvcrt.dll
0x75350000 - 0x75369000 C:\Windows\SysWOW64\sechost.dll
0x75c00000 - 0x75cf0000 C:\Windows\syswow64\RPCRT4.dll
0x75100000 - 0x75160000 C:\Windows\syswow64\SspiCli.dll
0x750f0000 - 0x750fc000 C:\Windows\syswow64\CRYPTBASE.dll
0x72e20000 - 0x72e6b000 C:\Windows\system32\apphelp.dll
0x73f30000 - 0x73fbc000 C:\Windows\AppPatch\AcLayers.DLL
0x75600000 - 0x75700000 C:\Windows\syswow64\USER32.dll
0x753d0000 - 0x75460000 C:\Windows\syswow64\GDI32.dll
0x75340000 - 0x7534a000 C:\Windows\syswow64\LPK.dll
0x75960000 - 0x759fd000 C:\Windows\syswow64\USP10.dll
0x760c0000 - 0x76d09000 C:\Windows\syswow64\SHELL32.dll
0x75370000 - 0x753c7000 C:\Windows\syswow64\SHLWAPI.dll
0x75a00000 - 0x75b5c000 C:\Windows\syswow64\ole32.dll
0x77020000 - 0x770af000 C:\Windows\syswow64\OLEAUT32.dll
0x72b90000 - 0x72ba7000 C:\Windows\system32\USERENV.dll
0x734a0000 - 0x734ab000 C:\Windows\system32\profapi.dll
0x731e0000 - 0x73231000 C:\Windows\system32\WINSPOOL.DRV
0x72520000 - 0x72532000 C:\Windows\system32\MPR.dll
0x76fc0000 - 0x77020000 C:\Windows\system32\IMM32.DLL
0x75ff0000 - 0x760bc000 C:\Windows\syswow64\MSCTF.dll
0x7c340000 - 0x7c396000 C:\Program Files (x86)\Java\jre6\bin\msvcr71.dll
0x6d800000 - 0x6da97000 C:\Program Files (x86)\Java\jre6\bin\client\jvm.dll
0x72590000 - 0x725c2000 C:\Windows\system32\WINMM.dll
0x6d7b0000 - 0x6d7bc000 C:\Program Files (x86)\Java\jre6\bin\verify.dll
0x6d330000 - 0x6d34f000 C:\Program Files (x86)\Java\jre6\bin\java.dll
0x6d290000 - 0x6d298000 C:\Program Files (x86)\Java\jre6\bin\hpi.dll
0x75160000 - 0x75165000 C:\Windows\syswow64\PSAPI.DLL
0x6d7f0000 - 0x6d7ff000 C:\Program Files (x86)\Java\jre6\bin\zip.dll
0x6d430000 - 0x6d436000 C:\Program Files (x86)\Java\jre6\bin\jp2native.dll
0x6d1d0000 - 0x6d1e3000 C:\Program Files (x86)\Java\jre6\bin\deploy.dll
0x75e40000 - 0x75f5c000 C:\Windows\syswow64\CRYPT32.dll
0x75750000 - 0x7575c000 C:\Windows\syswow64\MSASN1.dll
0x75cf0000 - 0x75de4000 C:\Windows\syswow64\WININET.dll
0x75560000 - 0x75563000 C:\Windows\syswow64\Normaliz.dll
0x75200000 - 0x75335000 C:\Windows\syswow64\urlmon.dll
0x76d10000 - 0x76f09000 C:\Windows\syswow64\iertutil.dll
0x6d6b0000 - 0x6d6f4000 C:\Program Files (x86)\Java\jre6\bin\regutils.dll
0x73830000 - 0x73839000 C:\Windows\system32\VERSION.dll
0x6d610000 - 0x6d623000 C:\Program Files (x86)\Java\jre6\bin\net.dll
0x75920000 - 0x75955000 C:\Windows\syswow64\WS2_32.dll
0x77560000 - 0x77566000 C:\Windows\syswow64\NSI.dll
0x73720000 - 0x7375c000 C:\Windows\system32\mswsock.dll
0x74d60000 - 0x74d66000 C:\Windows\System32\wship6.dll
0x6d630000 - 0x6d639000 C:\Program Files (x86)\Java\jre6\bin\nio.dll
0x6d000000 - 0x6d14a000 C:\Program Files (x86)\Java\jre6\bin\awt.dll
0x734f0000 - 0x7368e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16385_none_421189da2b7fabfc\COMCTL32.dll
0x72540000 - 0x72553000 C:\Windows\system32\DWMAPI.DLL
0x72f70000 - 0x72ff0000 C:\Windows\system32\uxtheme.dll
0x72ff0000 - 0x73034000 C:\Windows\system32\dnsapi.DLL
0x731c0000 - 0x731dc000 C:\Windows\system32\iphlpapi.DLL
0x731b0000 - 0x731b7000 C:\Windows\system32\WINNSI.DLL
0x6d230000 - 0x6d284000 C:\Program Files (x86)\Java\jre6\bin\fontmanager.dll
0x6d1a0000 - 0x6d1c3000 C:\Program Files (x86)\Java\jre6\bin\dcpr.dll
0x73040000 - 0x73045000 C:\Windows\System32\wshtcpip.dll
0x74a70000 - 0x74a94000 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x74a60000 - 0x74a66000 C:\Windows\system32\rasadhlp.dll
0x74630000 - 0x74668000 C:\Windows\System32\fwpuclnt.dll
0x73170000 - 0x73186000 C:\Windows\system32\CRYPTSP.dll
0x73110000 - 0x7314b000 C:\Windows\system32\rsaenh.dll
0x727f0000 - 0x72800000 C:\Windows\system32\NLAapi.dll
0x74cf0000 - 0x74cf8000 C:\Windows\System32\winrnr.dll
0x74ce0000 - 0x74cf0000 C:\Windows\system32\napinsp.dll
0x74cc0000 - 0x74cd2000 C:\Windows\system32\pnrpnsp.dll
0x6d7a0000 - 0x6d7af000 C:\Program Files (x86)\Java\jre6\bin\unpack.dll
0x10000000 - 0x1000d000 C:\Windows\.jagex_cache_32\runescape\jagmisc.dll
0x6d520000 - 0x6d544000 C:\Program Files (x86)\Java\jre6\bin\jsound.dll
0x6d550000 - 0x6d558000 C:\Program Files (x86)\Java\jre6\bin\jsoundds.dll
0x6f1d0000 - 0x6f242000 C:\Windows\system32\DSOUND.dll
0x73080000 - 0x730a5000 C:\Windows\system32\POWRPROF.dll
0x75780000 - 0x7591d000 C:\Windows\syswow64\SETUPAPI.dll
0x751d0000 - 0x751f7000 C:\Windows\syswow64\CFGMGR32.dll
0x75760000 - 0x75772000 C:\Windows\syswow64\DEVOBJ.dll
0x6ecf0000 - 0x6ed29000 C:\Windows\system32\MMDevAPI.DLL
0x72e70000 - 0x72f65000 C:\Windows\system32\PROPSYS.dll
0x6e4f0000 - 0x6e520000 C:\Windows\system32\wdmaud.drv
0x740e0000 - 0x740e4000 C:\Windows\system32\ksuser.dll
0x74b70000 - 0x74b77000 C:\Windows\system32\AVRT.dll
0x6e5a0000 - 0x6e5d6000 C:\Windows\system32\AUDIOSES.DLL
0x73b10000 - 0x73b18000 C:\Windows\system32\msacm32.drv
0x72560000 - 0x72574000 C:\Windows\system32\MSACM32.dll
0x6de80000 - 0x6de87000 C:\Windows\system32\midimap.dll
0x75f60000 - 0x75fe3000 C:\Windows\syswow64\CLBCatQ.DLL
0x6d360000 - 0x6d366000 C:\Program Files (x86)\Java\jre6\bin\jawt.dll
0x73df0000 - 0x73f25000 C:\Windows\.jagex_cache_32\runescape\sw3d.dll
VM Arguments:
jvm_args: -D__jvm_launched=460774322 -Xbootclasspath/a:C:\\PROGRA~2\\Java\\jre6\\lib\\deploy.jar;C:\\PROGRA~2\\Java\\jre6\\lib\\javaws.jar;C:\\PROGRA~2\\Java\\jre6\\lib\\plugin.jar -Dsun.awt.warmup=true -Xmx102m -Dsun.java2d.noddraw=true -Dsun.plugin2.jvm.args=-D__jvm_launched=460774322 "-Xbootclasspath/a:C:\\\\PROGRA~2\\\\Java\\\\jre6\\\\lib\\\\deploy.jar;C:\\\\PROGRA~2\\\\Java\\\\jre6\\\\lib\\\\javaws.jar;C:\\\\PROGRA~2\\\\Java\\\\jre6\\\\lib\\\\plugin.jar" "-Djava.class.path=C:\\\\PROGRA~2\\\\Java\\\\jre6\\\\classes" -Dsun.awt.warmup=true --- -- -Xmx102m -Dsun.java2d.noddraw=true
java_command: sun.plugin2.main.client.PluginMain write_pipe_name=jpi2_pid4252_pipe3,read_pipe_name=jpi2_pid4252_pipe2
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files (x86)\Internet Explorer;;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Common Files\Microsoft Shared\Windows Live
USERNAME=SAYD Murtaza
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 37 Stepping 2, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 Build 7600
CPU:total 4 (8 cores per cpu, 2 threads per core) family 6 model 37 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
Memory: 4k page, physical 4051456k(2572176k free), swap 8101012k(6449908k free)
vm_info: Java HotSpot(TM) Client VM (16.3-b01) for windows-x86 JRE (1.6.0_20-b02), built on Apr 12 2010 13:52:23 by "java_re" with MS VC++ 7.1 (VS2003)
time: Thu Apr 22 10:46:49 2010
elapsed time: 2034 seconds -
Ce sont des fichiers de logs d'erreur générés par un programme qui a une certaine forme de dysfonctionnement.
Si ça t'aide, sache qu'une partie de ton jeu est programmée en langage Java, qu'une partie de ce code Java se sert de code programmé en un autre langage sous forme de librairies dll via quelque chose qui s'appelle JNI, et que c'est cette interface, JNI, qui génère ces fichiers de log lorsque quelque chose crashe quelque part.
Si tu ne comprends pas mon second paragraphe, tu peux probablement supprimer ces fichiers sans aucun souci. Comprendre ces fichiers d'erreur est un travail de programmeur :)
