Problème SQL
J'ai un problème, en mettant le script d'un debrideur Mu, j'ai sa qui s'affiche.
Je suis pas super fort donc sa serait sympas de bien expliqué.
PHP Error Message
Warning: mysql_connect() [function.mysql-connect]: Host '216.108.235.7' is not allowed to connect to this MySQL server in /home/a6795006/public_html/index.php on line 109
Free Web Hosting
PHP Error Message
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/a6795006/public_html/index.php on line 110
Free Web Hosting
PHP Error Message
Warning: mysql_query() [function.mysql-query]: Access denied for user 'nobody'@'localhost' (using password: NO) in /home/a6795006/public_html/index.php on line 113
Free Web Hosting
PHP Error Message
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in /home/a6795006/public_html/index.php on line 113
Free Web Hosting
PHP Error Message
Warning: mysql_result(): supplied argument is not a valid MySQL result resource in /home/a6795006/public_html/index.php on line 114
Free Web Hosting
PHP Error Message
Warning: mysql_close(): no MySQL-Link resource supplied in /home/a6795006/public_html/index.php on line 116
Free Web Hosting
PHP Error Message
Warning: mysql_connect() [function.mysql-connect]: Host '216.108.235.7' is not allowed to connect to this MySQL server in /home/a6795006/public_html/index.php on line 193
Free Web Hosting
PHP Error Message
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/a6795006/public_html/index.php on line 194
Free Web Hosting
PHP Error Message
Warning: mysql_query() [function.mysql-query]: Access denied for user 'nobody'@'localhost' (using password: NO) in /home/a6795006/public_html/index.php on line 200
Free Web Hosting
PHP Error Message
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in /home/a6795006/public_html/index.php on line 200
Free Web Hosting
Erreur SQL !
SELECT * FROM partner ORDER BY count DESC LIMIT 0,5
Merci de vos réponse.
Configuration: Windows Vista
Firefox 3.5.5
10 réponses
  1. Je dirai que tu as un problème avec ta fonction de connexion mysql_connect().
    Vérifie tes identifiants.
    1. c'est dans quel fichier qu'on modifie ?
      1. Warning: mysql_connect() [function.mysql-connect]: Host '216.108.235.7' is not allowed to connect to this MySQL server in /home/a6795006/public_html/index.php on line 109
        Faut savoir décrypter les messages d'erreur.
        1. merci, mais maintenant il n'y a que cette erreur et je n'arrive pas a l'enlever.
          PHP Error Message
          Free Web Hosting
          La ligne qui correspond:
          $nb_dl_ip = mysql_result($nb_download_j, 0);
          1. Merci, mais je n'est toujours pas trouver.
            PS: je suis un noob
            1. Essai de remplacer mysql_result() par mysql_fetch_array()
              1. merci, mais sa marche pas. si ta une autre idée sa serait sympa.
                1. quand tu dis "ça marche pas"... c'est a dire ? message d'erreur ?
                  Peux-tu me mettre tout le code correspondant à ta requête sql.
                  Utilise la balise <code> pour mettre ton code et pour plus de lisibilité.
              2. voial ce que sa met.
                PHP Error Message
                Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/a6795006/public_html/index.php on line 114
                Free Web Hosting
                Erreur SQL !
                No database selected
                1. Il faut que tu ai une connexion avec ta base de donnée avant de lancer une requête.
                  $mysql_id = mysql_connect('serveur', 'identifiant', 'mot de passe');
                  mysql_select_db('base de donnée', $mysql_id) or die(mysql_error());
