Problème Superkaramba & MDK 10 RC1
j'essaie d'installer Superkaramba 0.34 sur une Mandrake 10.
Lorsque je lance la configuration, voici ce que j'obtiens:
./configure --prefix=/usr
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking whether g++ supports -Wundef... no
checking whether g++ supports -Wno-long-long... no
checking whether g++ supports -Wnon-virtual-dtor... no
checking how to run the C++ preprocessor... /lib/cpp
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
J'ai pourtant installer tous les paquetages "développement" à l'installation.
J'ai aussi vérifier que les librairies c++ & g++ étaient bien présentes.
Pouvez-vous m'apporter des explications sur cette erreur, ou, éventuellement, une solution ?
D'avance, merci !
David.
  1. Salut,
    Je ne pourrai probablement pas t'aider, mais "par curiosité", que dit le fichier "config.log" ?
    bob
    1. salut
      quand j'étais sous mandrake, j'avais réussi à installer superkaramba. D'après ce que tu mets, tu l'installes d'après les sources. Je n'y connais hélas rien et ne peut t'aider pour ton message d'erreur, mais as-tu essayer d'installer une version rpm pour mandrake ? Ca devrait s'installer, y a pas de raison.
