Attaque par un virus help
Je crois que mon pc a ete infecte par un virus
ai active avast et depuis ai au moins 5 anti virus se declenche toute les5 min
Comment faire pour m en debarasse
vous remercie *
  1. hello(du travail pour malwarebyte, a priori plus d infection.
    1)Relance hijack et clique sur "Do a system scan only"
    Ensuite recherche ces lignes et coches les cases
    R3 - URLSearchHook: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTor0.dll
    O2 - BHO: EoRezoBHO - {64F56FC1-1272-44CD-BA6E-39723696E350} - C:\Program Files\EoRezo\EoAdv\EoRezoBHO.dll (file missing)
    O2 - BHO: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTor0.dll
    O3 - Toolbar: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTor0.dll
    O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
    O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
    O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
    O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe" /background
    O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE LOCAL')
    O4 - HKUS\S-1-5-19\..\RunOnce: [LSD_III] %systemroot%\LSD\end.cmd (User 'SERVICE LOCAL')
    O4 - HKUS\S-1-5-19\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'SERVICE LOCAL')
    O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE RÉSEAU')
    O4 - HKUS\S-1-5-20\..\RunOnce: [LSD_III] %systemroot%\LSD\end.cmd (User 'SERVICE RÉSEAU')
    O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
    O4 - HKUS\S-1-5-18\..\RunOnce: [LSD_III] %systemroot%\LSD\end.cmd (User 'SYSTEM')
    O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
    O4 - HKUS\.DEFAULT\..\RunOnce: [LSD_III] %systemroot%\LSD\end.cmd (User 'Default user')
    O23 - Service: Service Bonjour (Bonjour Service) - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
    Ensuite clique sur "Fix checked"
    2)• Télécharger CCLeaner et l'installer sur le bureau en refusant l'installation de la barre Yahoo.
    http://www.commentcamarche.net/telecharger/telecharger 168 ccleaner
    • Fermer toutes les applications
    • Lancer CCLeaner
    S'il n'est pas en Français cliquer sur Options, Setting, Language
    et sélectionner Français
    • cocher dans le menu Nettoyeur - onglet Windows :
    Internet Explorer: Fichiers Internet Temporaires, Cookies
    • Système: Vider la Poubelle, Fichiers Temporaires, Presse-papiers
    • Avancé: Vieilles données du Prefetch
    • Décocher dans le menu Options - sous-menu Avancé :
    Effacer uniquement les fichiers, du dossier temp de Windows, plus vieux que 48 heures
    • Cocher dans le menu Nettoyeur - onglet Applications : Internet: Sun Java
    • Cocher , si cela est possible, dans le menu Nettoyeur - onglet Applications :
    Firefox/Mozilla: Cache Internet, Cookies
    • Click sur Analyse
    • Click sur le bouton Lancer le nettoyage dans le menu Nettoyeur.
    • Click sur Registre
    • Sélectionner tout
    • Click sur Chercher des erreurs (En bas)
    Une fois le scan terminé sélectionner tout
    • Click sur Réparer les erreurs sélectionnées
    3)pare-feu gratuits:regle un seul pare feu sur un ordi.telecharge un des suivants ensuite deconnecte toi.
    puis desactive le pare feu windows(aller dans le centre de securite puis pare feu windows et la desactive le)
    puis installe celui de ton choix.
    je te conseille un des 2(en anglais mais simple avec le tuto qui est donne)
    Comodo pro Firewall
    http://www.commentcamarche.net/telecharger/telecharger 34055041 comodo firewall pro
    Tuto pour la 3.0
    https://infomars.fr/forum/index.php?showtopic=1225
    ou
    OnlineArmor :
    téléchargement:https://www.commentcamarche.net/telecharger/ 34055356 online armor personal firewall
    tutoriels:https://forum.pcastuces.com/sujet.asp?f=25&s=35606
    :http://www.malekal.com/tutorial_Online_Armor.ph
    il y en a d autres mais d apres les test de matousec en gratuit il n y en a pas bcp d autre.
    http://www.matousec.com/index.html
    il y a encore quelques petites choses que je te mettrai a la fin.
    1. EoRezoBHO
      à virer également
      1. R3 - URLSearchHook: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTor0.dll
        toolbar inutiles je pense...voir peut-être même dangereux non ?
        un coup de toolbar S&D ?
        1. il y en a des lignes infectes. soit avast est jamais mis a jour ou bien il faut changer tes mannieres de surfer sur le net car la cela fait pas mal tout de meme.
          1)passe cet antimalware, fait comme indique(on va voir ce qu il reconnait)
          Telecharges malwaresbytes antimalwares(MBAM) : egalement tres util sur pb de pub mais pas tous malheureusement
          Malwarebytes Anti-Malware: http://www.malwarebytes.org/mbam/program/mbam-setup.exe
          Tutoriel Malwarebytes Anti-Malware: https://forum.pcastuces.com/malwarebytes_antimalwares___tutoriel-f31s3.htm
          fais comme indique,mise a jour , scan complet en mode sans echec et les rapports.
          COLLE LE RAPPORT APRES SUPPRESSION MERCI.
          garde le et lance un scan tout les mois comme indique.
          si tu as ad aware tu peux desinstalle car il ne reconnait plus grand chose.
          2)refais un rapport hijack que tu colles.
          1. totobetourne attention "Spyware Guard 2008" ....je ne sait pas si MBAM va y faire ?
          2. voici le premier rapport
            Malwarebytes' Anti-Malware 1.31
            Version de la base de données: 1506
            Windows 5.1.2600 Service Pack 2
            16/12/2008 17:30:40
            mbam-log-2008-12-16 (17-30-40).txt
            Type de recherche: Examen complet (C:\|)
            Eléments examinés: 66603
            Temps écoulé: 28 minute(s), 6 second(s)
            Clé(s) du Registre infectée(s): 46
            Valeur(s) du Registre infectée(s): 13
            Elément(s) de données du Registre infecté(s): 0
            Dossier(s) infecté(s): 11
            Fichier(s) infecté(s): 53
            HKEY_CLASSES_ROOT\anvtrgrwarning.warningbho (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\anvtrgrwarning.warningbho.1 (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\xml.xml (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{500bca15-57a7-4eaf-8143-8c619470b13d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{500bca15-57a7-4eaf-8143-8c619470b13d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{500bca15-57a7-4eaf-8143-8c619470b13d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\xml.xml.1 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\Interface\{305043e5-f9d9-4b3a-a618-c4d0da8031ce} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\Interface\{536cba8a-9db6-45cf-8d65-f486c49242d5} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\Interface\{5c8b2a9c-24a0-4991-a74b-1e4931bd3a57} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\Interface\{df3f06c6-d443-48a8-bdf2-4e31f0554ebf} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\{5222008a-dd62-49c7-a735-7bd18ecc7350} (Rogue.VirusRemover) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{50e9d039-fb50-4020-a841-1d226ae52b22} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{64466b8e-20a7-4a4a-aff4-aad9ca68b52c} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{64466b8e-20a7-4a4a-aff4-aad9ca68b52c} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{64466b8e-20a7-4a4a-aff4-aad9ca68b52c} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{F5734812-E6A1-8833-ECA9-949B5B8A88BF} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{95e9bcc0-2e84-4500-8a9c-0b7a96769124} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{22C447D3-73A8-E1C7-C391-21BE4338CEBC} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\Typelib\{9233c3c0-1472-4091-a505-5580a23bb4ac} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\Typelib\{b3a0aa5c-9fa3-408d-8193-2a948ef51d2d} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\Typelib\{bae92f67-539c-41cd-9183-162bb40aaa0c} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{3b8fb116-d358-48a3-a5c7-db84f15cbb04} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{95e9bcc0-2e84-4500-8a9c-0b7a96769124} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{95e9bcc0-2e84-4500-8a9c-0b7a96769124} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extensions\{3b8fb116-d358-48a3-a5c7-db84f15cbb04} (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{60239d08-5e56-4fae-b596-9fa423e5d469} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{3679651b-7df2-42e4-8221-d43f3dd60974} (Trojan.Agent) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\spyware guard 2008 (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Spyware Guard 2008 (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Spyware Guard 2008 (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\pro antispyware 2009 4.6 (Rogue.ProAntispyware) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\AntiSpywareExpert (Rogue.AntiSpywareExpert) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\vrl32warning.warningbho (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\vrl32warning.warningbho.1 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\webmedia.chl (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Online Alert Manager (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IExplorer add-on (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Browser Toolbar (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\System Alert Popup (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\spyware guard (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Solt Lake Software (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{4a409fb7-42e8-eec2-35e8-792cf005ab91} (Adware.BHO) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{4a409fb7-42e8-eec2-35e8-792cf005ab91} (Adware.BHO) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{4e6615b5-a259-4e55-905f-7f9ce60b379d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{4e6615b5-a259-4e55-905f-7f9ce60b379d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\vrl32 (Rogue.VirusHeat) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\anvtrgr (Rogue.VirusHeat) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\spywareguard (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\iemodule (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\internetconnection (Trojan.Agent) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run\vmware hptray (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run\quicktime task (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\pro antispyware 2009 (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\eqsiksfhmxmldknz (Trojan.Agent) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Cognac (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\New Windows\Allow\*.securewebinfo.com (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\New Windows\Allow\*.safetyincludes.com (Trojan.Zlob) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\New Windows\Allow\*.securemanaging.com (Trojan.Zlob) -> Quarantined and deleted successfully.
            C:\Program Files\Spyware Guard 2008 (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\Program Files\Spyware Guard 2008\quarantine (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\Program Files\vrl32software (Rogue.AntiVirusLab) -> Quarantined and deleted successfully.
            C:\Program Files\WebMediaViewer (Trojan.Zlob) -> Quarantined and deleted successfully.
            C:\Program Files\AnvTrgrsoftware (Rogue.VirusTrigger) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009 (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\BASE (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\DELETED (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\SAVED (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Program Files\vrl32software\vrl32.exe (Rogue.VirusHeat) -> Quarantined and deleted successfully.
            C:\Program Files\AnvTrgrsoftware\AnvTrgr.exe (Rogue.VirusHeat) -> Quarantined and deleted successfully.
            C:\Program Files\Spyware Guard 2008\spywareguard.exe (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\WINDOWS\system32\msxml71.dll (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            C:\Program Files\WebMediaViewer\hpmun.dll (Trojan.Zlob) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Local Settings\Temp\qpgiqmsi2.exe (Rootkit.Zlob) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Local Settings\Temp\qpgiqmsi3.exe (Zlob.Agent) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Local Settings\Temp\_ad10.exe (Adware.Agent) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Local Settings\Temp\_ad1C.exe (Adware.Agent) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Local Settings\Temp\_ad26.exe (Adware.Agent) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Local Settings\Temp\_ad30.exe (Adware.Agent) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Local Settings\Temp\_ad3A.exe (Adware.Agent) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Microsoft\Internet Explorer\DLLs\ieModule.dll (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Microsoft\Internet Explorer\DLLs\moduleie.dll (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Microsoft\Internet Explorer\DLLs\nnmhmigfhb.dll (Trojan.Agent) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Microsoft\Protect\svhost.exe (Rogue.Installer) -> Quarantined and deleted successfully.
            C:\WINDOWS\system32\winscenter.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            C:\Program Files\Spyware Guard 2008\conf.cfg (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\Program Files\Spyware Guard 2008\mbase.vdb (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\Program Files\Spyware Guard 2008\quarantine.vdb (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\Program Files\Spyware Guard 2008\queue.vdb (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\Program Files\Spyware Guard 2008\uninstall.exe (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\Program Files\Spyware Guard 2008\vbase.vdb (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\Program Files\WebMediaViewer\hpmon.exe (Trojan.Zlob) -> Quarantined and deleted successfully.
            C:\Program Files\WebMediaViewer\hpmun.exe (Trojan.Zlob) -> Quarantined and deleted successfully.
            C:\Program Files\WebMediaViewer\qttask.exe (Trojan.Zlob) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\proas2009.exe (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081211182232285.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081211203619243.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081211234553366.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081213175414960.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081213182424762.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081213182604055.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081213182643922.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081213183051659.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081214191726487.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081215201214485.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081215202326824.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\LOG\20081216153404016.log (Rogue.ProAntispyware2009) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Application Data\Microsoft\Internet Explorer\Quick Launch\AntiSpywareExpert.lnk (Rogue.Antispyware) -> Quarantined and deleted successfully.
            C:\WINDOWS\system32\regsvr32.exe (Trojan.Agent) -> Quarantined and deleted successfully.
            C:\WINDOWS\sysexplorer.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Local Settings\Temp\29.tmp.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            C:\Documents and Settings\Admin\Bureau\Spyware Guard 2008.lnk (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\WINDOWS\reged.exe (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\WINDOWS\spoolsystem.exe (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\WINDOWS\sys.com (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\WINDOWS\syscert.exe (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\WINDOWS\vmreg.dll (Rogue.SpywareGuard) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Application Data\Microsoft\Protect\track.sys (Trojan.FakeAlert) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Menu Démarrer\Run Virus Scan.url (Trojan.Zlob) -> Quarantined and deleted successfully.
            C:\Documents and Settings\All Users\Menu Démarrer\Online Spyware Test.url (Trojan.Zlob) -> Quarantined and deleted successfully.
            C:\WINDOWS\system32\yozdbdrdhibrq.dll (Adware.BHO) -> Quarantined and deleted successfully.
            et voici le dernier rapport
            Scan saved at 17:38:18, on 16/12/2008
            MSIE: Internet Explorer v7.00 (7.00.5730.0011)
            Boot mode: Normal
            Running processes:
            C:\WINDOWS\System32\smss.exe
            C:\WINDOWS\system32\lsass.exe
            C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
            C:\Program Files\Alwil Software\Avast4\ashServ.exe
            C:\WINDOWS\Explorer.EXE
            C:\Program Files\Fichiers communs\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
            C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
            C:\WINDOWS\system32\slserv.exe
            C:\WINDOWS\lclock.exe
            C:\Program Files\Fichiers communs\Nero\Lib\NMBgMonitor.exe
            C:\Program Files\Microsoft ActiveSync\wcescomm.exe
            C:\PROGRA~1\MICROS~4\rapimgr.exe
            C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
            C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
            C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
            C:\Documents and Settings\Admin\Application Data\Microsoft\Live Search\Notification-LiveSearch.exe
            C:\Documents and Settings\Admin\Application Data\Microsoft\Live Search\Mise-a-jour-LiveSearch.exe
            C:\Program Files\Fichiers communs\Nero\Lib\NMIndexingService.exe
            C:\Program Files\Fichiers communs\Nero\Lib\NMIndexStoreSvr.exe
            C:\Program Files\Windows Live\Mail\wlmail.exe
            C:\Program Files\iPod\bin\iPodService.exe
            C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
            C:\Program Files\Windows Live\Messenger\usnsvc.exe
            C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
            R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
            R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = https://www.msn.com/fr-fr/?ocid=iehp
            R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = https://www.bing.com/?toHttps=1&redig=5FC791212101479BAFBE1A679848B1AF
            R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.bing.com/?toHttps=1&redig=5FC791212101479BAFBE1A679848B1AF
            R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://lo.st
            R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.google.fr/toolbar/ie8/sidebar.html
            R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://www.google.fr/keyword/%s
            R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
            R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
            O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
            O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
            O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
            O4 - HKCU\..\Run: [LClock] lclock.exe
            O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Fichiers communs\Nero\Lib\NMBgMonitor.exe"
            O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\Program Files\Microsoft ActiveSync\wcescomm.exe"
            O4 - Startup: Outil de notification Live Search.lnk = C:\Documents and Settings\Admin\Application Data\Microsoft\Live Search\Notification-LiveSearch.exe
            O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
            O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~1\Office12\EXCEL.EXE/3000
            O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~4\INetRepl.dll
            O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~4\INetRepl.dll
            O9 - Extra 'Tools' menuitem: Créer un Favori de l'appareil mobile... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~4\INetRepl.dll
            O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~1\Office12\REFIEBAR.DLL
            O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
            O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
            O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Fichiers communs\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
            O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
            O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
            O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
            O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
            O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
            O23 - Service: Service de l’iPod (iPod Service) - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
            O23 - Service: Nero BackItUp Scheduler 3 - Nero AG - C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
            O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Fichiers communs\Nero\Lib\NMIndexingService.exe
            O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
            O23 - Service: SmartLinkService (SLService) - - C:\WINDOWS\SYSTEM32\slserv.exe
        2. télechargez ici https://www.clubic.com/telecharger-fiche17891-hijackthis.html
          Lancez HijackThis en double cliquant sur son icône puis cliquez sur le bouton do a system scan and save a logfile
          Le rapport est retranscrit aussitôt apres le scan dans une fenêtre de type Bloc-notes
          il vous suffit de realiser un copier/coller et de le poster dans le forum
          1. bonjour
            telecharge cela:util pour voir ce que peut etre l infection et agir ensuite.
            http://www.commentcamarche.net/telecharger/telecharger 159 hijackthis
            installe le normallement comme tout autre programme dans c/programme/...............
            clique sur do a scan and save a logfile, tu obtiens un rapport que tu colles.
            1. voici le rapport
              Scan saved at 15:56:58, on 16/12/2008
              Boot mode: Normal
              Running processes:
              C:\DOCUME~1\Admin\LOCALS~1\Temp\29.tmp.exe
              C:\Program Files\Internet Explorer\iexplore.exe
              O2 - BHO: searchersmart search enhancer - {4A409FB7-42E8-EEC2-35E8-792CF005AB91} - C:\WINDOWS\system32\yozdbdrdhibrq.dll
              O2 - BHO: vrl32WarningBHO Class - {4E6615B5-A259-4e55-905F-7F9CE60B379D} - C:\Program Files\vrl32software\vrl32Warning.dll (file missing)
              O2 - BHO: XML module - {500BCA15-57A7-4eaf-8143-8C619470B13D} - C:\WINDOWS\system32\msxml71.dll
              O2 - BHO: (no name) - {64466B8E-20A7-4A4A-AFF4-AAD9CA68B52C} - C:\Program Files\WebMediaViewer\hpmun.dll
              O2 - BHO: AnvTrgrWarningBHO Class - {95E9BCC0-2E84-4500-8A9C-0B7A96769124} - C:\Program Files\AnvTrgrsoftware\AnvTrgrWarning.dll (file missing)
              O4 - HKLM\..\Run: [eqsiksfhmxmldknz] C:\WINDOWS\System32\regsvr32.exe /s "C:\WINDOWS\system32\afmfqbqgvlzwnsdgv.dll"
              O4 - HKLM\..\Run: [spywareguard] C:\Program Files\Spyware Guard 2008\spywareguard.exe
              O4 - HKCU\..\Run: [vrl32] "C:\Program Files\vrl32software\vrl32.exe"
              O4 - HKCU\..\Run: [AnvTrgr] "C:\Program Files\AnvTrgrsoftware\AnvTrgr.exe"
              O4 - HKCU\..\Run: [Cognac] C:\DOCUME~1\Admin\LOCALS~1\Temp\29.tmp.exe
              O4 - HKCU\..\Run: [Pro Antispyware 2009] "C:\Documents and Settings\All Users\Application Data\Solt Lake Software\Pro Antispyware 2009\proas2009.exe" /autorun
              O4 - HKLM\..\Policies\Explorer\Run: [QuickTime Task] C:\Program Files\WebMediaViewer\qttask.exe
              O4 - HKLM\..\Policies\Explorer\Run: [VMware hptray] C:\Program Files\WebMediaViewer\hpmon.exe
              O9 - Extra button: (no name) - {3B8FB116-D358-48A3-A5C7-DB84F15CBB04} - http://www.servicemenutool.com/redirect.php (file missing)
              O9 - Extra 'Tools' menuitem: Explorer Security - {3B8FB116-D358-48A3-A5C7-DB84F15CBB04} - http://www.servicemenutool.com/redirect.php (file missing)
              O21 - SSODL: ieModule - {60239D08-5E56-4FAE-B596-9FA423E5D469} - C:\Documents and Settings\All Users\Application Data\Microsoft\Internet Explorer\DLLs\ieModule.dll
              O21 - SSODL: InternetConnection - {3679651B-7DF2-42E4-8221-D43F3DD60974} - C:\Documents and Settings\All Users\Application Data\Microsoft\Internet Explorer\DLLs\nnmhmigfhb.dll
