[SQL] Probleme requete UPDATE
J'ai un formulaire sur la page 'database_edit.php' et quand j'exécute ma requête d'UPDATE tout ce passe bien, pas d'erreur. Mais ca ne met pas a jour ma base de données.
Je ne vois pas ou pourrez être l'erreur.
Ma requete :
Ma table :
Merci de votre aide.
Ma requete :
$sql="UPDATE `case`
SET `case_status`='".$case_status."',
`date_modif`='".$date_modif."',
`receive_letter`='".$receive_letter."',
`dated_letter`='".$dated_letter."',
`request_letter`='".$request_letter."',
`acknowledged_letter`='".$acknowledged_letter."',
`date_assigned`='".$date_assigned."',
`date_sent_compiler`='".$date_sent_compiler."',
`date_returned_compiler`='".$date_returned_compiler."',
`date_case_completed`='".$date_case_completed."',
`date_final_report_sent`='".$date_final_report_sent."',
`invoice_number`='".$invoice_number."',
`invoice_amount`='".$invoice_amount."',
`date_start_loss`='".$date_start_loss."',
`date_end_loss`='".$date_end_loss."',
`location_loss`='".$location_loss."',
`fk_id_claim`='".$id_claim."',
`fk_id_district`='".$district."',
`fk_id_compiler`='".$fk_id_compiler."',
`fk_id_emp`='".$assigned_to."',
`fk_id_contact`='".$Contact."',
`date_update`='".$date_update."',
`description_update`='".$description_update."',
`fk_id_updater_emp`='".$fk_id_updater_emp."'
WHERE `id_case`='".$id_case."'";
$edit_case=mysql_query($sql)or die ("/!\ THERE IS AN ERROR WHEN YOU EDIT THE CASE : CHECK THAT YOU CHOSE AN OPTION IN EVERY DROPDOWN BOX ".$edit_case.''.mysql_error());
echo"<br />";
echo "<br /><span class=\"success\">CASE EDITED !</span>";
Ma table :
CREATE TABLE `case` ( `num_case` int(11) NOT NULL auto_increment, `id_case` varchar(20) NOT NULL, `case_status` text NOT NULL, `date_creation` varchar(30) NOT NULL, `date_modif` varchar(30) NOT NULL, `receive_letter` varchar(10) NOT NULL, `dated_letter` varchar(10) NOT NULL, `request_letter` text NOT NULL, `acknowledged_letter` varchar(10) NOT NULL, `date_assigned` varchar(10) NOT NULL, `date_sent_compiler` varchar(10) NOT NULL, `date_returned_compiler` varchar(10) NOT NULL, `date_case_completed` varchar(10) NOT NULL, `date_final_report_sent` varchar(10) NOT NULL, `invoice_number` varchar(20) NOT NULL, `invoice_amount` varchar(20) NOT NULL, `date_start_loss` varchar(10) NOT NULL, `date_end_loss` varchar(10) NOT NULL, `location_loss` text NOT NULL, `fk_id_claim` int(11) NOT NULL, `fk_id_district` int(11) NOT NULL, `fk_id_compiler` int(11) NOT NULL COMMENT 'employe ayent compiler le rapport', `fk_id_emp` int(11) NOT NULL COMMENT 'investigator (assigned to))', `fk_id_insured` int(11) NOT NULL, `fk_id_contact` int(11) NOT NULL, `date_update` varchar(10) NOT NULL, `description_update` text NOT NULL, `fk_id_updater_emp` int(11) NOT NULL, PRIMARY KEY (`num_case`), KEY `fk_id_emp` (`fk_id_emp`), KEY `fk_id_insured` (`fk_id_insured`), KEY `fk_id_compiler` (`fk_id_compiler`), KEY `fk_id_updater_emp` (`fk_id_updater_emp`), KEY `fk_id_claim` (`fk_id_claim`), KEY `fk_id_district` (`fk_id_district`), KEY `fk_id_contact` (`fk_id_contact`) ) ENGINE=InnoDB DEFAULT CHARSET=latin1 AUTO_INCREMENT=2 ; -- -- Dumping data for table `case` -- INSERT INTO `case` (`num_case`, `id_case`, `case_status`, `date_creation`, `date_modif`, `receive_letter`, `dated_letter`, `request_letter`, `acknowledged_letter`, `date_assigned`, `date_sent_compiler`, `date_returned_compiler`, `date_case_completed`, `date_final_report_sent`, `invoice_number`, `invoice_amount`, `date_start_loss`, `date_end_loss`, `location_loss`, `fk_id_claim`, `fk_id_district`, `fk_id_compiler`, `fk_id_emp`, `fk_id_insured`, `fk_id_contact`, `date_update`, `description_update`, `fk_id_updater_emp`) VALUES (1, 'OTP/1/2008', 'New Case', '30/09/2008', '30/09/2008', '30/09/2008', '30/09/2008', '', '', '', '', '', '', '', '', '', '01/09/2008', '01/09/2008', 'Maraval Road', 21, 19, 1, 1, 1, 64, '', '', 2); -- -- Constraints for dumped tables -- -- -- Constraints for table `case` -- ALTER TABLE `case` ADD CONSTRAINT `case_ibfk_10` FOREIGN KEY (`fk_id_contact`) REFERENCES `contact` (`id_contact`) ON DELETE CASCADE ON UPDATE CASCADE, ADD CONSTRAINT `case_ibfk_3` FOREIGN KEY (`fk_id_emp`) REFERENCES `employe` (`id_emp`) ON DELETE CASCADE ON UPDATE CASCADE, ADD CONSTRAINT `case_ibfk_4` FOREIGN KEY (`fk_id_insured`) REFERENCES `insured` (`id_insured`) ON DELETE CASCADE ON UPDATE CASCADE, ADD CONSTRAINT `case_ibfk_6` FOREIGN KEY (`fk_id_compiler`) REFERENCES `employe` (`id_emp`) ON DELETE CASCADE ON UPDATE CASCADE, ADD CONSTRAINT `case_ibfk_7` FOREIGN KEY (`fk_id_updater_emp`) REFERENCES `employe` (`id_emp`) ON DELETE CASCADE ON UPDATE CASCADE, ADD CONSTRAINT `case_ibfk_8` FOREIGN KEY (`fk_id_claim`) REFERENCES `claim` (`id_claim`) ON DELETE CASCADE ON UPDATE CASCADE, ADD CONSTRAINT `case_ibfk_9` FOREIGN KEY (`fk_id_district`) REFERENCES `district` (`id_district`) ON DELETE CASCADE ON UPDATE CASCADE;
Configuration: Windows XP Firefox 3.0.2
bjr à vous,
Je fait un projet sur acess et j'ai un probléme avec ma requéte, j'aimerai augmenter le champ effectif de la table lycee2, et quand je met la modification du 1 er lycee je peut modifier l'effectif seulement si je met l'effectif = 1, et quand je met la modification du 2em lycee je peut modifier l'effectif seulement si je met l'effectif = 2.
voici ma requête:
UPDATE LYCEE2
SET EFFECTIF = LYCEE.EFFECTIF
WHERE LYCEE.EFFECTIF = NUMLYCEE
AND NUMLYCEE=[numero_de_la_ligne_a_modifier]
AND LYCEE2.EFFECTIF not like LYCEE2.NUMLYCEE; -
Merci.. Ça m'a aider a trouver le problème.
La condition reste vide :
probleme resolu ;) -
Contributeursalut,
juste après la déclaration de ta requête ajoute :print_r( $sql );
la requête va s'afficher, tu fais un copier/coller pour tester directement dans PHPMyAdmin (onglet "SQL"), comme ça tu sauras ce qui cloche (en général du moins…).
