Probleme de gravure
Fermé
Bonjour,a tous
jai essayer de graver un dvd avec nero mais la gravure a echouer pouver vous m'aider svp jai reçus un raport je n'y comprend rien je vous donne ce rapport
Dragons
4C85-200E-4005-0004-0000-7660-0800-35X3-0000-407M-MX37-**** (*)
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.9.6.0
Internal Version: 7, 9, 6, 0
(Nero Express)
Recorder: <TSSTcorp CD/DVDW SH-S182D>Version: SB04 - HA 1 TA 0 - 7.9.6.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <TSSTcorp CD/DVDW SH-S182D>Version: SB04 - HA 1 TA 0 - 7.9.6.0
=== Scsi-Device-Map ===
CdRomPeripheral : TSSTcorp CD/DVDW SH-S182D atapi Port 1 ID 0 DMA: Off
DiskPeripheral : ST3200827AS nvata Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CD/DVDW SH-S182D E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095600kB)
Free physical memory: 1492MB (1528424kB)
Memory in use : 27 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
17.9.2008
Compilation ISO
20:35 Orkas Ultimate #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
20:35 Orkas Ultimate #2 Text 0 File Isodoc.cpp, Line 6663
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
20:35 Orkas Ultimate #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
20:35 Orkas Ultimate #4 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
20:35 Orkas Ultimate #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2117823 (470:37.48, 4136MB)
20:35 Orkas Ultimate #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
20:35 Orkas Ultimate #7 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: TSSTcorp CD/DVDW SH-S182D, Media type: DVD-R
Disc Manufacturer: UME02 -
Disc Application Code: 64, Disc Physical Code: 193
20:35 Orkas Ultimate #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
20:35 Orkas Ultimate #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2117824 (2117824) = #2117824/470:37.49
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2117824 blocks [E: TSSTcorp CD/DVDW SH-S182D]
20:35 Orkas Ultimate #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: TSSTcorp CD/DVDW SH-S182D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4337303552, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2117824 | 0 | 0x00
2117824 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
20:35 Orkas Ultimate #11 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
20:35 Orkas Ultimate #12 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
20:35 Orkas Ultimate #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
20:35 Orkas Ultimate #14 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
20:35 Orkas Ultimate #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
20:35 Orkas Ultimate #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 16x (22 160 Ko/s)
20:35 Orkas Ultimate #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
20:35 Orkas Ultimate #18 Text 0 File DVDR.cpp, Line 3225
Recording mode: Sequential Recording Mode
20:35 Orkas Ultimate #19 Text 0 File DVDR.cpp, Line 3381
Start write address at LBA 0
DVD high compatibility mode: Yes
20:35 Orkas Ultimate #20 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
20:35 Orkas Ultimate #21 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
20:36 Orkas Ultimate #22 Text 0 File Cdrdrv.cpp, Line 1352
20:36:12.421 - E: TSSTcorp CD/DVDW SH-S182D : Queue again later
03:04 Orkas Ultimate #23 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 16 38 20 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x0c53c200: Len x10000
0x7E 0A 68 11 36 BC 1A BC 29 82 B0 A4 64 DD 31 C4
0x83 37 0D 02 9F 64 62 49 52 69 41 DA A2 C2 49 3F
0xF0 30 5A 2A F5 C5 A5 4B F7 96 0C 81 68 33 EE 11
03:04 Orkas Ultimate #24 CDR -1135 File Writer.cpp, Line 303
Write error
03:04 Orkas Ultimate #25 Text 0 File DVDR.cpp, Line 3783
EndDAO: Last written address was 1456159 (16381Fh)
03:04 Orkas Ultimate #26 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 16x (22 160 Ko/s)
03:04 Orkas Ultimate #27 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
03:04 Orkas Ultimate #28 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
03:04 Orkas Ultimate #29 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Dragons
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
(Nero Express)
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Use Inquiry : 1
17.9.2008
Compilation ISO
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
DAO infos:
MCN: ""
DAO layout:
Class: 0
Sense Code: 0x0C
Sense Qual: 0x00
Write error
Existing drivers:
Registry Keys:
je n'arrive plus à graver il me manque un composant dans real player
et tu pe m'aider pour mon probleme de gravure stp
ModérateurJe te plains.
Lis ceci :
http://www.commentcamarche.net/faq/sujet 2981 windows j utilise une version piratee -
oui pourquoi ?
ModérateurSalut,
Tu as Windows Orkas Ultimate ?
