Probleme de gravure
bonjour,
Voulant graver des dvd (faire des sauvegardes) au debut pas de probleme, mais mtn, je n'y arrive plus!!
j'tutilise dvd shrink pour faire l'analyse, l'encodage, la compression et graver de suite apres! mais depuis quelque jour, plus moyen de graver apres tt cela!!
voila le msg d'erreur qui apparait a chaque fois (il es long):
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 12:06:00
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 20:18:06
Nero API version: 6.3.1.10
Using interface version: 6.0.0.0
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <_NEC DVD_RW ND-1300A> Version: 1.0A - HA 0 TA 1 - 6.3.1.10
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 92732U8 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-1300A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : _NEC DV-5500A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : ATAPI CD-R/RW 48X16 atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
_NEC DVD_RW ND-1300A G: CDRom0
_NEC DV-5500A F: CDRom1
ATAPI CD-R/RW 48X16 H: CDRom2
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261616kB)
Free physical memory: 47MB (48748kB)
Memory in use : 81 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
13.5.2004
NeroAPI
22:40:01 #1 Phase 111 File APIProgress.cpp, Line 269
DVD-Video files sorted
22:40:03 #2 Text 0 File Reader.cpp, Line 118
Reader running
22:40:03 #3 Text 0 File Writer.cpp, Line 124
Writer _NEC DVD_RW ND-1300A running
22:40:03 #4 Text 0 File AudioCompilationImpl.cpp, Line 817
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
22:40:03 #5 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
22:40:04 #6 ISO9660GEN -11 File geniso.cpp, Line 3899
22:40:04 #7 Text 0 File Burncd.cpp, Line 3200
Turn on Disc-At-Once, using DVD media
22:40:05 #8 Text 0 File DlgWaitCD.cpp, Line 244
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286143 (508:01.68, 4465MB)
22:40:05 #9 Text 0 File DlgWaitCD.cpp, Line 249
Write in overburning mode: FALSE
22:40:05 #10 Text 0 File DlgWaitCD.cpp, Line 2107
Recorder: _NEC DVD_RW ND-1300A, Media type: DVD-R
Disc Manufacturer: PRINCO -
Disc Application Code: 64, Disc Physical Code: 193
22:40:05 #11 Text 0 File DlgWaitCD.cpp, Line 410
>>> Protocol of DlgWaitCD activities: <<<
22:40:05 #12 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286144 (2286144) = #2286144/508:1.69
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286144 blocks [_NEC DVD_RW ND-1300A ]
22:40:05 #13 Text 0 File ThreadedTransferInterface.cpp, Line 982
Prepare recorder [_NEC DVD_RW ND-1300A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682022912, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286144 | lead-out | 1 | 0x00 | 0x41
22:40:08 #14 Phase 24 File APIProgress.cpp, Line 269
Caching of files started
22:40:08 #15 Text 0 File Burncd.cpp, Line 4210
Cache writing successful.
22:40:08 #16 Phase 25 File APIProgress.cpp, Line 269
Caching of files completed
22:40:08 #17 Phase 36 File APIProgress.cpp, Line 269
Burn process started at 4x (5 540 KB/s)
22:40:08 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2345
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
22:40:08 #19 Text 0 File DVDR.cpp, Line 1650
Recording mode: Sequential Recording Mode
22:40:08 #20 Text 0 File Mmc.cpp, Line 20051
Set BUFE: supported -> ON
22:40:08 #21 Text 0 File DVDR.cpp, Line 1791
Start write address at LBA 0
DVD high compatibility mode: Yes
22:40:08 #22 Text 0 File Cdrdrv.cpp, Line 8024
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
22:40:36 #23 SCSI -1106 File Cdrdrv.cpp, Line 1439
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03EB0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
22:40:36 #24 CDR -1106 File Writer.cpp, Line 304
Power calibration error
22:40:36 #25 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
22:40:36 #26 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
22:40:36 #27 Text 0 File DVDR.cpp, Line 2001
EndDAO: Last written address was -1
22:40:36 #28 Phase 38 File APIProgress.cpp, Line 269
Burn process failed at 4x (5 540 KB/s)
22:40:36 #29 Text 0 File AudioCompilationImpl.cpp, Line 828
DRM: DRM burn session terminated.
22:40:36 #30 Text 0 File AudioCompilationImpl.cpp, Line 857
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
est ce que quelqu'un pourrai me dire c que cet comment faire pour ne plus avoir de probleme.
D'avance je vous en remercie!
a bientot
SEB.
10 réponses
  1. re bonjour ,
    J'ai noté exactement le message qui se marquais quand le gravure ne va pas voici ce message : erreur d'écriture de dvd ( write dvd 9 )
    une erreur d'écriture du dvd s'est rpoduite , elle à été probablement été causée par un mauvais média , veuillez remplacer le média , pour moi c du chinois , si vous pouviez m'aider ce serait hyper sympa
    véro
    1. bonjour ,
      bon voilà j'ai un petit soucis de gravure , j'utilise any dvd et clone dvd pour analyser et graver , voilà deux fois qu'un message se met après l'analyse ( problème de média , write drive 9 ) et je ne sais absolument pas ce que c'est , et parfois il me grave une partie du film et puis le message s'inscrit . Je voudrais savoir aussi si c'est normal que cela prenne entre 1h30 et 6h pour analyser et graver .
      Voilà , merci beaucoup a ceux qui pourront m'aider
      vero
      1. salut a tous
        j'ai aussi un probleme de calibration de la puissance, et j'ai chercher et je suis tomber sur sa , j'espere que vous comprendrer mieux pour quoi sa fonctionne pas.
        Erreur de calibrage de puisssance :
        Un CD-R contient une plage appelée Power Calibration Area qui permet d' ajuster la puissance du laser au type de support testé. Cela revient à dire que votre lecteur peut être allergique à certaines marques de CD-R. En toute logique il faut procéder à une mise à jour du firmware de votre graveur ou essayer d' autres marques de CD-R.
        et sa doit etre la meme chose pour les dvd
        1. jai le mm probleme ke tt le monde
          moi sa fai 6 mois ke jutilise dvd shkink et jai jamai u de pb...
          mais depui 2 semaine sa narrete po de planker avec les mm messages ke vous!!
          je c po ce ke c car je suis unnoob en pc lol ... si kelkun a la reponse kil la donn svp merci lol
          1. Salut ,j'ai le meme probleme.Je n'arrive pas a graver und dvd avec shrink sans qu'il y est ce message d'erreur.Aidez moi svp.Faut-il installer une autre version de nero.
            1. J'ai aussi un message qui ressemble tres fort a celui là.
              Est-ce que qqn peut me dire comment résoudre ce problème.
              Moi Plusieur films ne fonctionne pas et presque 5 dvd vierge y sont passé.
              Merci d'avance
              1. j ai le meme message :
                Windows XP 5.1
                IA32
                WinAspi: -
                Version de Nero : 6.3.1.10 (Nero Express)
                Graveur : <_NEC DVD+RW ND-1100A> Version: 1.80 - HA 1 TA 1 - 6.3.1.10
                Pilote d'adaptateur :<atapi> HA 1
                CD-ROM : <JLMS XJ-HD166S >Version: DIS3 - HA 1 TA 0 - 6.3.1.10
                DiskPeripheral : Maxtor 6Y120L0 atapi Port 0 ID 0 DMA: On
                CdRomPeripheral : JLMS XJ-HD166S atapi Port 1 ID 0 DMA: On
                CdRomPeripheral : _NEC DVD+RW ND-1100A atapi Port 1 ID 1 DMA: On
                JLMS XJ-HD166S D: CDRom0
                _NEC DVD+RW ND-1100A E: CDRom1
                AutoRun : 1
                Excluded drive IDs:
                CmdQueuing : 1
                CmdNotification: 2
                ShowDrvBufStat : 0
                EraseSpeed : 0
                BUFE : 0
                Physical memory : 253MB (259568kB)
                Free physical memory: 62MB (64168kB)
                Memory in use : 75 %
                Use Inquiry : 1
                17.5.2004
                Compilation UDF/ISO
                00:25:14 #1 Phase 112 File dlgbrnst.cpp, Line 1841
                Réallocation des fichiers DVD-Vidéo commencée
                00:25:14 #2 Phase 114 File dlgbrnst.cpp, Line 1841
                Réallocation des fichiers DVD-Vidéo achevée (aucun fichier modifié)
                00:25:14 #3 Text 0 File Isodoc.cpp, Line 6065
                Iso document burn settings
                Determine maximum speed : FALSE
                Simulate : FALSE
                Write : TRUE
                Finalize CD : TRUE
                Multisession : FALSE
                Burning mode : DAO
                Mode : 1
                ISO Level : 1 (Max. of 11 = 8 + 3 char)
                Character set : ISO 9660
                Joliet :FALSE
                Allow pathdepth more than 8 directories : TRUE
                Allow more than 255 characters in path : TRUE
                Write ISO9660 ;1 file extensions : TRUE
                00:25:14 #4 Phase 111 File dlgbrnst.cpp, Line 1841
                Classement des fichiers DVD-Vidéo
                00:25:14 #5 Text 0 File Reader.cpp, Line 118
                Reader running
                00:25:14 #6 Text 0 File Writer.cpp, Line 124
                Writer _NEC DVD+RW ND-1100A running
                00:25:14 #7 ISO9660GEN -11 File geniso.cpp, Line 3899
                00:25:14 #8 ISO9660GEN -11 File geniso.cpp, Line 3899
                00:25:14 #9 Text 0 File Burncd.cpp, Line 3200
                Turn on Disque entier, using DVD media
                00:26:10 #10 Text 0 File DlgWaitCD.cpp, Line 244
                Last possible write address on media: 2295103 (510:01.28, 4482MB)
                Last address to be written: 2286111 (508:01.36, 4465MB)
                00:26:10 #11 Text 0 File DlgWaitCD.cpp, Line 249
                00:26:10 #12 Text 0 File DlgWaitCD.cpp, Line 2107
                Recorder: _NEC DVD+RW ND-1100A, Media type: DVD+R
                00:26:10 #13 Text 0 File DlgWaitCD.cpp, Line 410
                Insert empty disc to write to.
                (Medium in drive: Inconnu. Medium required by compilation: DVD+R/RW.)
                00:26:10 #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
                original disc pos #0 + 2286112 (2286112) = #2286112/508:1.37
                -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286112 blocks [_NEC DVD+RW ND-1100A ]
                00:26:10 #15 Text 0 File ThreadedTransferInterface.cpp, Line 982
                Prepare recorder [_NEC DVD+RW ND-1100A ] for write in CUE-sheet-DAO
                DAO infos:
                MCN: ""
                Tracks 1 to 1:
                1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681957376, ISRC ""
                DAO layout:
                2286112 | lead-out | 1 | 0x00 | 0x41
                00:26:10 #16 Phase 24 File dlgbrnst.cpp, Line 1841
                Début de mise en cache des fichiers
                00:26:10 #17 Text 0 File Burncd.cpp, Line 4210
                00:26:10 #18 Phase 25 File dlgbrnst.cpp, Line 1841
                Cache des fichiers terminé
                00:26:10 #19 Phase 36 File dlgbrnst.cpp, Line 1841
                Début de gravure à 2,4x (3 312 Ko/s)
                00:26:10 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2345
                00:26:10 #21 SCSI -1066 File Cdrdrv.cpp, Line 1185
                SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AB5000
                Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
                Sense Code: 0x24
                Sense Qual: 0x00
                CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
                Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
                0x00 0x00 0x00 0x00 0x24 0x00
                00:26:10 #22 SCSI -1066 File Cdrdrv.cpp, Line 1185
                SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AB6000
                Sense Code: 0x24
                Sense Qual: 0x00
                CDB Data: 0xFA 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x06 0x00 0x00 0x00
                00:26:10 #23 Text 0 File DVDPlusRW.cpp, Line 618
                00:49:25 #24 Text 0 File WriterStatus.cpp, Line 115
                <_NEC DVD+RW ND-1100A > start writing Lead-Out at LBA 2286112 (22E220h), lenght 0 blocks
                00:49:25 #25 Text 0 File ThreadedTransfer.cpp, Line 229
                00:50:26 #26 SCSI -1106 File Cdrdrv.cpp, Line 1185
                Sense Code: 0x73
                Sense Qual: 0x03
                CDB Data: 0x5B 0x01 0x01 0x00 0x00 0x01 0x00 0x00 0x00 0x00 0x00 0x00
                00:50:26 #27 SCSI -1176 File Cdrdrv.cpp, Line 1185
                Sense Code: 0x72
                Sense Qual: 0x03
                CDB Data: 0x5B 0x01 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
                0x00 0x00 0x00 0x00 0x72 0x03
                00:50:26 #28 SCSI -1066 File Cdrdrv.cpp, Line 1185
                Sense Code: 0x24
                Sense Qual: 0x00
                00:50:26 #29 CDR -1106 File ThreadedTransferInterface.cpp, Line 1701
                Erreur calibrage puissance
                _NEC DVD+RW ND-1100A\H1 T1
                00:50:26 #30 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1701
                Impossible d'effectuer la fonction Disc At Once
                00:53:43 #31 Phase 127 File dlgbrnst.cpp, Line 1841
                Génération des cadres DVD de compatibilité supérieure
                00:53:47 #32 Phase 129 File dlgbrnst.cpp, Line 1841
                Génération des cadres DVD achevée avec succès
                00:53:47 #33 SCSI -1066 File Cdrdrv.cpp, Line 1185
                Sense Code: 0x24
                Sense Qual: 0x00
                00:53:47 #34 Phase 38 File dlgbrnst.cpp, Line 1841
                La gravure a échoué à 2,4x (3 312 Ko/s)
                Existing drivers:
                File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 30/08/2002 13:00:00 (Adapter driver for rec)
                Registry Keys:
                mais cela ne le fait qu'avec un seul dvd !!!! tous les autres fonctionnent
                je ne comprends vraiment pas pourquoi il y a une erreur calibrage puissance
                merci pour vos reponses
                1. Pour repondre a la reponse de foobar 47 si il parle de nero c parce que dans les option, il me demande si je veut utiliser nero pour graver alors moi, j'ai mis oui!! Mais j'ai toujours fait ca et avant ca n'a jamais causer de probleme!!
                  Et pour firehead77 tu dit que ca peut indicquer un probleme de firmeware ou imcompatibiliter de support!! Ca pourrai etre le dvd vierge qui serai defecteux alors!! Mais j'ai essayer 4 dvd vierge et idem! Ou alors, je suis tomber sur une mauvaise serie!!!!!
                  Encore merci pour votre aide!!!
                2. slt
                  La ligne suivante :
                  peut indiquer un problème de firmeware et/ou d'incompatibilté du support.
                    tu utilises dvdshrink et il parle de Nero ?
                    c'est un peu louche !
                    désinstalle Nero pour voir...
                    foobar... il est toujours en retard...
