Probleme de macro
J'ai un problème sur une macro.
le begue est en gras
je n'arrive pas à mettre mon doc excel en ligne.
voici la macro:
Sub Ligue_2()
' Ligue_2 Macro
Range("G10:AJ29").Select
ActiveWorkbook.Worksheets("Classement").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("Classement").Sort.SortFields.Add Key:= _
Range("G10:G29"), SortOn:=xlSortOnValues, Order:=xlDescending, DataOption _
:=xlSortNormal
Range("P10:P29"), SortOn:=xlSortOnValues, Order:=xlDescending, DataOption _
:=xlSortNormal
Range("N10:N29"), SortOn:=xlSortOnValues, Order:=xlDescending, DataOption _
:=xlSortNormal
Range("H10:H29"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption _
:=xlSortNormal
With ActiveWorkbook.Worksheets("Classement").Sort
.SetRange Range("G10:AJ29")
.Header = xlGuess
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
End With
Range("F4:AJ4,I8:P8,R8:Y8,AA8:AH8").Select
Range("AA8").Activate
With Selection
.HorizontalAlignment = xlCenter
.VerticalAlignment = xlCenter
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
.MergeCells = False
End With
Selection.Merge
Selection.Font.Bold = True
Range("F4:AJ4").Select
Selection.Font.Underline = xlUnderlineStyleSingle
ActiveCell.FormulaR1C1 = "=RC[-5]"
Range("I8:P8").Select
ActiveCell.FormulaR1C1 = "GÉNÉRAL"
Range("Q8").Select
ActiveCell.FormulaR1C1 = ""
Range("R8:Y8").Select
ActiveCell.FormulaR1C1 = "DOMICILE"
Range("AA8:AH8").Select
ActiveCell.FormulaR1C1 = "EXTÉRIEUR"
Range("H9").Select
ActiveCell.FormulaR1C1 = "ÉQUIPE"
Range("I9").Select
ActiveCell.FormulaR1C1 = "PNTS"
Range("J9").Select
ActiveCell.FormulaR1C1 = "J"
Range("K9").Select
ActiveCell.FormulaR1C1 = "G"
Range("L9").Select
ActiveCell.FormulaR1C1 = "N"
Range("M9").Select
ActiveCell.FormulaR1C1 = "P"
Range("N9").Select
ActiveCell.FormulaR1C1 = "BP"
Range("O9").Select
ActiveCell.FormulaR1C1 = "BC"
Range("P9").Select
ActiveCell.FormulaR1C1 = "DIFF"
Range("I9:Q9").Select
Selection.AutoFill Destination:=Range("I9:AH9"), Type:=xlFillDefault
Range("I9:AH9").Select
Range("F10").Select
ActiveCell.FormulaR1C1 = "1"
Range("F11").Select
ActiveCell.FormulaR1C1 = "2"
Range("F12").Select
ActiveCell.FormulaR1C1 = "3"
Range("F10:F12").Select
Selection.AutoFill Destination:=Range("F10:F29"), Type:=xlFillDefault
Range("F10:F29").Select
Range("F10:G29,I10:AJ29,H9:AH9").Select
Range("H9").Activate
With Selection
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.MergeCells = False
End With
Range("F10:G29,I10:AJ29,H9:AH9,H10:H29,I8:AH8").Select
Range("I8").Activate
Selection.Borders(xlDiagonalDown).LineStyle = xlNone
Selection.Borders(xlDiagonalUp).LineStyle = xlNone
With Selection.Borders(xlEdgeLeft)
.LineStyle = xlContinuous
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
End With
With Selection.Borders(xlEdgeTop)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
End With
With Selection.Borders(xlEdgeBottom)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
End With
With Selection.Borders(xlEdgeRight)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
End With
With Selection.Borders(xlInsideVertical)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
End With
With Selection.Borders(xlInsideHorizontal)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
End With
Range("F10:AJ11").Select
Application.CutCopyMode = False
With Selection.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.Color = 10092543
.TintAndShade = 0
.PatternTintAndShade = 0
End With
Range("F12:AJ12").Select
.ThemeColor = xlThemeColorAccent6
.TintAndShade = 0.599993896298105
End With
Range("F27:AJ27").Select
.Pattern = xlSolid
.Color = 16777062
.TintAndShade = 0
End With
Range("F28:AJ29").Select
.Pattern = xlSolid
.ThemeColor = xlThemeColorAccent5
End With
Range("F14:AJ14,F16:AJ16,F18:AJ18,F20:AJ20,F22:AJ22,F24:AJ24,F26:AJ26").Select
Range("AJ26").Activate
.Pattern = xlSolid
.ThemeColor = xlThemeColorDark1
.TintAndShade = -4.99893185216834E-02
End With
Range("Q8:Q29,Z8:Z29,AI10:AI29").Select
Range("AI10").Activate
.ThemeColor = xlThemeColorLight1
.TintAndShade = 0
End With
Range("G6").Select
Dim equipe1 As Variant
Dim equipe2 As Variant
Dim place1 As Integer
Dim place2 As Integer
Dim numligne1 As Integer
Dim numligne2 As Integer
Dim classement As Integer
'numligne1 = 10
numligne2 = 49
For numligne1 = 10 To 29
equipe1 = Cells(numligne1, 8).Value
Do
equipe2 = Cells(numligne2, 8).Value
If equipe1 <> equipe2 Then
numligne2 = numligne2 + 1
End If
Loop Until equipe1 = equipe2
place1 = Cells(numligne1, 6).Value
place2 = Cells(numligne2, 6).Value
classement = place2 - place1
Cells(numligne1, 7).Value = classement
If classement > 0 Then
Range(Cells(numligne1, 6), Cells(numligne1, 36)).Select
Selection.Font.Color = -16776961
End If
If classement < 0 Then
Selection.Font.Color = -4165632
End If
numligne2 = 49
Next numligne1
End Sub
Merci de votre aide
