Probleme avec java et minecraft
voila je vien d'avoir un nouveaux pc portable et j'ai normalement tout reinstaller pourtant il y a minecraft qui crash sans raison a la generation du monde
j'ai installer java mais le resultat est le meme
que doit-je faire car je ne comprend pas
y a t-il un pilote mal installer ou mon minecraft est mal installer
(je suis sur Windows 10)
voila le crash de minecraft
Completely ignored arguments: [--nativeLauncherVersion, 301]
[08:00:24] [Client thread/INFO]: Setting user: monrus
[08:00:25] [Client thread/INFO]: LWJGL Version: 2.9.4
[08:00:25] [Client thread/INFO]: Reloading ResourceManager: Default
[08:00:26] [Sound Library Loader/INFO]: Starting up SoundSystem...
[08:00:26] [Thread-5/INFO]: Initializing LWJGL OpenAL
[08:00:26] [Thread-5/INFO]: (The LWJGL binding of OpenAL. For more information, see http://www.lwjgl.org)
[08:00:26] [Thread-5/INFO]: OpenAL initialized.
[08:00:26] [Sound Library Loader/INFO]: Sound engine started
[08:00:27] [Client thread/INFO]: Created: 1024x512 textures-atlas
[08:00:31] [Client thread/INFO]: Deleting level New World
[08:00:31] [Client thread/INFO]: Attempt 1...
[08:00:33] [Server thread/INFO]: Starting integrated minecraft server version 1.9.2
[08:00:33] [Server thread/INFO]: Generating keypair
[08:00:34] [Server thread/INFO]: Preparing start region for level 0
[08:00:35] [Server thread/INFO]: Preparing spawn area: 12%
[08:00:36] [Server thread/INFO]: Preparing spawn area: 26%
[08:00:37] [Server thread/INFO]: Preparing spawn area: 42%
[08:00:38] [Server thread/INFO]: Preparing spawn area: 56%
[08:00:39] [Server thread/INFO]: Preparing spawn area: 71%
[08:00:40] [Server thread/INFO]: Preparing spawn area: 85%
[08:00:41] [Server thread/INFO]: Preparing spawn area: 99%
[08:00:41] [Server thread/INFO]: Changing view distance to 12, from 10
[08:00:42] [Server thread/INFO]: monrus[local:E:71e90d76] logged in with entity id 796 at (188.5, 71.0, 238.5)
[08:00:42] [Server thread/INFO]: monrus joined the game
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffe782e6c17, pid=3928, tid=7540
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig9icd64.dll+0x16c17]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\Admin\AppData\Roaming\.minecraft\hs_err_pid3928.log
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
AL lib: (EE) alc_cleanup: 1 device not closed
Java HotSpot(TM) 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Bon ce matin j'ai retenté de jouer en version 1.9.4 et ça a fonctionné, je ne sais pas à quoi était dû le bug. Pour ceux avec qui ça ne marcherai toujours pas il reste la solution des autres version ^^ sinon GLHF in game
Pour le moment j'ai remarqué qui si on passe en version 1.8.x le jeu marche, il y a seulement la 1.9+ qui bug ...
pour ceux qui ne savent pas lancer le jeu en 1.8, dans le launcher (le page fenêtré blanche) en bas à gauche il y a votre profil avec votre nom affiché, ciquer sur "Edit Profil" puis c'est la dernière ligne de la section "Version Selection". -
J'ai également le même problème
J'ai tout essayé :
- Réinstaller Java
- Lancer en compatibilité Windows XP - 7 - 8
- Mis à jour les pilotes de mon ordi (notamment carte graphique)
J'ai téléchargé le jeu pour la première fois il y a seulement quelques jours, ai lancé une première partie, ai joué pendant 1h environ
Depuis, impossible de reprendre la partie, ou même d'en créer une nouvelle... ça crash dès la génération de la map
Je suis preneur de toute solution !
Merci ! -
j'ai exactement le même problème, et c'est étrange c'est depuis aujourd'hui seulement. Hier j'ai lancé le jeu sans problème et là je ne peux plus rejoindre ma save ... Etrange.
Je viens d'essayer en mode administrateur et en lançant en mode compatibilité pour Windows 7, ca ne marche toujours pas .. -
essaye en relançant en administrateur.
Il me semble minecraft n'est pas encore compatible avec windows10
essaye de le lancer avec une compatibilitée différente.
il te faut minecraft windows 10 édition béta non ?
