Probleme de lancement MInecraft
Bonjour a tous et a toute,
J'ai besoin aujourd'hui de votre aide car j'ai reformaté mon ordi , mais je découvre que minecraft ne fonctionne plus ( alors qu'il marchait avant) pourriez vous m'aidez ? Voici le message d'erreur:
---- Minecraft Crash Report ----
// Shall we play a game?
Time: 25/03/15 21:56
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:252)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bss.an(SourceFile:526)
at bss.ak(SourceFile:355)
at bss.a(SourceFile:302)
at net.minecraft.client.main.Main.main(SourceFile:124)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8.1
Operating System: Windows Vista (x86) version 6.0
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 97113688 bytes (92 MB) / 157954048 bytes (150 MB) up to 523501568 bytes (499 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8.1
LWJGL: 2.9.1
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs: []
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
et voici ma carte graphique:
CArte graphique VGA standard
    Il manque un pilote pour que ta carte graphique soit correctement reconnue.
    https://www.commentcamarche.net/faq/9265-identifier-son-materiel-avec-aida64
    Copie-colle le résumé généré par AIDA64 dans ton prochain message.
    1. alors voila pour la carte graphique :
      Champ Valeur
      Propriétés de la carte vidéo
      Type de DAC 8 bit
      Type de circuit ATI ATOMBIOS
      Taille de la mémoire 16 Mo
      Identification du Bios 01.00
      Identification de la carte VGA
      Description du périphérique Carte graphique VGA standard
      Pilotes installés
      vga64k 6.0.6001.18000 (longhorn_rtm.080118-1840)
      vga256 6.0.6001.18000 (longhorn_rtm.080118-1840)
      vga 6.0.6001.18000 (longhorn_rtm.080118-1840)
      framebuf 6.0.6001.18000 (longhorn_rtm.080118-1840)
      et voici pour l'accelerateur 3D :
      Champ Valeur
      Propriétés du processeur graphique
      Carte vidéo MSI RX2400Pro (MS-V104)
      Version du Bios 010.058.000.002.026086
      Date du Bios 30/07/2007
      Nom de code RV610
      N° du type de composant 113-B17005-103
      Périphérique PCI 1002-94C3 / 1462-1041 (Rev 00)
      Transistors 180 million(s)
      Technologie utilisée 65 nm
      Taille interne 82 mm2
      Type du bus PCI Express 1.0 x16 @ 1.0 x16
      Taille de la mémoire 256 Mo
      Vitesse d'horloge 446 MHz (original: 450 MHz)
      Horloge RAMDAC 400 MHz
      Pipelines Pixel 4
      Unités de cartographie de texture 4
      Shaders unifiés 40 (v4.0)
      Gestion du matériel DirectX DirectX v10
      Propriétés du bus mémoire
      Type du bus DDR2
      Largeur du bus 64 bits
      Fréquence réelle 495 MHz (DDR) (original: 500 MHz)
      Fréquence effective 990 MHz
      Bande passante [ TRIAL VERSION ]
      Architecture
      Architecture ATI VLIW5
      Calculer les unités (CU) 2
      SIMD par unité de calcul 1
      Largeur SIMD 4
      Largeur d'instructions SIMD 5
      Performance de pointe théorique
      Taux de remplissage pixel 1784 MPixel/s @ 446 MHz
      Taux de remplissage texel [ TRIAL VERSION ]
      Simple précision FLOPS 35.7 GFLOPS @ 446 MHz
      Double précision FLOPS [ TRIAL VERSION ]
      Entier 24 bits Ops ES/s 7.1 GIOPS @ 446 MHz
      Entier 32 bits Ops ES/s 7.1 GIOPS @ 446 MHz
      ATI PowerPlay (BIOS)
      State #1 GPU: 450 MHz, Mémoire: 500 MHz (Boot)
      State #2 GPU: 450 MHz, Mémoire: 500 MHz (OverDrive)
      State #3 GPU: 450 MHz, Mémoire: 500 MHz (UVD)
      Fabricant du processeur graphique
      Nom de l'entreprise Advanced Micro Devices, Inc.
      Information sur le produit http://www.amd.com/en-us/products/graphics/desktop
      Télécharger le pilote http://sites.amd.com/us/game/downloads
      Mise à jour du pilote http://www.aida64.com/driver-updates
      VOIla
    2. Merci de votre aide
    3. Modérateur
      Essaie ceci (Catalyst Software Suite 13.9) :
      http://support.amd.com/fr-fr/download/desktop/legacy?product=legacy2&os=Windows%20Vista%20-%2032
    4. je suis en train de le lancer je vais te le dire
      =p
    5. Mr je t'adore on se marie quand . JE te kiffffffffffeeeeeee car CA MARCHHHHHHHHHEEEEEEEEEEE .. hum hum du calme . Veux-tu m'épouser j'ai deux belles boules ?
  2. Si tu as windows en 64 bits , installe Java en 64 bits, je pense que ca viend de la
    Sinon ca vient de ta carte graphique, surtout qu'elle a un nom chelou
    1. j'ai un ordi 32 bits et déja fait toute les mse a jours et minecraft fonctionnait avant donc impossible.
