Probleme de gravure
bjr j'ai un gros probleme de gravure voici mon log
aidez moi svp merci
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17/07/2002 09:20:56
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:34
Nero Version: 6.6.0.8
Recorder: <NU DVDRW DDW-082> Version: B377 - HA 1 TA 0 - 6.6.0.8
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST DVD-ROM GDR8161B>Version: 0042 - HA 1 TA 1 - 6.6.0.8
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 2F040J0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : NU DVDRW DDW-082 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8161B atapi Port 1 ID 1 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
NU DVDRW DDW-082 E: CDRom0
HL-DT-ST DVD-ROM GDR8161 F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 735MB (753120kB)
Free physical memory: 435MB (446356kB)
Memory in use : 40 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
21.6.2007
ISO compilation
12:46:28 #1 Text 0 File Isodoc.cpp, Line 6172
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
12:46:28 #2 Text 0 File Reader.cpp, Line 127
Reader running
12:46:28 #3 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
12:46:28 #4 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
12:46:28 #5 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 83807 ( 18:37.32, 163MB)
12:46:28 #6 Text 0 File DlgWaitCD.cpp, Line 271
Write in overburning mode: NO (enabled: CD)
12:46:28 #7 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: NU DVDRW DDW-082, Media type: DVD-RW
Disc Manufacturer: INFOME - DIAA20
Disc Application Code: 2, Disc Physical Code: 214
12:46:28 #8 Text 0 File DlgWaitCD.cpp, Line 433
>>> Protocol of DlgWaitCD activities: <<<
12:46:28 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 83808 (83808) = #83808/18:37.33
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 83808 blocks [NU DVDRW DDW-082]
12:46:28 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [NU DVDRW DDW-082] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 171638784, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
83808 | lead-out | 1 | 0x41 | 0x00
12:46:28 #11 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
12:46:31 #12 Text 0 File Burncd.cpp, Line 4040
Cache writing successful.
12:46:31 #13 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
12:46:31 #14 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5 540 KB/s)
12:46:31 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:46:31 #16 Text 0 File DVDR.cpp, Line 2194
Recording mode: Sequential Recording Mode
12:46:31 #17 Text 0 File Mmc.cpp, Line 21235
Set BUFE: Seamless Link -> ON
12:46:31 #18 Text 0 File DVDR.cpp, Line 2340
Start write address at LBA 0
DVD high compatibility mode: Yes
12:46:31 #19 Text 0 File Cdrdrv.cpp, Line 8430
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-RW (3), Part Version: 3
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 20 10 00 00 00 00 00 - 00 00 03 12 00 00 00 00 ................
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
12:47:06 #20 SCSI -1135 File Cdrdrv.cpp, Line 1181
SCSI Exec, HA 1, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x53 0x00 0x00 0x00 0x00 0x00 0x01 0x47 0x60 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x0C 0x00
12:47:06 #21 Text 0 File DVDR.cpp, Line 5225
Drive: NU DVDRW DDW-082
Book Type request [QSI]: DVD-ROM, write to EEPROM
Changing the Book Type was finished successfully, return code 0
12:47:06 #22 CDR -1207 File DVDR.cpp, Line 4772
Book Type automatically set to: DVD-ROM
12:47:06 #23 CDR -1135 File ThreadedTransferInterface.cpp, Line 1765
Write error
12:47:06 #24 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1765
Could not perform start of Disc-at-once
12:47:06 #25 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5 540 KB/s)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 17/08/2001 22:07:32
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 30/01/2007 07:03:34
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 17/07/2002 08:53:02
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 30/01/2007 07:03:34 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 17/08/2001 21:51:56 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
aidez moi svp merci
Windows XP 5.1
IA32
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
21.6.2007
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Sense Code: 0x0C
Sense Qual: 0x00
Write error
Existing drivers:
Registry Keys:
tu ne fais rien de ce qui est demande!!!
mutisession en mode tao et non dao.
tes dvd sont toujours mal reconnu,change de marque!!!
nero7 n'est pas ajour!!!!
CdRomPeripheral : NU DVDRW DDW-082 atapi Port 1 ID 0 DMA: Off ??????????qu'est ce que c'est???mettre en mode dma!!!!
https://www.gravure-news.com/tutoriel/activer-le-mode-dma-3-1.php -
graveur virtuel toujours la!!!!!!!!!!!!
pourquoi tu n'arrives pas a mettre nero a jour?tu l'as eu avec le graveur????-
@julius1982gravure echoue voici le log
Windows XP 5.1
IA32
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 25/09/2005 19:11:20
NT-SPTI used
Nero Version: 7.0.0.0
Recorder: <NU DVDRW DDW-082> Version: B377 - HA 1 TA 0 - 7.0.0.0
Adapter driver: <IDE> HA 1
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <HL-DT-ST DVD-ROM GDR8161B>Version: 0042 - HA 1 TA 1 - 7.0.0.0
HL-DT-ST DVD-ROM GDR8161B F: CDRom1
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 467MB (478676kB)
Memory in use : 36 %
Use Inquiry : 1
24.6.2007
Compilation ISO
11:36:38 #1 Text 0 File Isodoc.cpp, Line 6410
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
11:36:38 #2 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
11:36:38 #3 Text 0 File Reader.cpp, Line 124
Reader running
11:36:38 #4 ISO9660GEN -11 File Geniso.cpp, Line 3304
11:36:38 #5 Text 0 File Burncd.cpp, Line 3301
11:36:38 #6 Text 0 File DlgWaitCD.cpp, Line 277
Last address to be written: 7231 ( 1:36.31, 14MB)
11:36:38 #7 Text 0 File DlgWaitCD.cpp, Line 289
11:36:38 #8 Text 0 File DlgWaitCD.cpp, Line 2568
11:36:38 #9 Text 0 File DlgWaitCD.cpp, Line 456
11:36:38 #10 Text 0 File ThreadedTransferInterface.cpp, Line 846
original disc pos #0 + 7232 (7232) = #7232/1:36.32
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 7232 blocks [E: NU DVDRW DDW-082]
11:36:38 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1058
Prepare recorder [E: NU DVDRW DDW-082] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 14811136, ISRC ""
DAO layout:
7232 | lead-out | 1 | 0x41 | 0x00
11:36:38 #12 Text 0 File SCSIPassThrough.cpp, Line 34
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
11:36:38 #13 Phase 24 File dlgbrnst.cpp, Line 1724
11:36:39 #14 Text 0 File Burncd.cpp, Line 4129
11:36:39 #15 Phase 25 File dlgbrnst.cpp, Line 1724
11:36:39 #16 Phase 36 File dlgbrnst.cpp, Line 1724
Burn process started at 4x (5 540 Ko/s)
11:36:39 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2669
11:36:39 #18 Text 0 File DVDR.cpp, Line 2469
11:36:39 #19 Text 0 File MMC.cpp, Line 21541
11:36:39 #20 Text 0 File DVDR.cpp, Line 2624
11:36:39 #21 Text 0 File Cdrdrv.cpp, Line 8385
Book Type: DVD-RW (3), Part Version: - (3)
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ..þ...ÿ.........
11:37:19 #22 SPTI -1135 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x53 00 00 00 00 00 00 1C 40 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 12 00 00 00 00 0C
11:37:19 #23 CDR -1135 File ThreadedTransferInterface.cpp, Line 1783
Write error
E: NU DVDRW DDW-082
11:37:19 #24 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1783
11:37:19 #25 Phase 38 File dlgbrnst.cpp, Line 1724
Burn process failed at 4x (5 540 Ko/s)
Existing drivers:
Registry Keys:
j'ai oublie,detail un peu ton pb,message erreur...si tu as toujours des pb apres avoir fait ce que je 'ai mis dans le post 1
oui tjrs le meme probleme il me dit parfois gravure terminee avec succes mais il nya rien sur le dvdrw
puis lorsque j'explore le dvd il me dit E:n'est pas accessible fonction incorrect
voici le log
Windows XP 5.1
IA32
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:34
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 201MB (206284kB)
Memory in use : 72 %
Use Inquiry : 1
23.6.2007
ISO compilation
22:26:13 #1 Text 0 File Isodoc.cpp, Line 6172
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
22:26:13 #2 Text 0 File Reader.cpp, Line 127
Reader running
22:26:13 #3 Text 0 File Writer.cpp, Line 122
Writer NU DVDRW DDW-082 running
22:26:13 #4 ISO9660GEN -11 File geniso.cpp, Line 3293
22:26:13 #5 Text 0 File Burncd.cpp, Line 3153
22:26:13 #6 Text 0 File DlgWaitCD.cpp, Line 259
Last address to be written: 350095 ( 77:47.70, 683MB)
22:26:13 #7 Text 0 File DlgWaitCD.cpp, Line 271
22:26:14 #8 Text 0 File DlgWaitCD.cpp, Line 2316
22:26:14 #9 Text 0 File DlgWaitCD.cpp, Line 433
22:26:14 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
original disc pos #0 + 350096 (350096) = #350096/77:47.71
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 350096 blocks [NU DVDRW DDW-082]
22:26:14 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 716996608, ISRC ""
DAO layout:
350096 | lead-out | 1 | 0x41 | 0x00
22:26:14 #12 Phase 24 File dlgbrnst.cpp, Line 1832
22:26:14 #13 Text 0 File Burncd.cpp, Line 4040
22:26:14 #14 Phase 25 File dlgbrnst.cpp, Line 1832
22:26:14 #15 Phase 36 File dlgbrnst.cpp, Line 1832
22:26:14 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2609
22:26:14 #17 Text 0 File DVDR.cpp, Line 2194
22:26:14 #18 Text 0 File Mmc.cpp, Line 21235
22:26:14 #19 Text 0 File DVDR.cpp, Line 2340
22:26:14 #20 Text 0 File Cdrdrv.cpp, Line 8430
22:27:22 #21 Text 0 File DVDR.cpp, Line 5225
Book Type request [QSI]: Physical disc type, write to EEPROM
22:27:22 #22 CDR -1211 File DVDR.cpp, Line 4763
Book Type set to: DVD-RW
22:28:19 #23 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x055D0000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x84 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
22:28:19 #24 CDR -1135 File Writer.cpp, Line 311
Write error
22:28:19 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
22:28:20 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
22:28:20 #27 Text 0 File DVDR.cpp, Line 2603
EndDAO: Last written address was 33951
22:28:20 #28 Phase 181 File dlgbrnst.cpp, Line 1832
Writing lead-out...
22:28:20 #29 Text 0 File DVDR.cpp, Line 5225
Book Type request [QSI]: DVD-RW, write to EEPROM
22:28:20 #30 Phase 38 File dlgbrnst.cpp, Line 1832
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
@julius1982fais ce qui est demande et reposte le log
@sv25170je n'arrive pas a mettre nero a jour sinon le reste est fait j'aavais le meme probleme avec recordnow dx mais il ne donne pas de code d'erreur
Windows XP 5.1
IA32
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 390MB (400292kB)
Memory in use : 46 %
Use Inquiry : 1
24.6.2007
ISO compilation
10:18:42 #1 Text 0 File Isodoc.cpp, Line 6172
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
10:18:42 #2 Text 0 File Reader.cpp, Line 127
Reader running
10:18:42 #3 ISO9660GEN -11 File geniso.cpp, Line 3293
10:18:42 #4 Text 0 File Burncd.cpp, Line 3153
10:18:42 #5 Text 0 File DlgWaitCD.cpp, Line 259
Last address to be written: 358527 ( 79:40.27, 700MB)
10:18:42 #6 Text 0 File DlgWaitCD.cpp, Line 271
10:18:42 #7 Text 0 File DlgWaitCD.cpp, Line 2316
10:18:42 #8 Text 0 File DlgWaitCD.cpp, Line 433
10:18:42 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
original disc pos #0 + 358528 (358528) = #358528/79:40.28
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358528 blocks [NU DVDRW DDW-082]
10:18:43 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 734265344, ISRC ""
DAO layout:
358528 | lead-out | 1 | 0x41 | 0x00
10:18:43 #11 Phase 24 File dlgbrnst.cpp, Line 1832
10:18:43 #12 Text 0 File Burncd.cpp, Line 4040
10:18:43 #13 Phase 25 File dlgbrnst.cpp, Line 1832
10:18:43 #14 Phase 36 File dlgbrnst.cpp, Line 1832
10:18:43 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
10:18:43 #16 Text 0 File DVDR.cpp, Line 2194
10:18:43 #17 Text 0 File Mmc.cpp, Line 21235
10:18:43 #18 Text 0 File DVDR.cpp, Line 2340
10:18:43 #19 Text 0 File Cdrdrv.cpp, Line 8430
10:19:12 #20 SCSI -1135 File Cdrdrv.cpp, Line 1181
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x53 0x00 0x00 0x00 0x00 0x00 0x05 0x78 0x80 0x00 0x00 0x00
10:19:12 #21 Text 0 File DVDR.cpp, Line 5225
10:19:12 #22 CDR -1211 File DVDR.cpp, Line 4763
10:19:12 #23 CDR -1135 File ThreadedTransferInterface.cpp, Line 1765
Write error
10:19:12 #24 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1765
10:19:13 #25 Phase 38 File dlgbrnst.cpp, Line 1832
Existing drivers:
Registry Keys:
salut,
1)mettre nero a jour (il ne me semble pas qu'il y soit)
2)desactiver fonction gravure xp,tuto ici;
http://www.faq-nero.com/faq008.php
3)desinstaller le lecteur virtuel,tuto ici;
http://forum.telecharger.01net.com/telecharger/autour_du_pc/pilotes/tutoriel_desinstaller_completement_les_lecteurs_virtuels-3633/messages-1.html
4)pas de disque multisession en mode DAO mais TAO
5)les donnees de ton dvd-rw ne sont pas completes,as tu essayer avec une autre marque?
